How do I read the previous ones in a new input query for this exaple?
EXPORT erfAs()
LOCAL Md,H1,b,∅Bew,∅Büg,d,as;
LOCAL cnom;
LOCAL m,m1,mx,my;
IF I==I THEN Md:=Md;H1:=H1;
INPUT({{Md,[0],{25,15,0}},
{H1,[0],{25,15,1}},
{b,[0],{25,15,2}},
{cnom,[0],{72,15,0}},
{∅Büg,[0],{72,15,1}},
{∅Bew,[0],{72,15,2}}},
"Beton-Querkraftwiderstand",
{"Md [kNm]","h [mm] ","b [mm] ","cnom [mm] ","∅Büg [mm]","∅Bew [mm]"},
{"Bemessungsmoment","Höhe des Betonquerschnittes","breite des Betonquerschnittes","Betondeckung [mm]","Bügeldurchmesser [mm]","Bewehrungsdurchmesser [mm]"});
d:=H1-cnom-∅Büg-∅Bew;
as:=Md*1000000/(0.9*d*435);
RECT_P(7,135,310,200,RGB(0,0,0),RGB(0,230,255));
TEXTOUT_P("Ergebniss: ",19,140,6);
//LINE_P(0,185,170,185);
TEXTOUT_P("erf As",120,140,6);
TEXTOUT_P("=",180,140,6);
TEXTOUT_P(ROUND(as,0)+" mm²",195,140,6);
//TEXTOUT_P("mm",240,140,6);
REPEAT
DRAWMENU("ENDE","","weiter","","","zurück");
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
mx:=m1(1); my:=m1(2);
// ENDE
IF (my≥220 AND my≤319) AND (mx≥0 AND mx≤51) THEN
Startview(-1);
IF (my≥220 AND my≤319) AND (mx≥106 AND mx≤160) THEN
I:=1;erfAs;
//erfAs neu
IF (my≥220 AND my≤319) AND (mx≥265 AND mx≤319) THEN
I:=1;erfAs;
//Close main loop
UNTIL ((my≥220 AND my≤319) AND (mx≥0 AND mx≤51) or (my≥220 AND my≤319) AND (mx≥106 AND mx≤160) or (my≥220 AND my≤319) AND (mx≥265 AND mx≤319));
You need to be more explicit about what you are trying to figure out...
(11-17-2017 09:24 AM)webmasterpdx Wrote: [ -> ]You need to be more explicit about what you are trying to figure out...
I enter in this program my values and let calculate the result. Repeat the input with (zurück) but would like to read in all previous input values, because I only want to change one value
You can make the variables globals. Make sure you don't use the standard system variable names (try to use unique names).
The variables Md, H1, etc, are all declared as LOCAL inside the function. Instead declare them as EXPORT outside the function (before the function erfAs).
It should just hold the values.
Now, I just tried it on a simple example and it worked. However, if you specify initial values in your input statements, the initial values will override the variable values.
Give it a try.
-Donald
(11-17-2017 10:23 AM)webmasterpdx Wrote: [ -> ]You can make the variables globals. Make sure you don't use the standard system variable names (try to use unique names).
Give it a try.
-Donald
Hello Donald,
can you make a example i my programm?
EXPORT Md,H1,b,∅Bew,∅Büg,cnom; // May need to change b to b1 or something unique
// if you do, change b below too...
EXPORT erfAs()
LOCAL d,as;
LOCAL m,m1,mx,my;
{H1,[0],{25,15,1}},
{b,[0],{25,15,2}},
REPEAT
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
// ENDE
Startview(-1);
I:=1;erfAs;
//erfAs neu
I:=1;erfAs;
//Close main loop
(11-17-2017 11:11 AM)webmasterpdx Wrote: [ -> ]EXPORT Md,H1,b,∅Bew,∅Büg,cnom; // May need to change b to b1 or something unique
EXPORT erfAs()
LOCAL d,as;
LOCAL m,m1,mx,my;
{H1,[0],{25,15,1}},
{b,[0],{25,15,2}},
REPEAT
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
// ENDE
Startview(-1);
I:=1;erfAs;
//erfAs neu
I:=1;erfAs;
//Close main loop
When i make that, i become a syntax error in this line: EXPORT Md,H1,b,∅Bew,∅Büg,cnom;
I take a look at your program and if I don't understand all you want to do I noticed that you have a recursive call to erfAs as well as a call to Startview(-1) which I don't think are necessary.
So I modified a little bit your code to follow the sequence:
Main Loop:
-Input form to get variable values
-Calculation and display of result
-Wait until user press a soft key
Exit loop if soft key is "ENDE" or "weiter", else loop
If soft key is Weiter, do what you need for Weiter
If soft key is ENDE, do what you need for ENDE
EXPORT erfAs()
LOCAL cnom;
LOCAL m,m1,mx,my;
LOCAL Ende, Weiter, Zurück;
//Main loop
REPEAT
{H1,[0],{25,15,1}},
{b,[0],{25,15,2}},
REPEAT
// Get mouse data
REPEAT
m:=MOUSE; m1:=m(1);
UNTIL SIZE(m1)>0;
Ende:=(my≥220 AND my≤319) AND (mx≥0 AND mx≤51);
Weiter:=(my≥220 AND my≤319) AND (mx≥106 AND mx≤160);
Zurück:=(my≥220 AND my≤319) AND (mx≥265 AND mx≤319);
UNTIL (Ende or Weiter or Zurück); // wait for a soft key
UNTIL (Ende or Weiter); // exit Main loop with "ENDE" or "weiter"
// weiter
IF Weiter THEN
//do what you need for weiter
// ENDE
IF Ende THEN
//do what you need for ENDE
When you run it or when you compile it, and when you click on check, it should place the cursor where the error is.
I'm guessing, but did you remove the LOCAL declarations I moved to EXPORT?
Also, you might need to change the b variable name as I said in the comment....that could be the culprit. You can confirm this by using the check button and seeing where the cursor goes on error.
If this is the problem it's because b already exists as a global variable of a different type....which is why you need to change the name. Remember to change it where it's used in the function too.
Statistics 1Var uses H1, so that's a problem. You'll have to change H1 to HH1 and change where it's used below to HH1 too.
All the variables need to be unique and not used elsewhere in the system.
Yes, I change H1 to HH1 on my virtual prime and it compiled fine.....b was OK on my system, but I don't know what programs you have already installed.
Many thanks Webmasterpdx and Didier Lachieze, You hit the nail on the head, that's exactly what I wanted, great.
And sorry, but my englisch is not so good.
