"Counting in their heads" - 1895 oil painting
08-12-2020, 01:50 PM (This post was last modified: 08-15-2020 07:26 PM by Albert Chan.)
RE: "Counting in their heads" - 1895 oil painting
There is also a pattern for sp (see Benoulli Number thread)
\(s_p(n) = \sum_{x=0}^{n-1}x^p = \large {n^{p+1}\over p+1} - {n^p \over 2}
+ {p\over12}(n^{p-1}) + k_{p-3}(n^{p-3}) + k_{p-5}(n^{p-5}) + \cdots \)
sp(1) = sp(0) + 0^p = sp(0) = 0
⇒ above formula does not have a constant term
⇒ when p is odd, p>1, sp(n) has factor n²
Redo previous example:
s5(n) = n^6/6 - n^5/2 + 5/12*n^4 + k2*n^2
s5(1) = 1/6 - 1/2 + 5/12 + k2 = 0
→ k2 = -1/12
→ s5(n) = (2*n^6 - 6*n^5 + 5*n^4 - n^2) / 12
T = 50^5 + 51^5 + 52^5 + ... + 150^5
   = s5(151) - s5(50)
   = 1936617185625 - 2450520625
   = 1934166665000
Update: we may use this to help mental calculation: For n ≥ 0, sp(n) = (-1)p+1 * sp(1-n)
Redo above example, using s5(151) = s5(-150), and horner's rule
b = -150
a = 50
d = b-a = -200
d2 = (b^2-a^2)/d = b+a      = -100
d3 = (b^3-a^3)/d = d2*b+a^2 =  17500
d4 = (b^4-a^4)/d = d3*b+a^3 = -2500000
d5 = (b^5-a^5)/d = d4*b+a^4 =  381250000
d6 = (b^6-a^6)/d = d5*b+a^5 = -56875000000
T = s5(b) - s5(a) = (2*d6 - 6*d5 + 5*d4 - d2)*d / 12 = 1934166665000
Update: we are better off using Euler-Maclaurin formula, which work for any f(x)
Note: coefficients were B(1)/1! = -1/2, B(2)/2! = 1/12, B(4)/4! = -1/720, ...
Σf = Δ-1 f = (eD-1)-1 f = (D-1 - 1/2 + D/12 - D³/720 + ...) f
Example, with f = x^5
s5 = ∫f dx - f/2 + f'/12 - f'''/720 + ... = x^6/6 - x^5/2 + (5x^4)/12 - (60x^2)/720
08-13-2020, 03:50 PM
There is also the Faulhaber polynomials, with sum-of-powers formula as function of triangular number.
Let \(\large t = \binom{x}{2},\;{s_{2m} \over (2x-1)t}\) and \(\large {s_{2m+1} \over t^2}\) are polynomial of t, degree m-1
Example, get s4(x) and s5(x) in terms of t, using divided difference.
Note: we start from x=2, instead of 0, to avoid divide-by-zero issue.
x   s4(x)    | t    s4/(2xt-t)  divided-diff
2   0+1^4=1  | 1    1/3
3   1+2^4=17 | 3    17/15       (17/15-1/3)/(3-1) = 2/5
--> s4(x) = (2xt-t) * (1/3 + (t-1)*2/5) = (2x-1)*(6t^2-t)/15
x   s5(x)    | t    s5/t^2      divided-diff
2   0+1^5=1  | 1    1
3   1+2^5=33 | 3    11/3        (11/3-1)/(3-1) = 4/3
--> s5(x) = t^2 * (1 + (t-1)*4/3) = (4t^3-t^2)/3
Redo previous example, using horners rule for the difference.
lua> a,b = 50, 151      -- next line replaced with t's
lua> a,b = a*(a-1)/2, b*(b-1)/2
lua> d = b-a            -- = 10100
lua> d2 = b+a           -- = (b^2-a^2)/d = 12550
lua> d3 = d2*b+a^2      -- = (b^3-a^3)/d = 143629375
lua> (4*d3 - d2)*d / 3  -- = 50^5 + 51^5 + ... + 150^5
1934166665000
08-14-2020, 02:25 PM (This post was last modified: 08-14-2020 02:29 PM by Albert Chan.)
(08-12-2020 01:32 AM)Albert Chan Wrote:  I was wrong. There seems to be a pattern to sum of powers formula after all ...
\( S_p = n c^p + \large {n^3-n \over 12} \left(
\binom{p}{2} c^{p-2} +
{3n^2-7 \over 20} \binom{p}{4} c^{p-4} +
{3n^4-18n^2+31 \over 112} \binom{p}{6} c^{p-6} +
{5n^6-55n^4+239n^2-381 \over 960} \binom{p}{8} c^{p-8} +
\cdots \right) \)
Example:
50^5 + 51^5 + 52^5 + ... + 150^5              // p=5, c=100, n=101
= 101*100^5 + 102*101*100/12 * (10*100^3 + (3*101^2-7)/20*5*100)
= 1934166665000
To extend formula for spacings = d, simply replace Sp by Sp/dp, c by c/d
Or, just check the dimensions for each term. All terms must have same units.
Example, for sum-of-squares, all terms should have unit of c²
S2 = n*c² + (n³-n)/12 *         // c/d is dimensionless, thus c, d have same unit
Example, for sum of m odd squares
1² + 3² + 5² + ... + (2m-1)²       // d=2, c = m = n
= m*m² + m*(m²-1)/12 * 2²
= m*(4m²-1)/3
= \(\binom{2m+1}{3}\)
We can confirm this from sum-of-n-squares formula
\(\begin{align}
{n(n+1)(2n+1) \over 6} &= {n(n+1)·[(n-1) + (n+2)] \over 6}\\
\binom{2n+2}{3}/4 &= \binom{n+1}{3} + \binom{n+2}{3}\\
\end{align}\)
Let n = 2m:
LHS = sum-of-m-odd-squares + sum-of-m-even-squares
\(\binom{n+2}{3}\) = 4×sum-of-m-squares = sum-of-m-even-squares
⇒ \(\binom{2m+1}{3}\) = sum-of-m-odd-squares
08-14-2020, 07:20 PM
C'mon now Albert... Is all this really 'in your head'? Seems like many whiteboards...
08-15-2020, 02:55 AM
(08-13-2020 03:50 PM)Albert Chan Wrote:  There is also the Faulhaber polynomials, with sum-of-powers formula as function of triangular number.
1934166665000
Indeed there is more than a way to skin a cat (if we still may say that these days).
There is also Hurwitz zeta function.
For example,
ζ(-5, 50) - ζ(-5, 151) = 1934166665000
But what calculator has that built-in?
08-15-2020, 05:04 AM
(08-15-2020 02:55 AM)Gerson W. Barbosa Wrote:  There is also Hurwitz zeta function.
For example,
Anybody know which zeta function Prime's CAS uses when Zeta() is given two arguments? Prime evaluates Zeta(2,2) as 1.9892802343, but Wolfram Alpha returns pi^2/6-1 (approx 0.644934) for HurwitzZeta(2,2). Prime's Help screen for Zeta() does not mention a two-argument syntax, so it's a mystery to me.
<0|ɸ|0>
-Joe-
08-15-2020, 07:20 AM
(08-15-2020 05:04 AM)Joe Horn Wrote:  Anybody know which zeta function Prime's CAS uses when Zeta() is given two arguments?
That’s the derivative of Zeta function. The second argument is the derivative order. In W|A:
(d^2 ζ(x))/(dx^2), x = 2
