41CL Self-Update
11-21-2017, 04:47 PM
Post: #121
RE: 41CL Self-Update
(11-21-2017 04:25 PM)Monte Dalrymple Wrote:
(11-21-2017 03:08 AM)Neve Wrote:  Just to let you know that the update went fine (finally).
On a side note, the clupdate program showed 13 pages out-of-date, not 14.
The update instructions marked 14 pages as out-of-date. You missed one.
Probably one of the adjacent pages, where you are supposed to do two
XEQ "PGINV" in a row.
I thought I did. But I apparently missed one then...
Should I go through the whole process again?
11-21-2017, 07:34 PM
Post: #122
(11-21-2017 04:47 PM)Neve Wrote:
(11-21-2017 04:25 PM)Monte Dalrymple Wrote:  The update instructions marked 14 pages as out-of-date. You missed one.
You can either go through the process again or check each of the pages individually.
It's probably easier just to go through the process again.
11-21-2017, 07:53 PM (This post was last modified: 11-21-2017 07:54 PM by Neve.)
Post: #123
(11-21-2017 07:34 PM)Monte Dalrymple Wrote:
(11-21-2017 04:47 PM)Neve Wrote:  I thought I did. But I apparently missed one then...
I did, but it’s not working.
The first YPOKE
"830AC2-0150"
XEQ YPOKE
Returns DATA ERROR.
11-21-2017, 08:43 PM
Post: #124
(11-21-2017 07:53 PM)Neve Wrote:
(11-21-2017 07:34 PM)Monte Dalrymple Wrote:  You can either go through the process again or check each of the pages individually.
The first YPOKE
"830AC2-0150"
XEQ YPOKE
Returns DATA ERROR.
Enter the hex again. DATA ERROR means what is in ALPHA is not the right format or
not hexadecimal.
11-21-2017, 09:12 PM
Post: #125
(11-21-2017 08:43 PM)Monte Dalrymple Wrote:  Enter the hex again. DATA ERROR means what is in ALPHA is not the right format or
not hexadecimal.
My bad. Everything is fine.
Do I have to redo the update every time I mess around and want to reset the calc by doing a MEMORY LOSS?
11-21-2017, 10:15 PM
Post: #126
not hexadecimal.
No. The changes are permanent. Your 41CL is up-to-date, at least until more
.rom files are added or new updates are released.
11-21-2017, 10:17 PM
Post: #127
(11-21-2017 10:15 PM)Monte Dalrymple Wrote:  No. The changes are permanent. Your 41CL is up-to-date, at least until more
Awesome. Thank you!!!!
11-21-2017, 11:25 PM
Post: #128
FYI, clupdate v1.1.0 with v5 support is coming along quite nicely.
The code is complete, everything works, I am currently testing edge cases.
Sylvain
11-22-2017, 03:11 AM
Post: #129
(11-21-2017 11:25 PM)Sylvain Cote Wrote:  FYI, clupdate v1.1.0 with v5 support is coming along quite nicely.
Sylvain
Wonderful!
You’re doing an awesome job, really!
09-06-2018, 09:09 PM
Post: #130
Every time I perform an update (just done a couple) I cannot forget to thank (never will be enough) Sylvain for his big contribute, Monte and everybody on this site who shared their personal experience and gave useful advices. Smile
thank-you again
09-06-2018, 10:58 PM
Post: #131
(09-06-2018 09:09 PM)aurelio Wrote:  Every time I perform an update (just done a couple) I cannot forget to thank (never will be enough) Sylvain for his big contribute, Monte and everybody on this site who shared their personal experience and gave useful advices. Smile
thank-you again
Indeeeeeeeed!!! A big thanks to all of them.
09-07-2018, 12:15 AM
Post: #132
(09-06-2018 09:09 PM)aurelio Wrote:  Every time I perform an update ...
Each time a 41CL user update his board by himself is our reward, so keep doing it, that was the goal.
(09-06-2018 10:58 PM)Neve Wrote:
(09-06-2018 09:09 PM)aurelio Wrote:  thank-you again
You are welcome!
The biggest thanks part, by far, should go to Monte who created the 41CL , the YFN? ROMs, the update ROM and so many other things. THANK YOU!
Sylvain
09-07-2018, 05:26 AM (This post was last modified: 09-07-2018 05:30 AM by Ángel Martin.)
Post: #133
Sylvain
And just to keep the machine well oiled, a set of 14 updated modules is about to be released - maintenance releases? Yes and no, an updated Auto-Complete Navigator and the new "Universal Execute" are coming, allowing access to the sub-functions in the listings, as well as direct execution by NAME of any function *and* sub-function across the bus. - That is, knowing the individual launchers on each module won't be necessary anymore.
So get psyched!
ÁM
09-07-2018, 11:35 AM (This post was last modified: 09-07-2018 11:36 AM by Sylvain Cote.)
Post: #134
Quote:And just to keep the machine well oiled, a set of 14 updated modules is about to be released ...
I really do not know where you find the time to get so much done, you must be living in another space-time continuum. Wink
THANK YOU Ángel for having created, keeping improving & creating new mind blowing modules.
Sylvain
09-07-2018, 12:00 PM
Post: #135
Sylvain
Yes Ángel: THANK YOU VERY MUCH!
01-03-2019, 12:20 PM (This post was last modified: 01-07-2019 07:57 AM by jedu.)
Post: #136
RE: 41CL Self-Update - Another success - Update
Hi
I purchased in January 2017 a V4 board. I had it installed by Jose Gonzalez (at the same time I got a Time module from him, very good service) in October 2017 and I didn't had the time to play with it, until yesterday... I decided to try to update it, and everything was such easy, that sometimes I even think the calculator was cheating me.
What follows are the first steps in my learning experience. I hope others can benefit of it.
I used Ubuntu 16.04LTS almost clean and I followed the excellent pdf by Sylvain Côté
41CL FLASH UPDATE
Before that I read a bunch of messages and I followed this PDF, with two small additions, changes I'll mention later.
I downloaded clupdate-1.1.0.zip and rom_files_181228.zip from 41CL Calculator File Area
To my surprise the content was not as described in Sylvain's pdf... in particular there was no UPDAT-2B.ROM ...
I installed Oracle JDK (which includes JRE) using the "Ubuntu way".
$ sudo add-apt-repository ppa:webupd8team/java
$ sudo apt-get update
$ sudo apt-get install oracle-java8-installer
And I followed Sylvain's pdf instructions, with inputs from several messages...
I added the TURBO 50
I uploaded UPDAT-4A.ROM (Instead of UPDAT-2B.ROM). This was the part in which I was less confident... I didn't get the clear idea that I was doing it well...
I used a USB 2.0 to RS232 DB9, UGREEN Serial RS232 Adapter and the serial cable I purchased from Daryl at the same time.
Linux recognized the adapter without any problem. I had to search with dmesg the /dev/tty the kernel had given to the serial interface, in my case /dev/ttyUSB0.
Please note that the device file cannot be used by standard users... Instead of adding my user to the dialout group or changing the permissions I did use sudo. This can be very probably considered a bad practice...
edu@Narsill:~/clupdate$ sudo java -jar clupdate-1.1.0.jar --upload UPDAT-4A.ROM /dev/ttyUSB0 4800
23:41:46 --upload    [fileName: UPDAT-4A.ROM] [portName: /dev/ttyUSB0] [baudRate: 4800]
23:41:46 File       UPDAT-4A.ROM loading ...  done [YCRC=0x5189B8F2 Rev:2018-12-15]
23:41:46 Serial     /dev/ttyUSB0 opened.
23:41:46 Sleeping   5 seconds before starting file transfer
23:41:51 Sending    8192 = 8192 bytes sent
23:42:10 Serial     /dev/ttyUSB0 closed.
I did run a COMPLETE FLASH SCAN (V3 & V4)
This is the output, after the scan:
23:47:05 --update   [fileName: rom_files_181228.zip] [portName: /dev/ttyUSB0] [baudRate: 4800]
23:47:05 File       rom_files_181228.zip loading ... done
23:47:06 Serial     /dev/ttyUSB0 opened at 4800 baud.
23:47:06 Waiting    for 41CL commands ...
23:47:09 Received   OPEN_CHANNEL_REQUEST(0x41)
23:47:09 Sent       OPEN_CHANNEL_RESPONSE(0x42)
23:48:22 Received   FLDB_4MB_IMPORT_REQUEST(0x45) [Page: 0x0DE] [BoardGeneration: second] [EstimatedFullScan: 01h 25m 58s]
23:48:22 File       [FileName: FLDB.ROM] [YCRC:0x12282018] [Rev: 2018-12-28]
23:48:22 Sending    8192 = 8192 bytes sent
23:48:49 Received   KEEP_ALIVE(0x59))))))))))))))))))))))))))))))))
01:09:05 Received   KEEP_ALIVE(0x59))))))))))))))))))))))))))))))))
01:14:19 Received   CORR_FLDB_4MB_EXPORT_REQUEST(0x4D)
01:14:19 Sent       CORR_FLDB_4MB_EXPORT_RESPONSE(0x4E)
01:14:19 Receiving  2186 2188 2189 1629 = 8192 bytes received
01:14:38 File       CFLDB.ROM saved
01:14:38 Report     Outdated ROM images [BoardGeneration: second]
01:14:38 Report     NUT0-N.ROM      [Page:0x000 ID:OS41 Rev:2018-12-02 YCRC:0xDBE7A58C]
01:14:38 Report     TIME-3A.ROM     [Page:0x006 ID:TMOD Rev:2018-12-02 YCRC:0x59097A6D]
01:14:38 Report     YFNZ-4F.ROM     [Page:0x007 ID:YFNZ Rev:2018-12-02 YCRC:0x3650EF10]
->01:14:38 Report     YFNX-4C.ROM    [Page:0x00A ID:YFNX Rev:2018-12-28 YCRC:0x15C13E04]
01:14:38 Report     YLIB-4B.ROM     [Page:0x00B ID:YLIB Rev:2018-12-28 YCRC:0x0C09DA8C]
01:14:38 Report     ALL_FF.ROM      [Page:0x1FB ID:     Rev:2018-11-01 YCRC:0x53D36BD2]
01:14:38 Report     108 outdated pages, out of 512 pages, spread over 38 Flash blocks, estimated update time: 02h 18m 10s
I started the update (changing the command FLUDP by FLUPD)
01:15:57 Received   PAGE_IMPORT_REQUEST(0x53) [Page:0x00A]
->01:15:57 Image      YFNX-4C.ROM     [Page:0x00A ID:YFNX Rev:2018-12-28 YCRC:0x15C13E04]
01:15:57 Sending    8192 = 8192 bytes sent
01:16:15 Received   PAGE_IMPORT_REQUEST(0x53) [Page:0x00B]
01:16:15 Image      YLIB-4B.ROM     [Page:0x00B ID:YLIB Rev:2018-12-28 YCRC:0x0C09DA8C]
01:16:15 Sending    8192 = 8192 bytes sent
03:24:21 Received   PAGE_IMPORT_REQUEST(0x53) [Page:0x1FB]
03:24:21 Image      ALL_FF.ROM      [Page:0x1FB ID:     Rev:2018-11-01 YCRC:0x53D36BD2]
03:24:21 Sending    8192 = 8192 bytes sent
03:28:23 Received   CLOSE_CHANNEL_REQUEST(0x57)
03:28:23 Sent       CLOSE_CHANNEL_RESPONSE(0x58)
03:28:27 Serial     /dev/ttyUSB0 closed.
The calculator showed UPD DONE.
I continued with Sylvain's instructions closing the communications and setting up MMU.
And that was all... at least that's what I thought...
Later, a user discovered that the first three modules weren't updated. In fact it's correct... you can notice in the previous list excerpts with a -> that the YFNX-4C.ROM module is the 4th to be discovered to be outdated but the first one to be updated.
The first three modules, NUT0-N, TIME-3A, and YFNZ-4F are part of the operating system and as such write-protected and aren't updated.
The solution is to execute OSUPDT before FLUPD to remove the protection and after the update OSPROT to restore protection. Original explanation can be found here: http://www.hpmuseum.org/forum/thread-120...#pid109967
There is a new feature which gets installed in this update in the 41CL Update Functions (YUPS module, in fact in UPDAT-4A.ROM) which improves dramatically the speed of scan time. Read all the comments, including situations in which this could cause problems here http://www.hpmuseum.org/forum/thread-120...#pid109837.
Thank you to Monte and Sylvain for your work and members of the forum for your help...
Now I only need to decide to "play/learn" with it, by preparing a good configuration and reading much from 41CL manuals and HP41-DVD...
I tried to follow without success Gene Wright's recommendations in:
HHC 2015 HP 41CL update
In particular I get stuck in configuration 1, in step 12: XEQ HEPINI, trying to get the "A" into the prompt... Any clue?
Best regards and thank you for your time.
Eduardo/EA2BAJ
PD: If somebody wants the full log, just send me a private message.
PD2: It some of comments or conclusions are dangerous, just let me know.
PD3: Perhaps having Sylvain's PDF updated in HHC would be very helpful...
01-03-2019, 12:31 PM (This post was last modified: 01-03-2019 12:34 PM by Neve.)
Post: #137
Hi and Happy New Year 2019! Best Wishes to all!!
Is there a list, somewhere..., of changes from updates to updates? It is always with great pleasure that I see and update popping up. But, except for new added modules, what are the updates/upgrades, bug fixes and what not, to already existing modules??
Maybe I don’t know where to look...?
Thank you all.
01-03-2019, 01:28 PM (This post was last modified: 01-03-2019 01:29 PM by Sylvain Cote.)
Post: #138
(01-03-2019 12:31 PM)Neve Wrote:  Is there a list, somewhere..., of changes from updates to updates? It is always with great pleasure that I see and update popping up. But, except for new added modules, what are the updates/upgrades, bug fixes and what not, to already existing modules??
You can list the ROM changes by comparing two rom_files_YYMMDD.zip files (available HERE)
Example:
java -jar clupdate-1.1.0.jar --diff rom_files_181202.zip rom_files_181228.zip
Result:
                              [rom_files_181202.zip/mem_ref_v2.txt] vs [rom_files_181228.zip/mem_ref_v2.txt]
YFNX-4B.ROM     [Page:0x00A ID:YFNX Rev:2018-12-02 YCRC:0x0BCBF9C6] != YFNX-4C.ROM     [Page:0x00A ID:YFNX Rev:2018-12-28 YCRC:0x15C13E04]
YLIB-4A.ROM     [Page:0x00B ID:YLIB Rev:2018-11-01 YCRC:0x79AF544D] != YLIB-4B.ROM     [Page:0x00B ID:YLIB Rev:2018-12-28 YCRC:0x0C09DA8C]
UPDAT-3B.ROM    [Page:0x062 ID:YUPS Rev:           YCRC:0xF9417D87] != UPDAT-4A.ROM    [Page:0x062 ID:YUPS Rev:2018-12-28 YCRC:0x5189B8F2]
YFNF-2A.ROM     [Page:0x0AF ID:YFNF Rev:2018-09-10 YCRC:0x44AB64B1] != YFNF-3A.ROM     [Page:0x0AF ID:YFNF Rev:2018-12-28 YCRC:0x39FA9FA2]
FLDB_V2.ROM     [Page:0x0DE ID:FLDB Rev:2018-12-02 YCRC:0x12022018] != FLDB_V2.ROM     [Page:0x0DE ID:FLDB Rev:2018-12-28 YCRC:0x12282018]
Summary: 5 outdated pages, out of 256 pages, spread over 4 Flash blocks, estimated update time: 00h 12m 38s
                                 [rom_files_181202.zip/mem_ref.txt] vs [rom_files_181228.zip/mem_ref.txt]
UPDAT-3B.ROM    [Page:0x062 ID:YUPS Rev:2018-01-22 YCRC:0xF9417D87] != UPDAT-4A.ROM    [Page:0x062 ID:YUPS Rev:2018-12-28 YCRC:0x5189B8F2]
FLDB.ROM        [Page:0x0DE ID:FLDB Rev:2018-12-02 YCRC:0x12022018] != FLDB.ROM        [Page:0x0DE ID:FLDB Rev:2018-12-28 YCRC:0x12282018]
YFNF-2A.ROM     [Page:0x167 ID:YFNF Rev:2018-04-02 YCRC:0x44AB64B1] != YFNF-3A.ROM     [Page:0x167 ID:YFNF Rev:2018-12-28 YCRC:0x39FA9FA2]
Summary: 5 outdated pages, out of 512 pages, spread over 4 Flash blocks, estimated update time: 00h 12m 38s
                              [rom_files_181202.zip/mem_ref_v5.txt] vs [rom_files_181228.zip/mem_ref_v5.txt]
Summary: 5 outdated pages, out of 1024 pages, spread over 4 Flash blocks, estimated update time: 00h 12m 38s
If you want what has changes for a specific ROM, you have to read the release notice or the user manual for that specific ROM, if it exist.
Sylvain
01-03-2019, 11:22 PM
Post: #139
Thank you Sylvain.
01-05-2019, 08:40 PM
Post: #140
Just to let you guys know that the latest update has a glitch.
2 of the updated modules do not get installed on the machine.
TIME-3A.ROM
NUT0-N.ROM
