New FIRMWARE ! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: New FIRMWARE ! (/thread-10058.html) |
RE: New FIRMWARE ! - salvomic - 01-31-2018 05:03 PM (01-31-2018 04:37 PM)TheKaneB Wrote: There's also the Black-Scholes formula for option pricing, not found on the 12C. not found in the Calc, but there is in its manual... RE: New FIRMWARE ! - Tim Wessman - 01-31-2018 05:09 PM I was going to wait to post anything until the "update.xml" file that drives the automatic detection of updates was posted. Apparently, the old one was pulled down by the system and then the system proceeded to re-upload with a new date..... dunno. :? The document updates are still pending as well. RE: New FIRMWARE ! - Carlos295pz - 01-31-2018 05:18 PM (01-31-2018 05:09 PM)Tim Wessman Wrote: I was going to wait to post anything until the "update.xml" file that drives the automatic detection of updates was posted. Apparently, the old one was pulled down by the system and then the system proceeded to re-upload with a new date..... dunno. :? Many of us patiently await your publication RE: New FIRMWARE ! - smp - 01-31-2018 05:34 PM (01-31-2018 10:33 AM)ggauny@live.fr Wrote: Hi, I struggled to obtain this one, but I was finally able to get it all through TIPlanet. What irony to have to get a very important HP calculator update through TIPlanet! I suppose I was a little too anxious to wait. 8-) smp RE: New FIRMWARE ! - Tim Wessman - 01-31-2018 05:58 PM I think its great personally! The fact that Prime is either the #1 or #2 recommend calculator for France and has a high level of interest on the main european TI site speaks rather highly in my mind... You would have been prompted to get the update except the stupid system that manages the files on that site seems to be constantly thinking up new ways to mess up. RE: New FIRMWARE ! - toml_12953 - 01-31-2018 06:02 PM (01-31-2018 05:34 PM)smp Wrote: [quote='ggauny@live.fr' pid='90083' dateline='1517394836'] Oui. Bien sûr! Thanks for the link. I got the files from there with no problem. RE: New FIRMWARE ! BUG - Guenter Schink - 01-31-2018 07:24 PM Don't know if this happened before. On the real calculator push this sequence:
It doesn't happen so with the virtual calculator. Günter RE: New FIRMWARE ! - Voldemar - 01-31-2018 08:03 PM (01-31-2018 07:24 PM)Guenter Schink Wrote: [*]APPMe too. Also on virtual calculator. RE: New FIRMWARE ! - salvomic - 01-31-2018 08:10 PM (01-31-2018 08:03 PM)Voldemar Wrote: Me too. Also on virtual calculator. I cannot reproduce: in Geometry have already some curves, Symb -> in a void field New then OK I get "undef" in the field (then it is apparently not easy to delete it) but no restart, both HC and VC. Are you start with a void Symb list or there are already items? Salvo RE: New FIRMWARE ! - chromos - 01-31-2018 08:11 PM (01-31-2018 08:03 PM)Voldemar Wrote:Not having real calculator, but my Virtual one inserts 'undef' into edited field.(01-31-2018 07:24 PM)Guenter Schink Wrote: [*]APPMe too. Also on virtual calculator. [attachment=5620] [attachment=5621] RE: New FIRMWARE ! - Guenter Schink - 01-31-2018 08:22 PM (01-31-2018 08:10 PM)salvomic Wrote:(01-31-2018 08:03 PM)Voldemar Wrote: Me too. Also on virtual calculator. Ok. I had started with an empty list, and it crashed. Now after I have entered an item it doesn't do that any longer. Now I can't reproduce this behaviour. Günter RE: New FIRMWARE ! - Voldemar - 01-31-2018 08:27 PM (01-31-2018 08:11 PM)chromos Wrote: my Virtual one inserts 'undef' into edited field.Tried again. Yes, inserts «undef». First time was application error and application closed. Just tried after calculator reset, application error. RE: New FIRMWARE ! - salvomic - 01-31-2018 08:32 PM (01-31-2018 08:22 PM)Guenter Schink Wrote: Ok. I had started with an empty list, and it crashed. Now after I have entered an item it doesn't do that any longer. Now I can't reproduce this behaviour. so it could be a bug related at the starting with an empty list... RE: New FIRMWARE ! - Guenter Schink - 01-31-2018 09:18 PM (01-31-2018 08:32 PM)salvomic Wrote:(01-31-2018 08:22 PM)Guenter Schink Wrote: Ok. I had started with an empty list, and it crashed. Now after I have entered an item it doesn't do that any longer. Now I can't reproduce this behaviour. Yes, definitely. Now I was able to reproduce the behaviour. On both, the virtual and the real calculator.
Real calculator restarts, virtual calculator shuts down, showing a Windows error message. Günter Günter RE: New FIRMWARE ! - chromos - 01-31-2018 11:18 PM (01-31-2018 09:18 PM)Guenter Schink Wrote: Yes, definitely. Now I was able to reproduce the behaviour. On both, the virtual and the real calculator. I can confirm it. RE: New FIRMWARE ! - Voldemar - 01-31-2018 11:37 PM Just noticed on physical calculator. After update no more screen flickering when tap on battery symbol. Many thanks. How do I update my firmware with this? - striegel - 02-01-2018 07:29 PM Since I haven't had the Prime for very long, I'm a relatively naive user of the Connectivity Kit. When I first acquired the Prime last last year, I updated the firmware using the Conn Kit. Now when I tell it to update firmware, it shows the same version it already has: "Update firmware: 20170710" I did download the .zip file via ftp, but how does the Conn Kit make use of this? Alan RE: New FIRMWARE ! - grsbanks - 02-01-2018 08:11 PM (01-31-2018 05:58 PM)Tim Wessman Wrote: The fact that Prime is either the #1 or #2 recommend calculator for France and has a high level of interest on the main european TI site speaks rather highly in my mind... Sadly there isn't that level of interest here in the UK. In fact, if you go to HP UK's store there are only 4 machines advertised (2 financials, the 10s and the 300s), none of which is the Prime and all of which are out of stock... RE: New FIRMWARE ! - salvomic - 02-01-2018 08:12 PM (02-01-2018 07:29 PM)striegel Wrote: Since I haven't had the Prime for very long, I'm a relatively naive user of the Connectivity Kit. When I first acquired the Prime last last year, I updated the firmware using the Conn Kit. try putting all file in the firmware folder in C:\Users\%your_user_name%\Documents\HP Connectivity Kit\Firmware RE: New FIRMWARE ! - Voldemar - 02-01-2018 08:17 PM (02-01-2018 07:29 PM)striegel Wrote: Now when I tell it to update firmware, it shows the same version it already has:There is «HP Connective Kit» folder in Documents folder. There is «Firmware» folder. Delete all from «Firmware» folder. Unzip «HP_Prime_Calculator_Firmware_20180124» (13 files) to «Firmware» folder. Now You can update calculator to the latest firmware. |
