11-04-2017, 02:08 PM
The program BESTFIT compares a set of regressions to determine a best fit. This simulates a feature presented on the Hewlett Packard HP 48S, HP 48G, HP 49G, and HP 50g. BESTFIT compares the correlations of the following four regression models:
1. Linear: y = a * x + b
2. Logarithmic: y = a * ln x + b
3. Exponential: y = b * a^x (y = b * e^(ln a * x))
4. Power: y = b * x^a
The output is a two element list: a string of the best fit equation and its corresponding correlation.
HP Prime Program: BESTFIT
BESTFIT2: An Extended Version
Version 2 adds the following regressions:
5. Inverse: y = b + a/x
6. Simple Logistic: y = 1/(b + a*e^(-x))
7. Simple Quadratic: y = b + a*x^2
8. Square Root: y = √(a*x + b)
HP Prime Program: BESTFIT2
Link: http://edspi31415.blogspot.com/2017/11/h...n-fit.html
EXPORT BESTFIT(L1,L2)
// 2017-11-02 EWS
// Simulate Best Fit
// HP 48GX,49G,50g
// initialize
LOCAL clist,m,c,v,s,n;
clist:={0,0,0,0};
// test
// correlation is linear only
// requires approx()
// linear y=a*x+b
clist[1]:=approx(correlation(L1,L2));
// log y=a*LN(x)+b
c:=approx(correlation(LN(L1),L2));
IF IM(c)==0 THEN
clist[2]:=c;
// exponential y=b*e^(a*x)
c:=approx(correlation(L1,LN(L2)));
IF IM(c)==0 THEN
clist[3]:=c;
// power y=b*a^x
c:=approx(correlation(LN(L1),LN(L2)));
IF IM(c)==0 THEN
clist[4]:=c;
// test
// POS(L0^2,MAX(L0^2))
m:=POS(clist^2,MAX(clist^2));
c:=clist[m];
IF m==1 THEN
v:=linear_regression(L1,L2);
s:=STRING(v[2])+"+"+STRING(v[1])+
"*X";
RETURN {s,c};
IF m==2 THEN
v:=logarithmic_regression(L1,L2);
"*LN(X)";
RETURN {s,c};
IF m==3 THEN
v:=exponential_regression(L1,L2);
s:=STRING(v[2])+"*"+STRING(v[1])+
"^X";
RETURN {s,c};
IF m==4 THEN
v:=power_regression(L1,L2);
s:=STRING(v[2])+"*X^"+
STRING(v[1]);
RETURN {v,s};
EXPORT BESTFIT2(L1,L2)
// 2017-11-02 EWS
// HP 48GX,49G,50g
// additional models
// initialize
LOCAL clist,m,c,v,s;
clist:={0,0,0,0,0,0,0,0};
// test
// linear y=a*x+b
// log y=a*LN(x)+b
IF IM(c)==0 THEN
clist[2]:=c;
IF IM(c)==0 THEN
clist[3]:=c;
// power y=b*a^x
IF IM(c)==0 THEN
clist[4]:=c;
// inverse y=b+a/x
IF POS(L1,0)==0 THEN
clist[5]:=approx(correlation(1/L1,
L2));
// simple logistic
IF POS(L2,0)==0 THEN
clist[6]:=approx(correlation(e^(−L1),
1/L2));
// simple quadratic
clist[7]:=approx(correlation(L1^2,
L2));
// square root
IF ΣLIST(L2≥0)==SIZE(L2) THEN
clist[8]:=approx(correlation(L1,
L2^2));
// test
c:=clist[m];
IF m==1 THEN
"*X";
IF m==2 THEN
"*LN(X)";
IF m==3 THEN
"^X";
IF m==4 THEN
STRING(v[1]);
// inverse
IF m==5 THEN
v:=linear_regression(1/L1,L2);
"/X";
// simple logistic
IF m==6 THEN
v:=linear_regression(e^(−L1),
1/L2);
s:="1/("+STRING(v[2])+"+"+
STRING(v[1])+"*e^(−X))";
// simple quadratic
IF m==7 THEN
v:=linear_regression(L1^2,L2);
"*X^2";
// square root
IF m==8 THEN
v:=linear_regression(L1,L2^2);
s:="√("+STRING(v[2])+"+"+
STRING(v[1])+"*X)";
RETURN {s,c};
