New Version: 2016.12.08 1.3.1.11226 [UPDATED]
12-13-2016, 08:27 PM
(This post was last modified: 12-16-2016 03:58 PM by Tim Wessman.)
New versions should be appearing on the FTP sometime shortly. The "check for update" functionatlity in any current connectivity kit or emulator will prompt you when it finds the update. If you happened to be in the "public beta", it will prompt you for a download to the release version as well. If your network blocks direct connection, the direct link can be found at "ftp.hp.com/pub/calculators/Prime/". The connectivity kit and emulator are now supported on both windows and mac. The iOS/Android/Winstore versions will be downloaded through your normal phone update mechanism as they are approved by the various stores. HP Prime Connectivity Kit Installer - Windows HP Prime Virtual Calculator Installer - Windows HP Prime Connectivity Kit DMG - macOS HP Prime Virtual Calculator DMG - macOS This release is focused around getting macOS support, and all the store applications synchronized. There were some changes in the Core calculator code, but mostly this will be identical to the last release. Note - There is no hardware calculator firmware release this round. This is expected. Quote:Date Released: 2016/12/08 TW Although I work for HP, the views and opinions I post here are my own. |
12-13-2016, 09:03 PM
RE: New Version: 2016.12.08 1.3.1.11226
Hello Tim
Thank you very much for the effort…but, are you sure of the links for Mac? I get "404 Not found" for both CK and Emulator. Or is it my system? Really sorry… Kind regards. JM. |
12-13-2016, 09:32 PM
(12-13-2016 09:03 PM)Jean-Michel Wrote: Hello Tim No, it is the FTP. Files are not appearing "smoothly" at the moment. Some even deleted the prior ones. I might even just remove the links for the moment until I'm certain the files are there. TW Although I work for HP, the views and opinions I post here are my own. |
12-13-2016, 09:47 PM
OK, thank you Tim for the prompt reply.
I'll check later on. I was kinda impatient to get them on my Mac laptop! Regards, JM |
12-14-2016, 02:51 AM
Thanks for working on the macOS support!
12-14-2016, 04:00 AM
Viga C | TD | FB |
12-14-2016, 06:01 AM
Viga C | TD | FB |
12-14-2016, 06:24 AM
Depending on the system that you are running, the function returning the used memory will not always report the same thing. On the HW calculator, it reports the "Free RAM". On computers, it reports, depending on the OS, either the Heap used, or the heap + program size, heap + program + shared libraries... So this can lead to a high variability between OS. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
12-14-2016, 10:36 AM
For me , don´t work properly. After traying download from ftp, the instalation abort.
When update from virtual calculator, show this alert: Leo |
12-14-2016, 12:38 PM
As a brand new member and computer illiterate, what is ftp and where do I find it? As a MAC user, without access to the connectivity kit and emulator for the Prime, where do I go to download the new connectivity kit and emulator designed for us MAC users.
12-14-2016, 03:23 PM
(12-14-2016 10:36 AM)jrozsas Wrote: When update from virtual calculator, show this alert:The same behaviour (win 7 64bit). Prime, 15C CE |
12-14-2016, 04:14 PM
(12-14-2016 10:36 AM)jrozsas Wrote: For me , don´t work properly. After traying download from ftp, the instalation abort. This is why we are moving away from using FTP in the new version. There are built in limits that cause problems for some people when using FTP transactions. Please click the direct link in my original post. TW Although I work for HP, the views and opinions I post here are my own. |
12-14-2016, 04:16 PM
(12-14-2016 12:38 PM)philipsrosen Wrote: As a brand new member and computer illiterate, what is ftp and where do I find it? As a MAC user, without access to the connectivity kit and emulator for the Prime, where do I go to download the new connectivity kit and emulator designed for us MAC users. You will need to wait until the original post gets updated with links to click. Right now, the files have been submitted and are in limbo somewhere in the internal file posting software on the HP side. Hopefully, that will be resolved some time today, but may take a few days. It is unfortunately impossible to know with this type of thing. TW Although I work for HP, the views and opinions I post here are my own. |
12-14-2016, 06:51 PM
(12-14-2016 04:14 PM)Tim Wessman Wrote: ... There are built in limits that cause problems for some people when using FTP transactions...Please, Tim, can you be more specific? I use ftp on daily basis (with total commander) and never encountered any problem even with huge files (~GB). [Sorry for offtopic.] Prime, 15C CE |
12-14-2016, 07:12 PM
(12-14-2016 06:51 PM)chromos Wrote: Please, Tim, can you be more specific? I use ftp on daily basis (with total commander) and never encountered any problem even with huge files (~GB). Many people have had problems using the old auto-update method. The HP FTP server has a two minute connection timeout, and some other strange things they've done. The problems I refer to are in the HP FTP server config and/or the auto-updater. Because of this and the fact that FTP is blocked in many school networks, this latest version and all moving forward will exclusively use a direct HTTP connection. That should be much more reliable and less likely to be blocked. TW Although I work for HP, the views and opinions I post here are my own. |
12-14-2016, 07:54 PM
(This post was last modified: 12-14-2016 08:03 PM by chromos.)
Thank you Tim for explanation. VirtCalc already updated via link from your opening post.
[Edit] ... and thank you for wireless connection to/from my android app - possibility to upload stuff from my desktop to android app is something I missed from day one. Prime, 15C CE |
12-15-2016, 05:29 PM
RE: New Version: 2016.12.08 1.3.1.11226 [UPDATED]
(12-14-2016 04:16 PM)Tim Wessman Wrote:(12-14-2016 12:38 PM)philipsrosen Wrote: [...]where do I go to download the new connectivity kit and emulator designed for us MAC users. Hello, The mac versions are now there as well. Have fun! TW Although I work for HP, the views and opinions I post here are my own. |
12-15-2016, 06:05 PM
RE: New Version: 2016.12.08 1.3.1.11226 [UPDATED] | |||
12-15-2016, 06:24 PM
12-15-2016, 06:45 PM
(12-15-2016 06:05 PM)Tinue Wrote: The firmware itself is still missing, right? The Mac versions run fine, but they download the 20160829 firmware. As quoted in the note, there is no plan to release a firmware at this time. TW Although I work for HP, the views and opinions I post here are my own. |
