What is the best BASIC Pocket Computer - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: What is the best BASIC Pocket Computer (/thread-1003.html) |
RE: What is the best BASIC Pocket Computer - Katie Wasserman - 04-17-2014 04:07 PM Quote:You might want to try using Everyready Lithium AA Batteries. They will last a lot longer than standard AA batteries. They cost more, but I can usually find them on sale for about half price several times a year and I stock up on them at the lower price. I use tem in my HP-200LX and in my Omnibook OB-430. I was using these in my HP-200LX as well, they do last a lot longer. However they have a very flat discharge voltage profile, dropping to zero very rapidly at the end of their life. This results in the low battery indication being shown for a very short time before the cells are completely dead. I didn't like that and switched back to alkaline cells. RE: What is the best BASIC Pocket Computer - Bill (Smithville NJ) - 04-17-2014 07:33 PM Quote: just did the test (167699497) on a HP-200LX running GW-Basic and Basica. Both took about 9.3-9.5 seconds. So UBASIC is quite a bit faster. Okay, I repeated the test on a pocket computer - Sharp PC-1600. I had to slightly modify the program - Sharp's basic didn't like multiple statements after the IF/THEN in line 190. Plus used the TIME function to calculate the elapsed time. For 167699497, it took about 100 seconds. I was going to try the PC-1262, but can't find my unit. Probably in the bottom of a very messy drawer. Bill RE: What is the best BASIC Pocket Computer - Sylvain Cote - 04-17-2014 10:18 PM I just ran the program on a HP-75C and it took 40.737 seconds for X=167699497. program changes ... 1 DELAY 0 5 REAL X, F, M, T1, T2 15 T1=TIME 900 T2=TIME @ DISP all PRINT's replaced by DISP all : replaced by @ Sylvain [edit: add program changes] RE: What is the best BASIC Pocket Computer - hp41cx - 04-17-2014 10:36 PM Bench RE: What is the best BASIC Pocket Computer - Guenter Schink - 04-18-2014 06:19 PM (04-17-2014 10:36 PM)hp41cx Wrote: Bench With UBASIC on the 200LX without any change except for time measurement and dim(8) 6.76 sec. A minor improvement to 6.36sec. when using shortened arithmetic e.g. A+=X instead of A=A+X. Günter RE: What is the best BASIC Pocket Computer - Guenter Schink - 04-18-2014 09:12 PM (04-16-2014 08:23 PM)Guenter Schink Wrote: Your example of 167699497 is calculated in about 2.4 seconds Now I have transformed the code into a structured form, no "GOTOs" any more . Then I use some special operations of UBASIC. But the algorithm is the same still. Code: 100 input "X=";X This program needs 1.53 sec for 167699497 on the 200LX. Günter RE: What is the best BASIC Pocket Computer - Dave Britten - 04-18-2014 09:51 PM (04-18-2014 09:12 PM)Guenter Schink Wrote:(04-16-2014 08:23 PM)Guenter Schink Wrote: Your example of 167699497 is calculated in about 2.4 seconds That's pretty impressive. I definitely need to experiment with UBASIC this weekend. For the record, I loaded my GW-BASIC version into QBASIC and ran it with no modifications, and it took about 12 seconds, or ~50% longer. Still can't find any place to download Swift!BASIC that I've seen mentioned in The Palmtop Paper archive. RE: What is the best BASIC Pocket Computer - ckreling - 05-07-2014 01:36 AM (04-06-2014 06:13 PM)rprosperi Wrote: [quote='Katie Wasserman' pid='8499' dateline='1396768062'] So nice to see this discussion. I have a pretty large Sharp Wizard collection (Museum) some new in box. I love hunting down elusive cards for the wizards. As you mentioned the work you did - I recently acquired a prudential 'PRUPACRATER' card. After reading your info I looked at the back and low and behold it is an OZ-770 64KB with a special label from Prudential on the front. Thanks so much for sharing that information. RE: What is the best BASIC Pocket Computer - Paul Berger (Canada) - 05-07-2014 02:44 AM I ran Dave's prime factor program on an Panasonic HHC running snapBASIC I replaced the first data statement with an array because the restore function in this dialect restores all data statements in the program. Time functions are different you read the clock by peeking at 5 sequential bytes in memory. Replaced all the INT functions with one called FIX as INT will only work with integer values and they are limited to a signed 16 bit number. Replaced SQR with SQRT, SQR returns the square of the argument. In interpreted mode 167699497 takes almost exactly 3 mins despite having a considerable faster CPU than the HP handhelds. I think the difference is the HP handhelds are running a CPU that is optimized for floating point math, whereas the HHC is running a 1 MHz 6502, a general purpose processor and a very simple one at that. I wanted to try this as a compiled program but before I can do that I need to figure out a way to get the compiled program off the machine and burn it into a EPROM as the design of the system does not allow the execution of compiled programs from RAM. The design of this machine is, interesting but the keyboard on it is pretty unfortunate. It works well but the keys are crowded and the keytops are small rectangles arranged in straight columns. The key legends are printed on the top of the machine around the keys instead of on the keytops and are pretty busy, it is not a nice keyboard to type on. RE: What is the best BASIC Pocket Computer - Csaba Tizedes - 01-04-2019 04:52 PM I found Xerxes' Benchmarks for 8-Queens problem and I found a TI-74 assembly routine on that page, but as I know the assembly programming on this machine is not available. Is there any information/docs about how these units are programmed in assembly? Also the same information available for CASIO FX-850P/880P ? Thanks! Csaba RE: What is the best BASIC Pocket Computer - Csaba Tizedes - 01-04-2019 07:56 PM (04-06-2014 08:26 PM)Alvaro Wrote: The Casio Fx-850P has a User Defined Function Really? How? This chocolate-sized marvel was my first computer and I do not really remember this feature... But this was 25 years ago... RE: What is the best BASIC Pocket Computer - JurgenRo - 01-04-2019 10:32 PM (03-30-2014 12:58 PM)Sylvain Cote Wrote: Most if not all of your questions can be answered by the HHC BASIC Comparison Sheet from Marcus Sylvain, you are an unbelievable source of information! Thanks for sharing this comparison data sheet! Greetings, Juergen RE: What is the best BASIC Pocket Computer - xerxes - 01-05-2019 06:31 PM (01-04-2019 04:52 PM)Csaba Tizedes Wrote: I found Xerxes' Benchmarks for 8-Queens problem and I found a TI-74 assembly routine on that page, but as I know the assembly programming on this machine is not available. Is there any information/docs about how these units are programmed in assembly? Please check this discussion for assembly programming on the TI-74: http://www.vcfed.org/forum/showthread.php?61884-Peek-Poke-and-the-TI-74 AFAIK there is no way for the FX-850P/880P. RE: What is the best BASIC Pocket Computer - Csaba Tizedes - 01-06-2019 02:28 PM (01-05-2019 06:31 PM)xerxes Wrote: Please check this discussion for assembly programming on the TI-74: http://www.vcfed.org/forum/showthread.php?61884-Peek-Poke-and-the-TI-74 Thanks, I have checked and downloaded tons of information. Really valuable source! RE: What is the best BASIC Pocket Computer - Sukiari - 01-07-2019 08:14 AM (04-13-2014 05:26 AM)Waon Shinyoe Wrote: IMHO SHARP G850 series is the best one though it aims at education market. It supports BASIC, on-calc C and ASM and machine code. (Though the soft keyboard is annoying...) I agree, it’s a great little machine, and it’s a big shame that there is basically nothing like these around any more. RE: What is the best BASIC Pocket Computer - toml_12953 - 01-07-2019 08:40 PM (04-08-2014 02:53 AM)Joe Horn Wrote: Although that wasn't the OZ-707, it was the OZ-770 (only 64K of RAM), almost identical to the OZ-707 except for having only 64K of RAM, and an IQ-775 (64K of EPROM and 32K of RAM) in which you had put the BASIC language. How much memory does the OZ-707 have? I thought it only had 32K RAM. Tom L RE: What is the best BASIC Pocket Computer - rprosperi - 01-08-2019 02:45 AM (01-07-2019 08:40 PM)toml_12953 Wrote: How much memory does the OZ-707 have? I thought it only had 32K RAM. The OZ-707 BASIC Card had 32K RAM and was sold at retail as one of the consumer application cards for the Wizard family and had a label on the front with digits and scientific function names to see through the clear touchpad on the OZ-7000, 7200, 8000, etc. (the product line used model designation OZ-NNN in US, and IQ-NNN in ROW). The OZ-770 had 64K RAM and had a blank face (as seen above) was sold only through VAR channels for vertical solution developers. RE: What is the best BASIC Pocket Computer - damaltor - 01-09-2019 01:04 PM I would rather stick with casio, the fx-880p is what i would select. the pb-2000 with the basic module is decent, too, the pb-1000 has a nice basic os, but the worst possible housing. all three possibilities are not exactly cheap, though the fx-880p is a very nice device which might be "worth it" for whatever it is needed for. alternatively, the older casio basic models are nice too but have exceptionally small displays. the good point is that i made a usb interface a while ago which allows transfer from the basic programs to and from the calculator, and also allows use with the tools made by Marcus to compile/decompile the basic programs. RE: What is the best BASIC Pocket Computer - Erwin - 01-09-2019 05:24 PM (03-30-2014 12:57 PM)Bill (Smithville NJ) Wrote: Hi Namir, I owned a PC1600 and sold it last year complete with disc drive, printer and all manuals. I programmed Z80 Assembler in the past and Basic and it was very fine. But:
regards Erwin RE: What is the best BASIC Pocket Computer - toml_12953 - 01-11-2019 03:32 AM (01-08-2019 02:45 AM)rprosperi Wrote:(01-07-2019 08:40 PM)toml_12953 Wrote: How much memory does the OZ-707 have? I thought it only had 32K RAM. Thanks. The way Joe kept saying "only 64K" when talking about the 770 made it sound like the 707 had more than the 770. Tom L |
