12-21-2014, 02:13 PM
Tried your new versión and zooming has improved a lot. It´s true that some movements aren´t 100% accurate, but is enough for doing basical rotations. By the way, when I select panning mode, it still rotate the figure instead of panning it, perhaps I´m not doing it well.
By the way. A suggestion. Is it posible to draw the XYZ axis to know which axis is in every moment? With so many rotations you get los thow is oriented the frame. Tahnk you, and keep on doing like this.
