11-02-2017, 09:58 PM
Today I got my 25E GPS out of the drawer and turned it on. Batteries wer flat, as I had left it there unused for a couple of month. Installed a battery pack with fresh batteries and switched it on again.
But what is this? Looks strange:
[attachment=5294]
I can press a number key and the number gets displayed. I can't do any basic operations though and other keys do weired things. For example x<>y seems to divide by 100. R/S gets me to stopwatch mode, and that even works. None of the menue options work.
I haven't tried reflashing the firmware. I am sure the calculator worked fine last time I played with it.
Any thoughts on what might have happened here?
Cheers,
Harald
PS: Bernhard, I hope you don't mind me posting this here instead of emailing you. It is not meant as a complaint in any way. I just thought it might help others if they have a similar problem.
It might be me having made a mistake when installing it. Maybe an insulation has been pierced under pressure inside the calculator and now there is a short?
[attachment=5294]
Cheers,
Harald
