41CL Maximum registers for DATA/PROGS storage - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 41CL Maximum registers for DATA/PROGS storage (/thread-11091.html) Pages: 1 2 |
RE: 41CL Maximum registers for DATA/PROGS storage - Sylvain Cote - 07-25-2018 05:07 PM (07-25-2018 12:09 PM)Ángel Martin Wrote:Answer coming from the creator of the module ... what can you ask more.(07-20-2018 06:22 AM)Podalirius Wrote: I readed Cl XPMEM manual: seems that the commands for use of the additional 1024 registers are more byte consuming. I had not seen the implied question and thus never answered it. Thank you Àngel. Sylvain RE: 41CL Maximum registers for DATA/PROGS storage - Ángel Martin - 07-25-2018 06:47 PM (07-25-2018 04:43 PM)Gene Wrote: ...and since a very likely use of the Y-registers is by way of indirect addressing, the byte usage probably will not be as high as the savings in regular data registers would use. Very true indeed, thanks for pointing it out! BTW the registers directly accessible by YSTO, YRCL... are limited by the standard prompt field, of three characters - from 000 to 999. Using EEX opens up a fourth field with a leading "1", thus up to 1999 max. So the current 1,024 could be upped to 2,048 (or even 3,096) like it is the case with the SandMatrix 4Y - where the registers are managed by the matrix functions instead... Cheers, ÁM |
