New FIRMWARE ! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: New FIRMWARE ! (/thread-10058.html) |
RE: New FIRMWARE ! - salvomic - 02-01-2018 08:21 PM (02-01-2018 08:11 PM)grsbanks Wrote: Sadly there isn't that level of interest here in the UK. Worst scenario in Italy :-( However a good seller (also on line) in North Italy has always Prime ready to send. Salvo RE: New FIRMWARE ! - KeithB - 02-01-2018 08:26 PM (02-01-2018 08:17 PM)Voldemar Wrote:(02-01-2018 07:29 PM)striegel Wrote: Now when I tell it to update firmware, it shows the same version it already has:There is «HP Connective Kit» folder in Documents folder. There is «Firmware» folder. Delete all from «Firmware» folder. Unzip «HP_Prime_Calculator_Firmware_20180124» (13 files) to «Firmware» folder. Now You can update calculator to the latest firmware. Or rename Firmware to something like Firmware_20170710 so you can revert (I guess!) if you have to. RE: New FIRMWARE ! - Voldemar - 02-01-2018 08:40 PM (02-01-2018 08:26 PM)KeithB Wrote: so you can revert (I guess!) if you have to.I do not know is it possible to downgrade HP Prime firmware or no. RE: New FIRMWARE ! - toml_12953 - 02-01-2018 08:54 PM (02-01-2018 07:29 PM)striegel Wrote: Since I haven't had the Prime for very long, I'm a relatively naive user of the Connectivity Kit. When I first acquired the Prime last last year, I updated the firmware using the Conn Kit. If you're using Windows, copy all the files in the ZIP to x:\users\username\Documents\HP Connectivity Kit\Firmware Where x it the letter where you have your user files stored (usually C) and username is your user name. The CK looks there for the latest version. RE: New FIRMWARE ! - striegel - 02-01-2018 09:27 PM (02-01-2018 08:54 PM)toml_12953 Wrote: If you're using Windows, copy all the files in the ZIP to Aha! I never thought to look there because I don't use the user area on my home system for anything. My practice has been to create a C:\alanstriegel directory and then put everything I care about under that. Thanks for the pointer. Now it's running the latest firmware. Alan RE: New FIRMWARE ! - Voldemar - 02-01-2018 10:31 PM HP Connectivity Kit, Check for update, now appears 20180124. |
