Challenge: Generate 24 in the X register / display
09-07-2020, 01:26 PM
RE: Challenge: Generate 24 in the X register / display
Sometimes, it feels like there are more lawyers in here than calculator fans...
09-07-2020, 02:30 PM
(09-07-2020 01:26 PM)rprosperi Wrote:  Sometimes, it feels like there are more lawyers in here than calculator fans...
Math fans, scientists and engineers, all of them tend to value precision, exactness and accuracy and abhor ambiguity. Lawyers, not so much.
Regards.
V.
09-07-2020, 02:36 PM
On a 41c used 3 and 6 keystrokes.
09-07-2020, 02:42 PM
6 keystrokes on HP 48.
Still waiting for Namir's no-key 41 solution Smile
It ain't OVER 'till it's 2 PICK
09-07-2020, 03:02 PM
HP67... remember, six keys for a solution using which number from 0 - 9 ?
There are 10 scenarios to be solved here. What is a solution using the number 1 three and exactly three times? Same for 0. Same for 7, etc.
I suspect Namir's solution is using no digits at all. That's fine, but does not remove the scenarios above... :-)
09-07-2020, 03:34 PM
50g no digits, 3 steps
09-07-2020, 06:39 PM
(09-07-2020 03:02 PM)Gene Wrote:  HP67... remember, six keys for a solution using which number from 0 - 9 ?
Oh well I should have known. Any time I think I understand a problem in math of any kind it means I didn't understand it Sad
09-07-2020, 09:01 PM
My no digits solution is three steps:
01 pi
02 e^x
03 CEIL
Without CEIL, it's four steps (on a 41):
01 pi
02 e^x
03 INT
04 ISG ST X
This provides a limit on solutions because the digits can be entered first and ignored:
02 0
03 0
04 pi
05 e^x
06 CEIL
I.e. there is a digit independent way of getting the result in six bytes/steps assuming all the used functionality is available on the device in question. Okay, pi isn't permitted since it is a constant but that leads onto:
For digits 1 - 9, there is an eight step solution.
Assume the digit is d:
01 d
02 ENTER
03 d
04 +
05 d
06 /
07 x^2
08 x!
Since we're aiming for the fewest steps, having this limit sets a bar -- not necessarily a very low bar but a bar. This doesn't mean that longer solutions aren't interesting. There is also an eight step solution for the digit 0.
On the other end of the scale, we must use each digit thrice and doing so cannot get the answer of 24. Therefore, the minimal program must be 4 or more steps/bytes. I suspect it has to be more than 4 in all cases (but no doubt will be proven wrong).
Embargo - lifted.
For the 41/42 and select other RPN models.
5
ENTER
ENTER
DSE X
5 steps , 8 bytes
16 bytes with 1-char global label and an END
09-07-2020, 09:20 PM (This post was last modified: 09-07-2020 09:20 PM by Sylvain Cote.)
(09-07-2020 09:01 PM)rprosperi Wrote:  Embargo - lifted.
Actually not yet, it is 5PM CENTRAL TIME USA Wink
09-07-2020, 09:47 PM (This post was last modified: 09-07-2020 09:47 PM by rprosperi.)
(09-07-2020 09:20 PM)Sylvain Cote Wrote:  Actually not yet, it is 5PM CENTRAL TIME USA Wink
Dang. Gene, when are you going to move to the East coast?
Anyhow, I'll be on a family monthly zoom then, plus I suspect this is not such an insightful solution that it will ruin anyone's day...
09-07-2020, 10:51 PM (This post was last modified: 09-07-2020 11:21 PM by Hlib.)
HP-50g, RPN mode. To ensure the least number of keystrokes I`ve made a custom
soft menu for four functions: DUP, SQ(x^2), !(factorial), NOT.
{ DUP SQ ! NOT } `CST` STO [LS] [MODE] Thus number of steps in the solution match the keystrokes.
The universal chain N DUP + N ÷ SQ ! (seven clicks) comes up to every number except zero.
But in some particular cases, this can be made more shorter.
#9 24=√9×9–√9 || 9 √ 9 × 9 √ – || 7 steps(clicks)
#8 24=8+8+8 || 8 DUP + 8 + || 5 steps(clicks)
#7 24=(((7+7)÷7)^2)! || 7 DUP + 7 ÷ SQ ! || 7
#6 24=6^2–6–6 || 6 SQ 6 – 6 – || 6
#5 24=5^2–5÷5 || 5 SQ 5 DUP ÷ – || 6
#4 24=4^2+4+4 || 4 SQ 4 + 4 + || 6
#3 24=3^3–3 || 3 DUP y^x 3 – || 5
#2 24=(((2+2)÷2)^2)! || 2 DUP + 2 ÷ SQ ! || 7
#1 24=(((1+1)÷1)^2)! || 1 DUP + 1 ÷ SQ ! || 7
#0 24=... || 0 NOT 0 NOT + 0 NOT ÷ SQ ! || 10
09-08-2020, 12:04 AM
HP42S, 5 steps:
4.9
ENTER
ENTER
X
IP
09-08-2020, 12:18 AM (This post was last modified: 09-08-2020 12:19 AM by Fred Lusk.)
I shortened my generic DM-42 program again. Now it is 10 steps. This program takes any single-digit number sitting in the X-register (or any number, positive, negative, or zero, for that matter), makes three copies in the stack (putting the number in X into Y and Z also), then uses all three numbers to create the number 24.
01 LBL "T4"
02 ENTER
03 ENTER
04 +
05 +
06 SIGN
07 RCL+ ST X
08 RCLx ST X
09 N!
10 END
If you preload the stack with the same number in X, Y, and Z, then delete steps 02 and 03, which leaves an 8-step program.
The following program will take ANY number in the X-register and convert it to 24. It works like the previous program, but it's simpler because it only has to deal with one number.
01 LBL "TF"
02 SIGN
03 RCL+ ST X
04 RCLx ST X
05 N!
06 END
...Fred
09-08-2020, 12:33 AM
My solution for 4 is:
4 4 ENTER 4 n!
The first two 4's and the command after doing nothing.
For zero (8 steps):
0 0 COS 0 n! + x^2 n!
Pauli
09-08-2020, 02:49 AM (This post was last modified: 09-08-2020 02:51 AM by Sylvain Cote.)
My solution for value 3 is: (HP-41 → 5 operations, 7 keystrokes, no unused data is left on the stack, Z & T are preserved)
ENTER
YˆX
LastX
My solution for value 4 is: (HP-41 → 6 operations, lots of keystrokes, no unused data is left on the stack, Z & T are preserved)
FACT
LastX
LastX
My solution for value 5 is: (HP-41 → 6 operations, 8 keystrokes, no unused data is left on the stack, T is preserved)
xˆ2
LastX
ENTER
Sylvain
Edit: typos
09-08-2020, 03:01 AM
(09-08-2020 12:18 AM)Fred Lusk Wrote:  I shortened my generic DM-42 program again. ...
01 LBL "T4"
02 ENTER
03 ENTER
04 +
05 +
06 SIGN
07 RCL+ ST X
08 RCLx ST X
09 N!
10 END
Brilliant!
Here is an adapted version for the HP-41 and which also now preserve Z & T .
01 LBL "T4"
02 ENTER
03 +
04 LastX
05 +
06 SIGN
07 ST+ ST X
08 ST* ST X
09 FACT
10 END
Sylvain
09-08-2020, 04:04 AM
Using 1 only once
10^x
LASTX
STO+X
STO+Y
Using NO Digit
CLX
10^x
10^x
LASTX
STO+X
STO+Y
09-08-2020, 05:22 AM
My solution for 2 on the 42S in 6 steps :
ENTER
ENTER
RCL* ST L
09-08-2020, 10:51 AM (This post was last modified: 09-08-2020 10:57 AM by ndzied1.)
42S, digit 4, 7 steps, roundabout way. 4! 2 steps.
ENTER
ENTER
ENTER
PERM
