Last X after Classics - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Last X after Classics (/thread-10045.html) |
Last X after Classics - Matt Agajanian - 01-28-2018 10:07 PM Hi all. Since LastX was implemented on HP-45s and higher, it would seem plasusible that LastX would be a built-in. So, since multiple registers were possible as evidenced by later Classics after the 35, why wasn’t there a Last X operation on the Woodstock HP-21? RE: Last X after Classics - PANAMATIK - 01-28-2018 10:46 PM (01-28-2018 10:07 PM)Matt Agajanian Wrote: Hi all. The HP-21 was the only Woodstock calculator without RAM chip. It had only the ACT registers for stack, all calculatons and one memory storage register. No register was left for Last X. Bernhard RE: Last X after Classics - Matt Agajanian - 01-28-2018 10:52 PM Ah! Thanks for the details. I suppose adding a RAM chip and the additional functionalities it would provide would put the 21 out of the economial price range too. RE: Last X after Classics - rprosperi - 01-29-2018 12:17 AM Thanks for explaining that Bernhard, I have wondered about that many times (most notably right after I upgraded from a -21 to a -25). Simple enough reason, once you have it explained. I always thought it was some form of HP limiting the -21 feature set to make the upgrade models seem so much better. But no, simply no registers available. Thanks! |
