New WP34S unit - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: New WP34S unit (/thread-20705.html) |
RE: New WP34S unit - Nigel (UK) - 11-14-2023 08:04 PM I’m very happy for C47 to use the algorithm. However, I’m much less familiar with the C47 code than with the WP34S code. Even with the latter I keep getting in a muddle with the various decNumber functions! The C code (no decNumbers) I wrote to test the algorithm worked essentially the first time; the WP34S version didn’t, and needed several compilation cycles to get all my decNumber mistakes sorted out. As I’m not currently set up to build the C47, any code I contributed would surely contain syntax errors as I couldn’t readily check it. So I’ll offer a fully-commented simple C (i.e., just ints and doubles) version of the algorithm. It would then be straightforward for one of the team to convert it, if they wanted to use it. Or I could do it, but it might take a while! I’ll post about this on the C47 forum. Nigel (UK) RE: New WP34S unit - Nigel (UK) - 11-14-2023 08:05 PM (11-13-2023 09:35 PM)ebs Wrote: Tested r3924, it's working fine. Thanks Nigel.As always, thank you for the feedback! Nigel (UK) RE: New WP34S unit - burkhard - 11-21-2023 06:40 PM You guys are amazing! I need to get out my cable and get re-flashing. I've been using these for years and I really do love the WP34S — I can buy an HP30b cheap, flash it to WP34S, sticker it, and get it to work in some ugly environments like my wood shop or garage, places I don't bring my many near-perfect 1970s and 80s HPs (they get used, but only on a nice clean safe desk). If the WP34S takes a hit or gets something spilled on it, it's not the end of the world. Nonetheless it does EVERYTHING I need and I know the UI well at this point. Really a nice project you all did... Thanks! |
