(02-04-2018 12:34 PM)Geir Isene Wrote: [ -> ]I have only tested taking the programs from the printer log - bacuase I need programs from my 41 to include in modules I create - and the printer log is the easiest way to do that.
Could you please provide me a little example (raw file preferred) of a HP-41 program with synthetic strings? You can also use the "View" function of the drive directory listing to obtain the FOCAL code of a HP-41 progam file.
hi,
I'm trying but I need some help, as I get an error "illegal retval" and in the same time "not connected to pilbox". PILBOX is ok on COM3 (Windows) and works well with ILCtrl.
Thanks!
Salvo
(02-05-2018 07:04 PM)Dave Frederickson Wrote: [ -> ]Try searching for a solution first. This was posted only 4 days ago.
http://www.hpmuseum.org/forum/thread-10065.html
sorry, for now I'm inattentive, happy doing experiments with PILbox, new toy for me...
thank you Dave, I'll read there.
Salvo
EDIT:
Found (in Mac OS X): it works with 115200 and not with 230400 Bd in configuration of PILbox
(02-05-2018 07:30 PM)salvomic Wrote: [ -> ]sorry, for now I'm inattentive, happy doing experiments with PILbox, new toy for me...
Salvo
EDIT:
Salvo, the PIL-Box has a jumper that sets the baud-rate option 115KB or 230KB. The 230KB is obviously faster, but the 'feeling' is even faster than it sounds and I recommend using 230KB if you can; I am fairly sure it will work at 230KB on OSX, but what s/w are you using?
IL-Per under some Windows subsystem (parallels, etc.) or pyILPer ?
(02-05-2018 09:06 PM)rprosperi Wrote: [ -> ]Salvo, the PIL-Box has a jumper that sets the baud-rate option 115KB or 230KB. The 230KB is obviously faster, but the 'feeling' is even faster than it sounds and I recommend using 230KB if you can; I am fairly sure it will work at 230KB on OSX, but what s/w are you using?
hi Bob,
I'm testing pyILPer now.
Today I set cables and started with PILbox and I saw the jumper set was the #2; should I test put in in #3?
Salvo
(11-28-2017 06:37 PM)jsi Wrote: [ -> ]This release of pyILPER includes lots of enhancements, improvements and changes, see the release notes for details.
Joachim
Thanks a lot, Joachim!
I'm enjoying very much with this program and PILbox (I find very good also ILper).
Installed with a glitch both in Mac OS X 10.13.3 and Windows 10 (inside Parallels 13).
I'm testing HP-41CX and HP-71b.
I'd like to have a set of preconfigured programs (LIF...) where to pick and install in the calculator (using the program not only to backup all - very important job - or printing, very amazing to get PDF from the "old machines")... Like a sort or "repository" (two series, for 71B and 41C) or "carry and cash (without cash)" of programs
About this purpose, it would be nice to could edit the virtual devices (disks, LIF, DAT...) to put (not only delete) programs to load, then, in the calculator; with the goal to share nice configurations, sets,...
EDIT: though I'm testing to import with Tools from some ROMs, it is not exactly what I'd prefer: I would like to import some parts by a list of programs in them, not the whole ROM...
Salvo
(02-05-2018 09:40 PM)salvomic Wrote: [ -> ]hi Bob,
Salvo
No, JP3 is not used.
JP2 - Jumper ON - 115KB
JP2 - Jumper OFF - 230KB
So just remove the jumper.
(02-05-2018 10:43 PM)rprosperi Wrote: [ -> ]No, JP3 is not used.
ok!
Then, removing JP2 now in Mac OS X the program runs at 230KB (and returns "illegal retval at 115KB).
For me is ok, thanks for advice.
Salvo
Sorry, Dave's right, I was not clear; JP3 is not used for setting baud rate...
(02-05-2018 11:11 PM)rprosperi Wrote: [ -> ]Sorry, Dave's right, I was not clear; JP3 is not used for setting baud rate...
Understood, thanks
For now I'll keep JP2 off and JP3 off; if there will be issues I'll try JP3 on.
I checked JP2 off in Mac OS X and Windows 10 also: ok with 230kb in pyILper and ILCtrl. Also in Windows, now at 115KB pyILper returns "illegal retval".
salvo
(02-05-2018 11:16 PM)salvomic Wrote: [ -> ]Understood, thanks
salvo
Great, looks like all is working properly.
You'll love the PIL-Box and wonder how you got along without one for so long.
(02-06-2018 12:42 AM)rprosperi Wrote: [ -> ]Great, looks like all is working properly.
yeah, indeed!
It's a must have for whom like HP41 and HP71.
Salvo
