New Version: 2018.01.24 1.4.0.13333 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: New Version: 2018.01.24 1.4.0.13333 (/thread-10061.html) |
RE: New Version: 2018.01.24 1.4.0.13333 - vervalin - 02-12-2018 06:57 PM (02-08-2018 10:54 PM)Mark Power Wrote: I’ve just upgraded from Beta 3 to 13333, and Racer and Baker’s Game are both now broken. Possibly DIMGROB related as I’m seeing insufficient memory errors? So, is there a workaround for this issue? Besides pressing the reset button on the back every time you want to run a program that uses DIMGROB? Do we know if HP is addressing this issue? Thanks RE: New Version: 2018.01.24 1.4.0.13333 - Tim Wessman - 02-12-2018 08:34 PM (02-12-2018 06:57 PM)vervalin Wrote:(02-08-2018 10:54 PM)Mark Power Wrote: I’ve just upgraded from Beta 3 to 13333, and Racer and Baker’s Game are both now broken. Possibly DIMGROB related as I’m seeing insufficient memory errors? All you'd need to do was make a stub function that will set G1-G9 to 0 pixels rather then a reset in the meantime. Yes, we are aware of it and working to resolve. RE: New Version: 2018.01.24 1.4.0.13333 - Mark Power - 02-12-2018 10:29 PM (02-12-2018 08:34 PM)Tim Wessman Wrote: All you'd need to do was make a stub function that will set G1-G9 to 0 pixels rather then a reset in the meantime. Thanks for the update Tim. I've updated Racer and Baker's Game to work with 13333 whilst the fix is prepared. I couldn't handle carrying around my Prime with my two favourite programs being broken, however temporarily :-) RE: New Version: 2018.01.24 1.4.0.13333 - Helge Gabert - 02-12-2018 10:51 PM FW version 13333 seems to be missing all one-color .jpgs to use in Graph3D as background. I chose one with a grayish tint in the beta 3 version (I forget the exact name). After the update, it was not available any more. No big deal, but is there a way to still select a light-color .jpg? RE: New Version: 2018.01.24 1.4.0.13333 - Tim Wessman - 02-13-2018 03:20 AM (02-12-2018 10:51 PM)Helge Gabert Wrote: No big deal, but is there a way to still select a light-color .jpg? No. Those were the files used in the title area and menu bars. However, since it seems like several people liked it we are thinking about being able to select a background color now... RE: New Version: 2018.01.24 1.4.0.13333 - Helge Gabert - 02-13-2018 05:03 AM Great, thanks! RE: New Version: 2018.01.24 1.4.0.13333 - Tim Wessman - 02-13-2018 05:06 AM Actually, I am dumb. Just do something like a 1x1 GROB with a color, save it as AFiles("color.png"):=DIMGROB_P(1,1,RGB(255,0,0)) or something like that, and then set your background to stretched. No need to wait. Note that syntax may not be correct... just throwing it out there to refine further. RE: New Version: 2018.01.24 1.4.0.13333 - Helge Gabert - 02-13-2018 02:41 PM Will try - - if it is safe to use DIMGROB in this way (no memory corruption?). RE: New Version: 2018.01.24 1.4.0.13333 - Tim Wessman - 02-13-2018 05:15 PM DIMGROB_P(G1,1,1,RGB(255,0,0)); ImageName:="red.png"; ImageDisplay:=2; AFiles(ImageName):=G1 is a better example. What memory corruption were you thinking about? Might hit the "insufficient memory" problem, but shouldn't be problematic. RE: New Version: 2018.01.24 1.4.0.13333 - Helge Gabert - 02-13-2018 06:11 PM OK. As you already guessed, I was only thinking about the insufficient memory problem, for example shown by trying to run the DIMGROB_demo program a second time. RE: New Version: 2018.01.24 1.4.0.13333 - Mic - 02-18-2018 12:34 PM I have some trouble with the connectivity kit : crash when I send an app on the virtual calculator for example RE: New Version: 2018.01.24 1.4.0.13333 - Tim Wessman - 02-21-2018 08:16 PM New files are out which addresses the major DIMGROB problem as well as a few others. |
