When ISZ/DSZ > ISG/DSE
05-23-2019, 11:51 PM
Ran across something interesting (to me at least) in an HP KeyNotes issue.
The situation was on the HP-67, the I register contained either a zero or one. Goal was to use ISZ/DSZ to switch it. Think of it as a brain-teaser:
"The X register contains either a zero or one. Flip the value without using any digit keys or X=? test conditionals."
The solution presented was...
ISZ
DSZ
DSZ
ISZ
which works. Then I started thinking. That's hard to do on the HP41 style structure.
ISG won't work here. Thoughts?
Try it on your HP67 or an emulator and help me think through how to do it this way on an HP41. No X=Y? or X=0? conditionals allowed. :-)
05-24-2019, 12:00 AM
RE: When ISZ/DSZ > ISG/DSE
SIGN
LASTX
05-24-2019, 12:44 AM
Which certainly works on X as I laid it out. Thomas is a master. :-)
What proposals for a value in a memory register?
05-24-2019, 01:08 AM
(05-24-2019 12:00 AM)Thomas Okken Wrote:  SIGN
LASTX
Awesome. And elegant!
05-24-2019, 02:59 AM
ACOS
SIN
By Andrés Rodríguez, I think.
05-24-2019, 04:10 AM (This post was last modified: 05-26-2019 03:59 AM by Paul Dale.)
On the 34S, I think the minimal real mode solution would be:
NOT
The 34S has both flavours of increment (i.e. ISG and ISZ).
Pauli
05-24-2019, 12:59 PM
Thank you Gerson for remembering this old answer from me to an old similar challenge!
Andrés C. Rodríguez (Argentina)
Please disregard idiomatic mistakes.
My posts are mostly from old memories, not from current research.
05-24-2019, 01:31 PM
(05-24-2019 12:44 AM)Gene Wrote:  What proposals for a value in a memory register?
Here is a proposal for a value in memory register 01 that keeps the stack and lastX unchanged:
X<> 01
DSE X
CHS
CHS
X<> 01
05-24-2019, 02:00 PM (This post was last modified: 05-24-2019 02:01 PM by Gerson W. Barbosa.)
CHS
ISG X
Two steps also, but Andrés Rodríguez’s solution should be still one byte shorter.
05-24-2019, 02:35 PM (This post was last modified: 05-24-2019 02:37 PM by Thomas Okken.)
(05-24-2019 02:00 PM)Gerson W. Barbosa Wrote:  CHS
ISG X
Andrés' solution looks unbeatable on size, but it is slower. Not a lot slower, to be honest, since it takes advantage of special cases in ACOS and SIN, so it really is quite brilliant. I wish I had thought of it. Smile
CHS ISG X is flawed because the ISG skips the next instruction in the 0 → 1 case...
05-24-2019, 04:02 PM
(05-24-2019 02:35 PM)Thomas Okken Wrote:  CHS ISG X is flawed because the ISG skips the next instruction in the 0 → 1 case...
Yes, I am aware of that. Anyway, the following works on both the 41 and 42:
01 LBL “W”
02 CHS
03 ISG X
04 END
0 XEQ W -> 1
XEQ W -> 0
XEQ W -> 1
and so on...
05-28-2019, 09:41 PM
Thomas, Gerson,
Your generous (and mostly undeserved) comments about [ACOS | SIN] made my day. Thank you!!
05-29-2019, 12:33 AM
(05-28-2019 09:41 PM)Andres Wrote:  Thomas, Gerson,
You are most welcome!
Besides, unto Andrés what belongs to Andrés! :-)
Here it is, exactly fourteen years ago now:
A tiny solution for the 0<>1 toggle
