4K HP 67 Games rom attached for testing
11-19-2016, 09:46 PM
Post: #141
RE: 4K HP 67 Games rom attached for testing
Ok, it looks like it is working.
I was out of range. I think we are good to send off once I play a few more games. Hopefully Robert can play a bit to check.
11-19-2016, 10:48 PM
Post: #142
(11-19-2016 09:46 PM)Gene Wrote:  Ok, it looks like it is working.
I just added a sample game to my last post.
Maybe you want to try it and see if you can reproduce the results.
And please don't forget the FIX 2. Just to be sure. ;-)
Dieter
11-19-2016, 11:01 PM
Post: #143
FIX 2 noted and included. ty
11-20-2016, 12:47 AM (This post was last modified: 11-20-2016 01:05 AM by Gene.)
Post: #144
Urgent:
Does the AOS program have a problem? I did a XEQ AOS to initialize. Then I did 1 + 2 = and it shows 0.
 01 LBL "AOS"
 02 SF 27
 03 LBL a
 04 CF 01
 05 CF 02
 06 22
 07 CF 22
 08 0
 09 LBL 09
 10 STO IND Y
 11 DSE Y
 12 GTO 09
 13 STO 00
 14 12
 15 STO 23
 16 -1
 17 STO 24
 18 CLST
 19 RTN
 20 LBL "+"
 21 LBL A
 22 61
 23 GTO 00
 24 LBL "-"
 25 LBL B
 26 51
 27 GTO 00
 28 LBL "*"
 29 LBL C
 30 42
 31 GTO 00
 32 LBL "/"
 33 LBL D
 34 32
 35 GTO 00
 36 LBL "YX"
 37 LBL b
 38 14
 39 GTO 00
 40 LBL "NEG"
 41 LBL c
 42 23
 43 GTO 00
 44 LBL "<"
 45 LBL d
 46 5
 47 LBL 00
 48 10
 49 /
 50 STO 22
 51 INT
 52 X!=0?
 53 GTO 00
 54 FS? 01
 55 XEQ 03
 56 LBL 00
 57 RDN
 58 FS?C 22
 59 XEQ 02
 60 RCL 22
 61 INT
 62 X=0?
 63 GTO 00
 64 LBL 07
 65 RCL 24
 66 X<0?
 67 GTO 00
 68 RCL IND 24
 69 FRC
 70 RCL 22
 71 FRC
 72 X>Y?
 73 GTO 00
 74 RCL IND 24
 75 INT
 76 X=0?
 77 GTO 00
 78 XEQ 01
 79 GTO 07
 80 LBL 00
 81 ISG 24
 82 ENTER
 83 RCL 24
 84 13
 85 X<=Y?
 86 ASIN
 87 RCL 22
 88 STO IND 24
 89 RCL IND 23
 90 CF 01
 91 GTO 99
 92 LBL ">"
 93 LBL e
 94 1
 95 STO 22
 96 X<>Y
 97 FS?C 22
 98 XEQ 02
 99 RCL 24
100 X<0?
101 SQRT
102 RCL IND 24
103 INT
104 X=0?
105 GTO 08
106 XEQ 01
107 GTO e
108 LBL 08
109 DSE 24
110 ENTER
111 RCL IND 23
112 SF 01
113 GTO 99
114 LBL E
115 LBL "="
116 1
117 STO 22
118 X<>Y
119 FS?C 22
120 XEQ 02
121 RCL 24
122 X<0?
123 GTO 00
124 RCL IND 24
125 XEQ 01
126 GTO E
127 LBL 00
128 RCL IND 23
129 XEQ a
130 RDN
131 RDN
132 SF 22
133 GTO 99
134 LBL 02
135 ISG 23
136 ENTER
137 21
138 RCL 23
139 -
140 X<0?
141 SQRT
142 RDN
143 STO IND 23
144 RCL 22
145 INT
146 X!=0?
147 RTN
148 LBL 03
149 ISG 24
150 ENTER
151 4.2
152 STO IND 24
153 RDN
154 RTN
155 LBL 01
156 RCL IND 23
157 DSE 23
158 RCL IND 23
159 X<>Y
160 XEQ IND Z
161 FS?C 02
162 ISG 23
163 ENTER
164 RCL 23
165 13
166 -
167 X<0?
168 SQRT
169 X<>Y
170 STO IND 23
171 DSE 24
172 RTN
173 RTN
174 LBL 01
175 Y^X
176 RTN
177 LBL 02
178 CHS
179 LBL 00
180 SF 02
181 RTN
182 LBL 03
183 /
184 RTN
185 LBL 04
186 *
187 RTN
188 LBL 05
189 CHS
190 LBL 06
191 +
192 LBL 99
193 RTN
194 SF 22
195 END
Link to AOS raw file: AOS raw file
The code should have the fix for this NOP: NOP
Original write-up from PPC Journal: AOS PPC Journal article
Gene: I think it has a problem. :-(
11-20-2016, 02:31 AM
Post: #145
Until we figure out if there is a problem in the AOS, this is the version that will go in. It gives answers instead of zeroes. :-)
AOS into .rom
11-20-2016, 05:11 PM (This post was last modified: 11-20-2016 05:48 PM by Dieter.)
Post: #146
(11-20-2016 02:31 AM)Gene Wrote:  Until we figure out if there is a problem in the AOS, this is the version that will go in. It gives answers instead of zeroes. :-)
AOS into .rom
Yes, there is a problem that I fixed in the last version I got here – but obviously the wrong one went into the zip file I posted.
The problem is in the Equals-routine (E) which finally calls the clear-all routine (XEQ a) at a point where the final result is in X. Due to the CLST in the clear-routine this value is lost. So your program works correctly, it just clears its result right before returning it. #-)
The attachment includes two versions: AOS_3 uses CLRG and thus clears all the 41's data registers. Here the final result is saved in Z and finally recalled by two RDNs (same as the original progam). AOS_3a uses a CLRGX loop that clears only R00...R22 and saves the result in LastX so that it can be finally recalled from there after the clearing is done. Both versions should work, both have a specific advantage: AOS_3 is faster, but clears all data registers, while AOS_3a clears only the required ones but takes 2-3 seconds longer for each "AOS" and "=" call due to the clear loop. If a complete CLRG is fine for you, use AOS_3.
Edit: I wonder if this CLRG is required at all. After the stack pointers are reset everything should work without setting all registers to zero. Gene, could you try this by loading AOS_3 and removing the initial CLRG? I have filled R00...R22 with random numbers and the program seems to work fine without clearing the registers.
Dieter
Attached File(s)
.zip  AOS_3.zip (Size: 2.62 KB / Downloads: 3)
11-20-2016, 05:20 PM (This post was last modified: 11-21-2016 07:42 AM by Dieter.)
Post: #147
(11-20-2016 12:47 AM)Gene Wrote:  Does the AOS program have a problem? I did a XEQ AOS to initialize. Then I did 1 + 2 = and it shows 0.
127 LBL 00
128 RCL IND 23
129 XEQ a
130 RDN
131 RDN
132 SF 22
133 GTO 99
Here is/was the problem: The final result is recalled by RCL IND 23 and then the whole operation stack is cleared (XEQ a). Here the result is lost due to the CLST (and four other values filling the stack) in that routine. Two fixed versions are attached to my previous post.
(11-20-2016 12:47 AM)Gene Wrote:  The code should have the fix for this NOP: NOP
Excuse me, but what is this "NOP" supposed to mean? You have used this term in a few posts and it seems to mean something like a bug report. Here I expected some way of doing a NOP = "no operation" on a '41. #-)
Of course this fix is and was included in AOS and AOS_3/3a.
Dieter
11-20-2016, 07:12 PM (This post was last modified: 11-20-2016 07:13 PM by Dieter.)
Post: #148
I see there is already one download of the fixed version 3/3a, and I guess I know who did it. ;-)
Anyway, here is the AOS version 4 which I am currently testing. It has no CLRG or another clearing routine, and it recalls the final result after an "=" operation directly from R13. Also note the SF22 instead of CF22 on startup which allows starting with an operator key (and x=0). Maybe you can try this one as well.
Dieter
Attached File(s)
.zip  AOS_4.zip (Size: 1.29 KB / Downloads: 2)
11-20-2016, 07:41 PM
Post: #149
(11-20-2016 05:20 PM)Dieter Wrote:  Excuse me, but what is this "NOP" supposed to mean? You have used this term in a few posts and it seems to mean something like a bug report. Here I expected some way of doing a NOP = "no operation" on a '41. #-)
Dieter
Gene: NOP was a column heading for corrections in the PPC Journal for many years. It might be article corrections, programming errors, etc.
Here's a link to a two page illustration of the Journal cover page and the page showing the NOP column: PPC V5N4 NOP
11-20-2016, 07:55 PM
Post: #150
AOS_3 is the one going into the rom.
I played with AOS4, but I think it has a bit more tweaking to do. Great idea, but I need to get the files to Angel and AOS3 seems to work fine.
AOS4 had a problem with this:
( 1 + 2 ) * ( 2 + 3 ) =
It showed a 0 in the middle of the calculation and gave a 0.
AOS3 is a great program! :-)
11-20-2016, 08:02 PM
Post: #151
Link to PDF of all program listings in the rom: PDF
Link to .zip of all .raw files in the rom: .zip of .raw
The .zip file includes a space "SumDigits.raw" file which is rom filler if there is enough space. I don't expect there to be enough room, so it will be carried over to rom2. :-) If it is included, it should be XROM 23,27 to avoid changing the hard coded XROM instructions we put in to call the Seed and RN routines.
11-20-2016, 08:07 PM
Post: #152
(11-20-2016 07:55 PM)Gene Wrote:  AOS4 had a problem with this:
Hmm... will check this.
(11-20-2016 07:55 PM)Gene Wrote:  AOS3 is a great program! :-)
OK then. But please also try it without the CLRG at the beginning. It should work just as well without losing all data registers.
Dieter
11-20-2016, 08:14 PM
Post: #153
(11-20-2016 07:41 PM)Gene Wrote:  Gene: NOP was a column heading for corrections in the PPC Journal for many years. It might be article corrections, programming errors, etc.
Fine – but what does it stand for? I didn't find an explanation on page 3 of V5N4 you posted. Is it an acronym? An abbreviation? Or does it simply refer to the NOP instruction?
Dieter
11-20-2016, 08:38 PM
Post: #154
CLRG is removed from the AOS program.
I think NOP does refer to the No OPeration instruction because errors in an article didn't do anything or errors in a program were incorrect. I am not sure of the original derivation, but it has been around in HP calculator circles for ages.
11-21-2016, 01:22 AM
Post: #155
Gene & Dieter,
Are you feeling like HP Quality/Test Engineers testing about-to-be-released calculator software back in the day? Impressive amount of testing and updates happening at a fast pace!
11-21-2016, 03:44 AM (This post was last modified: 11-21-2016 03:52 AM by Gene.)
Post: #156
No, because they did a much better job at this than we are doing. :-)
And Robert and Dieter are the coders here.
11-21-2016, 08:53 PM (This post was last modified: 11-21-2016 10:10 PM by Dieter.)
Post: #157
(11-19-2016 07:14 PM)Dieter Wrote:  (ST program)
I cannot say anything for sure, but the attached version (less than 30 minutes old) seems to run OK. It even does some things right that the original 67 program (and its documentation) did not.
I just saw that one of the data registers can be saved since R07 only holds the constant 25, which is the sensor range. This value is used only once, and another time half of this to define the phaser reach (so that's 12,5 here).
So I replaced R11 with R07 and inserted the two constants directly into the code: the sensor range still is 25 (line 53), the max. allowed Klingon distance for a phaser attack was rounded up to 15 (line 162, saves two bytes compared to 12,5 ;-)).
If you want to update the ST program – although it is not strictly required –, here is version 3a.
Edit: There is also an improved version of the SD program. Requires 96 bytes and needs two registers less than the original version. Also the output looks cleaner now since I added the one or other CF 29. ;-)
Dieter
Attached File(s)
.zip  ST3a.zip (Size: 1.83 KB / Downloads: 5)
11-22-2016, 02:36 AM
Post: #158
Gene,
Tried to send you a PM and it said you had reached your private message quota. Sad
11-22-2016, 02:56 AM
Post: #159
fix now. :-)
11-22-2016, 02:58 AM
Post: #160
(11-21-2016 08:53 PM)Dieter Wrote:  Edit: There is also an improved version of the SD program. Requires 96 bytes and needs two registers less than the original version. Also the output looks cleaner now since I added the one or other CF 29. ;-)
Dieter
Gene: Post it! That's the filler program for the .rom and if it takes less room it might make it.
