HP48 machines as Serial Port Monitors - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP48 machines as Serial Port Monitors (/thread-11023.html) |
HP48 machines as Serial Port Monitors - TomC - 07-08-2018 03:12 PM Has anybody had any experience with using two HP48s to monitor the TX and RX lines of a serial port? I've been troubleshooting a RS232 connection to an instrument, and there are many times where I'm guessing as to what is happening on the serial port. It would be helpful to monitor the activity - eg is the instrument sending a stop transmission character etc. This is strictly a simple RX/TX connection with no HW handshaking. I'm thinking both of these monitor H48s have each of their RX lines connected to the respective RX and TX lines of the instrument/controller port. [I presume impedance loading will not be an issue.] Of course these monitor machines would be set up with the appropriate baud, party, bits etc... TomC RE: HP48 machines as Serial Port Monitors - acoto - 07-08-2018 04:33 PM It should work. If interface cabling distance/impedance is not too high, it should not affect the communication between external devices. Just grab a terminal application and try it. https://www.hpcalc.org/hp48/utils/terminal/ Electrical details here: https://www.hpcalc.org/hp48/docs/misc/io2.txt "The serial I/O port allows full-duplex communication between systems at 1200, 2400, 4800, or 9600 baud over wires with RS-232 compatible signal levels. Available parity settings are: none, odd, even, mark, or space." RE: HP48 machines as Serial Port Monitors - acoto - 07-08-2018 04:46 PM If concerned about affecting line impedance, you may add an external voltage follower between RX-TX external line and HP 48 RX. http://hyperphysics.phy-astr.gsu.edu/hbase/Electronic/opampvar2.html |
