HP 42S Version Speed Variation
06-09-2014, 02:56 PM
RE: HP 42S Version Speed Variation
(06-09-2014 02:12 PM)rprosperi Wrote:  Thomas - Is there a way to create these individual post# links automagically, or only crafting them by hand (insert thread link then edit to add post#)? Quite useful and elegant way to save space in complex replies.
You can right-click the number of the post in the top right corner,
choose [Copy Link Location] in the context-menu
and then create a link in the toolbar [Insert hyperlink]:
[Image: toolbar.gif]
I can't reference only this icon but it's the earth and the chain.
You can even add a highlight url-parameter: #19.
PS: In the old forum you had to search for the id of a post in the source in order to directly link to a certain post.
06-09-2014, 02:58 PM
10 points for pointing to this feature. Smile
-10 points for tearing even that little sub-thread to shreds by forgetting to apply that theoretical knowledge. Confused
d:-I
06-09-2014, 03:00 PM
(06-09-2014 02:00 PM)Gerald H Wrote:
(06-09-2014 01:54 PM)J-F Garnier Wrote:  Can you make sure if by chance one of your machine is in PON (Printer On) mode and this other one in POFF?
Both with same flag settings & printing is off.
Interesting.
To answer your initial question: no, such a variation between versions is not expected/common.
I checked with a simple test program on my A and C machines and got no significant differences, my C machine is even about 5-10% slower than my A, so it doesn't depend on the software version.
Maybe something is wrong in one of your machine regarding system clock, even if the self-test reports 1MHz in both cases.
If you try to do a BEEP on both machines, can you hear a significant higher pitch on one?
For your reference, here is my test program:
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
Starting with a stack filled with 1, I get about 520 on my A machine and 490 on my C machine in 10 seconds.
06-09-2014, 03:04 PM
Thomas, now you get -15 points for reasons mentioned here.
d:-(
06-09-2014, 03:09 PM
Again,
10 points for pointing to that,
but -10 points for lack of application. Compare there.
Shall I quote Albert E. next?
d:-(
06-09-2014, 04:02 PM
(06-09-2014 03:00 PM)J-F Garnier Wrote:
(06-09-2014 02:00 PM)Gerald H Wrote:  Both with same flag settings & printing is off.
Interesting.
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
Quite amazing - this correspondent actually says something relevant to the topic!
06-09-2014, 04:42 PM
(06-09-2014 03:09 PM)walter b Wrote:  d:-(
Gähn
06-09-2014, 04:55 PM
Interesting.
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
I've now recovered my composure.
If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother.
A similar request on anyone with version A & C HP 42Ss.
06-09-2014, 05:04 PM
(06-09-2014 04:55 PM)Gerald H Wrote:  If you could enter the progs under post # 13 & time them? It's a lot to ask so no offence if you shouldn't bother.
Well, no I won't key in (twice) these rather long programs.
But if you can do on your side my simple test and the BEEP check I mentioned, it could give us a clue.
J-F
(and don't bother about the repetitive OT messages :-)
06-09-2014, 05:15 PM
To post # 29:
Beeps sound similar.
Your short test prog, & similar short loops, show the A version as marginally faster, but this would in no way account for the difference in timing for the factorization in post # 13.
06-09-2014, 05:23 PM (This post was last modified: 06-09-2014 05:23 PM by J-F Garnier.)
(06-09-2014 05:15 PM)Gerald H Wrote:  To post # 29:
Your short test prog, & similar short loops, show the A version as marginally faster...
OK. So we have similar machines (A slightly faster than C). And you have a program that runs faster on one machine. Nice mystery to solve.
And please use the Quote feature rather than a reference to a post in writing... thanks!
J-F
06-09-2014, 06:02 PM
(06-09-2014 03:00 PM)J-F Garnier Wrote:  For your reference, here is my test program:
LBL "X"
"RUN"
AVIEW
LBL 01
GTO 01
I tried your test program with my Version C units. I consistently get between 510 and 530. Variation is probably due to my inability to press R/S exactly at the same moment on each run.
Bill
06-09-2014, 06:39 PM
(06-09-2014 04:42 PM)Thomas Klemm Wrote:  Gähn
Oooh, that link shows exhausted poor little Thomas passed/past his limits. Don't overstress again. Get well soon!
d;-)
06-09-2014, 06:42 PM
Okay, I have entered your program on a Version C machine. I double & triple checked the code enter to make sure it matches your posted listing. I have printed it out and then checked the printout line by line with your listing. So I'm pretty sure it is entered correctly. Unfortunately, it does not seem to end - I've let it run for over 30 minutes with so solution.
Maybe I'm not initializing the program correctly.
I do the following:
enter 11,111,111,111 into the X register.
enter "seed"
(11,111,111,111 is still in the X register
I then do XEQ "POBR"
It then runs, but doesn't seem to end.
Am I'm doing something wrong? Is there something I should initialize or do?
Bill
06-09-2014, 06:52 PM
Usually, you won't need a post# for anything. Just use the link at the # top right to refer e.g. to this post. Or use <Quote>, delete almost everything, and the reader can still click on the little right green arrow. Want more?
d:-)
06-09-2014, 07:45 PM
(06-09-2014 05:23 PM)J-F Garnier Wrote:  Nice mystery to solve.
I was curious and entered your program in the Emu42 emulator and ran it using either ROM A and C. In this way, I was sure to have exactly the same operating conditions. No significant difference. What you are observing is not caused by the software version.
One question: in you first post, you reported that a program of yours was running slower on version A than on version C (+20% running time). Then you reported than your posted program POBR was slower on version C than on version A (now +40% running time). Is that correct?
J-F
06-10-2014, 05:23 AM
J-F
Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s.
I can hardly believe that I wrote that original error.
06-10-2014, 05:37 AM (This post was last modified: 06-10-2014 05:38 AM by Gerald H.)
I do the following:
enter "seed"
Bill
I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations.
I believe post # 36 indicates that the posted programmes are written correctly.
Please check your coding again, as errors do occur - see my previous post & the initial posting on this matter.
06-10-2014, 07:34 AM
(06-10-2014 05:23 AM)Gerald H Wrote:  Very sorry my first post is botched - version A was faster & consistently so. A took 200s & C 280s.
Thanks for the confirmation.
And the running time difference is not +20% as I wrote but +40%.
06-11-2014, 07:37 AM
(06-10-2014 05:37 AM)Gerald H Wrote:  I have checked against the programmes as stored in my HP 42S & the coding is identical - my calculators produce correct factorizations.
Gerald,
For the sake of completeness, I run your programs on my physical A and C machines.
I got:
version A machine: 414s
version C machine: 432s
consistent with the observation that version A is slightly faster (+5%).
I assume that there is something different in the implementation of your programs in your C machine.
Can you please check again? - Errors do occur :-)
Only you can do it since you are the only one to get such a speed difference (40%).
Please share your findings, I'm now curious...
J-F
