newRPL third demo released
08-30-2014, 07:26 PM (This post was last modified: 08-30-2014 07:27 PM by Massimo Gnerucci.)
RE: newRPL third demo released
(08-30-2014 05:46 PM)Sylvain Cote Wrote:
(08-29-2014 06:54 AM)Massimo Gnerucci Wrote:  Right. Or, wait a little for Win 9. Smile
Given Microsoft track record since Windows XP, I will let others do their beta/experiment testing. ;-)
Well, given past track: XP SP3 was OK, Vista... well, uhm... NO!, Seven is really good, 8/8.1 are questionable, 9 should be a masterpiece! Smile
(08-30-2014 05:46 PM)Sylvain Cote Wrote:  For the Win 32 vs 64 bits ...
I bought the 32 bits versions for the VM's because it was enough for me.
In retrospect I should had bought the licenses for 64 bits version.
Now, this will be corrected very soon with a 64 bits license.
I believe you can use the very same license key for 32/64 bit versions.
09-01-2014, 12:13 AM
(08-29-2014 06:24 AM)Ailurus Wrote:
(08-29-2014 02:25 AM)Sylvain Cote Wrote:  All my systems run's OSX, Linux or BSD's and I only have two licenses of Windows 7 Pro 32 bits installed in my VM's engines (Parallels/VMware/VirtualBox).
I use Linux as well and I the newRPL demo runs fine on Wine.
Yes! The only reason why we did not release the demos for all the different operating systems, is because the demo is a single console application with no dependencies other than the standard C library. This is a piece of cake for Wine, which runs it well on all known OS's where Wine was ported.
Claudio
09-03-2014, 09:50 PM
(08-30-2014 11:01 AM)Claudio L. Wrote:  I have a few objections to your idea:
Snip.
No worries - just didn't want you to be saying "I wish you'd told me sooner!" if you found out later, if you see what I mean. :-)
09-08-2014, 05:32 PM
(09-03-2014 09:50 PM)BruceH Wrote:  No worries - just didn't want you to be saying "I wish you'd told me sooner!" if you found out later, if you see what I mean. :-)
Ideas are always welcome, even if it was already explored and discarded, it is still a good idea.
