Volume of a bead - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Volume of a bead (/thread-11275.html) |
Volume of a bead - Albert Chan - 08-26-2018 02:07 PM Math trivia: a bead placed on the table (hole to the sky), volume = volume of sphere with diameter = height (You can think of a sphere is a bead with no hole, ... Neat) Here is a prove using messy integrals Simpson's rule for bead volume is simpler: let R = radius of sphere, r = radius of the hole, height of bead = 2 h, thus h² = R²- r² Half-Bead volume = h/6 * (top_area + 4 * middle_area + bottom_area) Bead volume = 2 Half-Bead = h/3 (0 + 4 Pi ( (√(R²- (h/2)²))² - r² ) + Pi (R²- r²)) = Pi/3 h (4 R² - h² - 4 r² + h²) = 4/3 Pi h^3 Here is a beautiful prove with no math, just visualization RE: Volume of a bead - Albert Chan - 09-09-2018 08:56 PM Find a gem of science/math stuff link: https://www.lockhaven.edu/~dsimanek/home.htm Physics Q&A: https://www.lockhaven.edu/~dsimanek/puzzles/ideas-answers.htm #1 Normally, a bridge is build on top of river, with ships passing beneath it. -> But there is water bridge, with ships run on top of it ... #66 holey sphere, about volume of bead. Solution by Martin Gardner ... --- I were trying to get a volume of bead with square hole (side 2 r). Its volume must be less than bead with round-hole, radius r. My first approximation for removed square holes volume ~ 4/Pi * volume of removed sphere round-hole = 4/Pi * (4/3 * Pi * (R^3 - h^3)) = 16/3 (R^3 - h^3), where h = sqrt(R^2 - r^2) Volume of square-holed bead ~ 4/3 Pi R^3 - 16/3 (R^3 - h^3) For relative small r, is that close ? RE: Volume of a bead - Zaphod - 09-09-2018 09:22 PM I like the sites sponsor: https://www.lockhaven.edu/~dsimanek/ideal/ideal.htm LOL RE: Volume of a bead - brickviking - 09-09-2018 09:45 PM (09-09-2018 09:22 PM)Zaphod Wrote: I like the sites sponsor: Sounds like the ideal sponsor. (Post 279) RE: Volume of a bead - Albert Chan - 09-18-2018 11:13 PM To maximize the holes of bead, the hole (no caps) can reach 1/sqrt(3) ~ 58% sphere volume ! http://datagenetics.com/blog/july22014/index.html If the problem get flipped, maximize size of sphere inside cyclinder, it is even higher = 2/3 ~ 67% http://datagenetics.com/blog/july32014/index.html |
