Here's an example program included with the latest beta for a game. If you feel you can read and follow this, you shouldn't have too much trouble doing fairly basic things I think.
Where it gets tricky is trying to integrate CAS calculations in and we still have some work there to make it easier.
// This example program is a "tunnel" game.
// A game where the player guides a triangle
// in a randomly moving tunnel and needs to
// avoid hitting the sides.
// first, we place a pragma directive to indicate
// which settings we use in our program and
// avoid compilation errors if the calculator
// does not match our settings
#pragma mode( separator(.,;) integer(h32) )
// Points is an exported, global variable
// in order to allow the user to see his score
// even after the program has ended.
// Had we not put the variable as a global
// this would have not be possible
export Points= 0;
// Tunnel is the main function of the program
export Tunnel()
begin
// First, we initialize all the variables and items
// used by the program.
// Set the point counter to 0
Points:= 0;
// detect the screen width and height
local width= grobw_p(G0), height= grobh_p(G0);
// playery is the vertical position of the player on the
// screen. We initialize it at 1/2 the screen
local playery= height/2;
// space will we the width of the tunnel
// we initialize it at 1/4 of the screen height
local space= height/4;
// topy will be the location of the tunnel on the
// screen. We initialize it centered on the screen
local topy= (height-space)/2;
// G1 will be used to draw outside of the
// screen in order to reduce flicker.
// we make G1 the same size as the screen and erase it
dimgrob_p(G1, width, height, #FFFFFF);
// speed is the number of millisecond in between frames
// we start at 300ms and we slowly decrease it to make the game harder
local speed= 300;
// nextFrame will contain the time when we need to display the next
// frame. This is set to now plus the speed
local nextFrame= ticks+speed;
// nextspeedup contains the moment when we want to next increase the
// dificulty of the game by speeding it up AND reducing the tunnel size
local nextspeedup= ticks+10000;
// movespeed contains the number of pixels by which the user can move per frame
local movespeed= 5;
// positions will contain a list of topy/space pairs associated with all the tunnel
// segments visible on the screen. This will be used to test for collision
// The tunnel is generated on the right and slowly moves left
// collisions will only be detected on the left. So, we need to
// record every new right position, and keep it in memory until it becomes
// the left position and is used for collision test. This is what is saved here
// We initializes the list with the screen height as the full screen is valid at the begining.
local positions= makelist({0, height}, I, 0, width/4);
// we now get to the core of the game
// while the player is "in the tunnel" (tested by comparing the user position
// with the leftmost position in the position list
// the +15 comes from the fact that the user triangle is 15 pixels heigh
while playery>positions(1,1) and playery+15<positions(1,2) do
// Draw the new part of the tunnel. A top and bottom blue part and a middle white
rect_p(G1, width-5, 0, width-1, topy, #FF);
rect_p(G1, width-5, topy+1, width-1, topy+space, #FFFFFF);
rect_p(G1, width-5, topy+space, width-1, height-1, #FF);
// Copy the back buffer to the screen
blit(G0, G1);
// Draw the "user". A color changing triangle of height 15
triangle_p(G0, {0, playery, #FF0000}, {15, playery+8, #00FF00}, {0, playery+15, #FF0000});
// start working on the next frame
// first, shift the back buffer graphic 5 pixels to the left
blit_p(G1, 0, 0, G1, 4, 0);
// remove the first item from the position list
positions:= positions({2,size(positions)});
// add the current position at the end of the position list
positions(0):= {topy, topy+space};
// if the up key is pressed, move the player up (if possible)
if iskeydown(2) and playery>0 then playery:= playery-movespeed; end;
// if the down key is pressed, move the player down (if possible)
if iskeydown(12) and playery+15<height then playery:= playery+movespeed; end;
// randombly move the tunnel up or down (if possible)
if rand<0.5 then
if topy>0 then topy:= topy-1; end;
else
if topy+space<height then topy:= topy+1; end;
end;
// increase the user's point count
Points:= Points+1;
// get "now"
local now= ticks;
// if we need to make the game harder
if now>nextspeedup then
// calculate next time we need to make the game harder
nextspeedup:= nextspeedup+10000;
// increase the speed
speed:= speed*0.9;
// keep user speed move constant compare with normal time
movespeed:= movespeed*0.9;
// make tunnel smaller
space:= space*0.9;
end;
// wait as needed for the next frame
wait((nextFrame-now)/1000);
// calculate when the next frame needs to happen
nextFrame:= nextFrame+speed;
end;
// out of the while loop. The user has lost
// tell him how many points he has!
msgbox("You have "+Points+" Points!");
// also return the point count on the stack
return Points;
end;
