Saturn Emulator
11-09-2019, 07:21 PM
(This post was last modified: 11-11-2019 10:22 PM by sunhp.)
Saturn Emulator
Just wondering if Prime could run SATURN CPU emulator just like HP50G does ?
Source : https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=124202 |
11-12-2019, 06:08 AM
RE: Saturn Emulator
The HW is definitely powerfull enough to do so... HPP is most likely too slow to do it at a speed close to what is needed :-( especially as it does not have anything that can simulate the memory while being fast... Bit it would be interesting to think about what 4 or 5 instructions would be useful to speed things up significantly... and make it possible... the 50G has around 2MB of ram space, which would easely fit in Prime (G2), so it should be more or less possible. The main issue as far as I can tell is memory access (nibble read/write access) and nibble wise manipulations (in HEW and DCB)... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-12-2019, 08:07 PM
RE: Saturn Emulator
(11-12-2019 06:08 AM)cyrille de brébisson Wrote: Hello, What if you waste memory by storing each nibble into a byte? |
11-13-2019, 06:09 AM
RE: Saturn Emulator
hello,
That helps the read/write, BUT, it means that each nibble has to be handled individually instead of being able to be handled as packs. For example, if you work with "packed" nibbles, you can describe 1 register as 1 64 bit integer (and use masks), so any saturn binary operation can be done in basically 1 PPL line as in: A:= (A and not mask) OR ((A and mask) + (B and mask)); regardless of the field... Working nibble by nibbles means loops, which are much less efficient... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-13-2019, 06:40 AM
(This post was last modified: 11-13-2019 09:36 AM by CyberAngel.)
RE: Saturn Emulator
(11-13-2019 06:09 AM)cyrille de brébisson Wrote: hello,I C... masks are easy... thus: It looks like every odd nibble read (ARM read is in bytes) has to be in a buffer in order to combine it with "upper" 4 bits of the unaltered Saturn information producing an even number of nibbles (= a byte). Every odd nibble write needs first a read into a buffer before the write to yet again combine the just read upper part of the byte with the 4 bits of that odd nibble to get a full byte to be written. Was that an explanation that others in this group can understand? Is that how you did it with the HP 49/50 ARM version, Cyrille? |
11-13-2019, 09:31 AM
(This post was last modified: 11-13-2019 09:35 AM by sunhp.)
RE: Saturn Emulator
Thank you Cyrille for the informations, this is very interesting I like it !
Long life HP calcs ! Julien |
11-14-2019, 06:51 AM
RE: Saturn Emulator
Working with packed nibbles is faster because masks and the like help a lot with all the ASM operations... speeding them up tremendously... It does make memory access more difficult, BUT in real life, I discovered (stats) that only a relatively small % of the instructions were memory access... so it is OK to take a penalty there... One exception of course is the reading of instructions for execution, BUT this is a known linear process, so you can manage have a shifting buffer that will do rom read only every 8 nibbles or so to speed this up... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-14-2019, 10:15 AM
RE: Saturn Emulator
(11-14-2019 06:51 AM)cyrille de brébisson Wrote: Hello,So...we will soon have a HP 50G+ Emulator running on the G2 hardware? Even a small, even fee seems reasonable (10 USD? - 9 would be odd) VPN |
11-14-2019, 02:47 PM
RE: Saturn Emulator
(11-14-2019 10:15 AM)CyberAngel Wrote: So...we will soon have a HP 50G+ Emulator running on the G2 hardware? Odd, yes, but it wouldn't be Prime... There are only 10 types of people in this world. Those who understand binary and those who don't. |
11-14-2019, 06:57 PM
RE: Saturn Emulator
(11-14-2019 02:47 PM)grsbanks Wrote:(11-14-2019 10:15 AM)CyberAngel Wrote: So...we will soon have a HP 50G+ Emulator running on the G2 hardware? Then the price of that software should be even 2 USD since 2 is - odd enough - the only even prime. On the other hand - that software emulates HP 50g - shouldn't it cost 50 USD |
11-14-2019, 11:24 PM
RE: Saturn Emulator
(11-14-2019 02:47 PM)grsbanks Wrote:(11-14-2019 10:15 AM)CyberAngel Wrote: So...we will soon have a HP 50G+ Emulator running on the G2 hardware? Ba-dump-bump! Ouch... --Bob Prosperi |
11-15-2019, 04:41 AM
(This post was last modified: 11-15-2019 04:42 AM by Wes Loewer.)
RE: Saturn Emulator
Quote:So...we will soon have a HP 50G+ Emulator running on the G2 hardware How would the vastly different keyboards be handled? |
11-15-2019, 06:05 AM
RE: Saturn Emulator
Technically, it is feasible... especially on G2.
Doing it in native C would be best of course, but means that Tim or I have to do it as it needs to be build in rom... and we are time limited... Doing it in PPL would be much slower, but means that others can work on it. We could include some helper PPL functions to help speed things up (a little bit like what I did with the triangle/lines function used by Han's 3D graphing app)... But these functions would need to be well defined in advance... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
11-17-2019, 07:37 PM
RE: Saturn Emulator
You can look at HP prime HP41 emulator for a nut cpu emulator in PPL
This can help to start a saturn emulator, but it will be very slow. As C helper functions you need at least functions to deal with all registers ops (taking care of base and fields) You need also to have a G2 hardware working at the same speed all the time ... Case select should be also speed up a bit Olivier |
11-17-2019, 07:49 PM
RE: Saturn Emulator
(11-15-2019 06:05 AM)cyrille de brébisson Wrote: Technically, it is feasible... especially on G2. A Prime [+] with double^2 the screen resolution (and larger battery?) is easier to get than a full Saturn Emulator with the latest HP 50g Firmware. Tim will probably have the Emu ready when he is 50 ປີ. [Forget the PPL - it's way too slow] VPN |
User(s) browsing this thread:
