Nope, sorry.
The splash screen is hardcodded in the OS and is there during the time used by the system to load the application from Flash to RAM (around 6s)...
(03-24-2014 12:13 AM)Alberto Candel Wrote: [ -> ]Hello,
I wonder if there is a way to eliminate (or reduce display time of) the splash screen of the HP Prime.
What about replacing it with other images?
Thank you
-a
Are you talking of the splash screen you get after a reboot, or the shorter one you get every time you turn on the calculator?
About the latter, I have noticed that you can start typing numbers "blind" while the splash screen is displayed, and the numbers are correctly entered in the command line.
(03-28-2014 03:41 PM)Alberto Candel Wrote: [ -> ]Hi,
I was talking about the HP splash when turning it on. It feels it takes forever!
Hm... On my Prime, it lasts noticeably less than a second, hardly forever. Is it just a matter of personal "sensitivity" or are we seeing different things?
Maybe you are talking about the first start up after it crashes? I think that one do something different (the animation with the circle eq); or at least I hope does something rather than being a longer delay.
