Is there a way to add this kind of menu on prime?
i tried with with DRAWMENU but i was unable to insert drawings just strings even when i tried with PIXON_P it wont let me create pixel over (xxx,219), is there a way to do that?
Thanks, but i was thinking on editing the menu on the bottom, is it possible to add pixel drawing instead of strings to that?
if it isnt i will use your menu
Thanks
(03-21-2014 05:50 PM)kifura Wrote: [ -> ]Thanks, but i was thinking on editing the menu on the bottom, is it possible to add pixel drawing instead of strings to that?
Thanks
You can; first you have to clear the current screen (e.g. use the RECT_P command). Then you can draw your image using PIXON_P. If your images are simple, then you can probably save a lot of space using PIXON_P and LINE_P. On the other hand, complicated images are probably best via the ICON command.
The main thing to get from my example is how to trap the touchscreen events since the icons themselves aren't really all that important (nor their location).
