HP program forms
11-23-2015, 10:57 PM (This post was last modified: 11-25-2015 12:07 PM by PedroLeiva.)
Post: #41
RE: HP program forms
To all participants: I would like to contribute sending original forms for HP 25 and my own for HP 35s. For HP 25 two versions, English and Spanish. I hope they will serve some users. Pedro
Attached File(s)
.zip  HP 25 and 35s Program Forms.zip (Size: 977.01 KB / Downloads: 101)
11-24-2015, 06:53 AM
Post: #42
Very helpfull
Thank's for sharing
Gérard.
11-24-2015, 02:10 PM
Post: #43
(12-14-2014 10:35 PM)Sylvain Cote Wrote:
(12-14-2014 09:24 PM)Dieter Wrote:  So I would like to ask which program forms have been available by HP or other sources. For instance, has there been a version for the Spices? And maybe somewhere there is a source for PDF forms ?-)
Hello Dieter,
You will find here, program forms for the HP-35, 55, 25, 65, 67 and 41.
Best regards,
Sylvain
All I get is a 404 error
Tom L
Tom L
Cui bono?
11-24-2015, 03:36 PM
Post: #44
(11-24-2015 02:10 PM)toml_12953 Wrote:  All I get is a 404 error
Tom L
My fault, I moved the files and did not update the links.
I will correct them and post the new links when it's done.
Sorry about that.
Best regards,
Sylvain
11-24-2015, 04:11 PM
Post: #45
(11-23-2015 10:57 PM)PedroLeiva Wrote:  To all participants: I would like to contribute sending original forms for HP 25 and my own for HP 35s. For HP 25 two versions, english and Spanish. I hope they will serve some users. Pedro
35s Form is quite nice and complete; I don't think I've seen 35S forms before. Thanks for the work to build it and share it here.
11-25-2015, 01:50 PM (This post was last modified: 11-25-2015 01:52 PM by Sylvain Cote.)
Post: #46
I have updated some of the links from the original posts and here they are grouped together.
HP-35, 55, 25, 65, 67 and 41 Forms
HP-35/45 Key Sequence Form & HP-55/25/65/67 Program Form
HP-65/67/97/41C Program Submittal for Users Library
HP-35 Key Sequence Empty form
HP-35 Key Sequence Filled form (file need to be updated, need to remove the filigrane)
I have created a hpmuseum folder in my dropbox public account for file safekeeping.
In the coming days/weeks, I will move all the files referenced in this site to this folder and update all the links of my posts accordingly.
I have tested the above links and they works for me.
If you have any issue, please let me known.
Best regards,
Sylvain
11-28-2015, 09:44 AM
Post: #47
Hi Sylvain,
Run pretty well now for me.
Thank's
Gérard.
05-17-2016, 11:11 PM
Post: #48
Here some more HP 67/97 & 41 Program Forms, compile from: http://saundby.com/electronics/CodingForms/
I hope they have not already been uploaded, Pedro
Attached File(s)
.pdf  HP 67_97 - Program Forms.pdf (Size: 1.4 MB / Downloads: 57)
06-14-2018, 10:19 PM
Post: #49
Well, well, well... I might be a little late to the party, but these just made my day. Thank you!
06-14-2018, 10:21 PM
Post: #50
(11-25-2015 01:50 PM)Sylvain Cote Wrote:  I have updated some of the links from the original posts and here they are grouped together.
Best regards,
Sylvain
As you probably know, at least some of these links are dead. I think it is worth preserving this material and would greatly appreciate it if you would update the links so I can catch these documents.
Thanks!
06-14-2018, 11:54 PM (This post was last modified: 06-15-2018 12:05 AM by Sylvain Cote.)
Post: #51
(06-14-2018 10:21 PM)drdbthompson Wrote:  As you probably know, at least some of these links are dead.
You should be thanking DropBox who has changed their file sharing policies. Sad
Here some of them ...
Key Sequence Forms Key Sequence Forms with Data Entry Program Forms Contributor's Guide
Sylvain
edit: add Key Sequence Forms with Data Entry section
06-15-2018, 11:43 PM
Post: #52
(06-14-2018 11:54 PM)Sylvain Cote Wrote:  You should be thanking DropBox who has changed their file sharing policies. Sad
Oh yes, I'm familiar with DropBox's penchant for changing things around. I wasn't too surprised, given the date (links do change).
Thanks again, for reposting these.
Best...
03-22-2021, 05:38 PM
Post: #53
I have started a Google Sheet accessible by everyone containing two tabs (currently). A Program Listing and Registers, Status, Flags, and Assignments forms. Please copy, use, and comment so I may improve these for use by everyone.
Forum Post
Google Sheet
HP48GX user learning the HP42s and DM42.
03-23-2021, 01:07 AM
Post: #54
To make these REALLY useful, we need a custom font for the HP keys (although I’m not sure how to make using such a font easy!). I do have an old copy of Fontographer and hardware to run it…).-kby
03-23-2021, 01:21 AM
Post: #55
How hard can it be to make a font? (Famous last words). I may look into trying this though I have no real idea what this entails.
03-23-2021, 01:46 AM
Post: #56
(03-23-2021 01:21 AM)DM48 Wrote:  How hard can it be to make a font? (Famous last words). I may look into trying this though I have no real idea what this entails.
OMG, how many times I have said that, you may be in for some surprises.
Do not forget that you have a wide audience that use Windows, macOS or Linux machines and that the font must works on all of them.
Also, because macOS UI rendering is based on PDF, font requirements are very stringent and not that easy to satisfy.
But do not let these little things stop you, go ahead and make a great HP keys font! Smile
03-23-2021, 01:49 AM
Post: #57
I’m a gluten for punishment. Does anyone have an example of all the characters used and would need to be included in the font?
03-23-2021, 02:56 AM
Post: #58
You made me doing some research on font creation programs for macOS and I found Glyphs.
This Austria made application seems to be THE one to use to create OpenType fonts (OTF, TTF, etc) the easy way.
I do not have time right now, but I will definitively try it in the near future.
03-23-2021, 10:51 AM
Post: #59
I’m on a Mac, too. ?
