Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
I think we have new champion -- by quite a margin
Prime G2 Beta 2.1.14549 using Python
#PYTHON name
from math import *
import sys
import hpprime
t=hpprime.eval("time")
c=int(sys.argv[0])
print()
print("Exponent = ",c)
print("Iterations = ", 10**c)
a=0
for i in range(1, 10**c+1):
a=a+pow((e**(sin(atan(i)))),1/3)
print("Time (sec) = ",round(hpprime.eval("time")-t,4))
print("Sum = ",a)
#end
Export sums(c)
Begin
PYTHON(name, c);
End;
From the Home screen invoke this Python program with sums(?)
where "?" question mark has to be replaced by the exponent which denotes the magnitude
- 3 for 1000
- 4 for 10 000
- 5 for 100 000
- 6 for 1 000 000
Output will be the exponent, the resulting number, the time and the sum. E.g.
3
1000
0.036 sec
1395.3462877433426
Results:
3 1 000 0.036 sec 1395.3462877433426
4 10 000 0.159 sec 13955.857904429155
5 100 000 1.425 sec 139560.9761410521
6 1 000 000 14.046 sec 1395612.158725383
I think that's quite impressive specifically when compared with the values for native PPL.
Günter
Edit: put the timing into the Python code rather than using TEVAL
Something new to me, maybe a lack of Prime knowledge.
My Prime is configured in RPN (for stack Home computations).
I tried the sum "benchmark" proposed here, then Pick (copy) the first formula to modify it in the command line, I want to run a bigger one, from a 1000 to 10000 sum.
I only added a zero behind "1000", the Editor refuses to validate the formula. Why ?
https://ibb.co/wgZJbrL
https://ibb.co/VD2Wzp6
https://ibb.co/WfpDSGv
(08-08-2021 10:59 AM)Guenter Schink Wrote: [ -> ]The HP Expander (not XP Expander) is a calculator from HP, not a mobile device. But I think it never saw the light of the markets. I've got a prototype at one of the HHCCs.
It actually was "HP Xpander".
Have a couple, from different development stages.
(08-08-2021 11:03 AM)Massimo Gnerucci Wrote: [ -> ] (08-08-2021 10:59 AM)Guenter Schink Wrote: [ -> ]The HP Expander (not XP Expander) is a calculator from HP, not a mobile device. But I think it never saw the light of the markets. I've got a prototype at one of the HHCCs.
Thanks for the correction. I could have had a closer look either to the device or the Wiki article
Günter
ThetaCalc, an RPN calculator app running on iOS which can be programmed in JavaScript, produced the following result for n = 1000000 on an iPhone 12:
HP museum benchmark (n = 1000000)
Sum = 1395612.1587253837
Time = 0.189 seconds
I don't know, however, whether the app fits into one of the given categories.
Here is the program:
function benchmark(n) {
let s = 0;
for (let i = 1; i <= n; i++) {
s += Math.pow(
Math.exp(
Math.sin(
Math.atan(i))), 1/3);
return s;
const n = 1000000;
startTimer();
let s = benchmark(n);
stopTimer();
println(`HP museum benchmark (n = ${n})`);
println(`Sum = ${s}`);
printlnElapsed();
I recently received a Sharp PC-1201 and was currious how this nice little machine would perform, here are the results :
N=10 ~25s result 13,318529402
N=100 ~285s result 138,90159786
N=1000 ~2844s result 1394,95067416
(04-22-2021 06:33 PM)Guenter Schink Wrote: [ -> ]I think we have new champion -- by quite a margin
When I copy and paste that code into the emulator, I get
Traceback (most recent call last): File "<stdin>", line 5, in <module>
ValueError: invalid syntax for integer with base 10: '10\xef\xb9\x90000'
10: '1\xef\xb9\x90000'
(08-17-2021 11:23 PM)toml_12953 Wrote: [ -> ] (04-22-2021 06:33 PM)Guenter Schink Wrote: [ -> ]I think we have new champion -- by quite a margin
I just also copied it to the virtual Prime. works flawlessly. (?)
The error actually points to line 6 "c=int(sys.argv[0])" Can't assume what's going wrong.
Günter
(08-18-2021 03:09 PM)Guenter Schink Wrote: [ -> ] (08-17-2021 11:23 PM)toml_12953 Wrote: [ -> ]When I copy and paste that code into the emulator, I get
Günter
I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop.
(08-18-2021 04:01 PM)toml_12953 Wrote: [ -> ]I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop.
o.K. I think I found the problem. It wasn't clearly explained. You have to enter the exponent rather then the number. E.g. enter 3 to get 1000 iterations. Have a look at the code and
now it should become obvious.
I chose this because "sys.argv[0]" doesn't seem to work reliably with numbers greater 999. Consequently if it works somehow, the first output is a digit with as many zeros as requested, and that output takes a while.
Günter
edit: I just realized that I can't run the program from the command line I had to go to the program catalog <SHIFT> <1> and run it fro there
(08-18-2021 06:56 PM)Guenter Schink Wrote: [ -> ] (08-18-2021 04:01 PM)toml_12953 Wrote: [ -> ]I had digit grouping set to 123,456.789. When I change it to 123456.789, I don't get an error but I get a lot of zeroes on the screen and what may be an infinite loop.
o.K. I think I found the problem. It wasn't clearly explained. You have to enter the exponent rather then the number. E.g. enter 3 to get 1000 iterations. Have a look at the code and now it should become obvious.
Günter
Oof! Es tuit mir leid! Yes, an exponent of 1000 would take a long time! Thank you for replying.
Updated up to post #233
Also the HP Xpander name and category fixed. Hopefully I didn't miss anything.
I have bought newer casio model, fx-570CW several months ago and reminded this thread. Test results below:
max = 10000
~ 581s - casio fx-570CW, 13955.8579 (sum function)
max = 1000
~ 59s - casio fx-570CW, 1395.346288 (sum function)
max = 100
~ 7s - casio fx-570CW, 139.297187 (sum function)
max = 10
~ 1s - casio fx-570CW, 13.71183502 (sum function)
fx-570CW is significantly faster than fx-570EX. Let's compare them.
1s / 2s (max = 10)
7s / 12s (max = 100)
59s / 109s (max = 1000)
581s / 1073s (max = 10000)
Tested with HP-200LX too.
max = 10000
~ 257s - HP-200LX turbo c 2.01, 13955.857904
max = 1000
~ 27s - HP-200LX turbo c 2.01, 1395.346288
max = 100
~ 4s - HP-200LX turbo c 2.01, 139.297187
max = 10
~ 2s - HP-200LX turbo c 2.01, 13.711835
#include <math.h>
main()
double i,sum;
i=1;
sum=0;
for(i=1;i<=10000;i++)
sum+=pow(exp(sin(atan(i))),1/3.);
printf("%lf\n",sum);
Σ( ³√[e^(sin(tan^-1(x)))], x=1 to 1000)
Casio fx-991CW:
Result: 1395.346288
Time: approx. 57 seconds
TI-30X Pro MathPrint (Europe):
Result: 1395.346288
Time: approx. 1 minute, 44 seconds
Once again Python on PRIME
This time using "Generator"
from math import *
from hpprime import *
Number=input("Enter number:")
Number=int(Number)
print(" {:,d}".format(Number))
t=eval('time')
Sum = sum(pow(e**(sin(atan(i))),1/3) for i in range(1,Number+1))
t=eval('time')-t
print("Sum = {:}".format(Sum),"\nTime = {:}".format(round(t,8)))
significantly faster than the previous published Python code (Top of this page). The calculation is done in this one-liner:
>>Sum = sum(pow(e**(sin(atan(i))),1/3) for i in range(1,Number+1)) <<
10,000 -> 0.101 sec 13955.8579042916
100,000 -> 1.038 sec 139560.9761411052
1,000,000 -> 10.381 sec 1395612.15872538
10,000,000 -> 103.724 sec 13956123.9815476
Günter
HP Prime G2 V.14603 Python
100.000 -> 0.84s
1.000.000 -> 8.4s
10.000.000 -> 84.1s
optimized post #238:
x=1/3
Sum = sum(exp(sin(atan(i)))**x for i in range(1,Number+1))
(01-28-2023 09:22 AM)BINUBALL Wrote: [ -> ]Tested with HP-200LX too.
Couldn't resist trying this on a modern PC...
#include <math.h>
#include <stdio.h>
void main()
double i,sum;
i=1;
sum=0;
$ gcc sum.c -o sum -lm
$ time ./sum
13955.857904
real 0m0.005s
user 0m0.005s
sys 0m0.001s
