(10-16-2017 01:38 PM)Gamo Wrote: [ -> ]I still can't find the way to do this pricing calculation method just by press the two known variables and get the answer for the other two variables.
For example: when you know Cost and Margin you get answer for Price and Markup. Just by input A and D then press B and C for instant answer.
That's not trivial, for several reasons. For instance there are multiple ways to calculate each of the four variables, depending on which ones are known are which are not. Then there are cases where no unique solution exists (e.g. if only markup and margin are given).
Here is a program that does what you want. Enter any two of the four variables, and the other two are calculated. The program uses a method that I already implemented more than 30 years ago for a triangle solver (enter any three... you get the picture). If a variable is entered, a constant of 1 (cost), 2 (price), 4 (markup) or 8 (margin) is added to R0. This way each of the six possible cases produces a unique sum:
cost & price => 3
cost & markup => 5
price & markup => 6
cost & margin => 9
price & margin => 10
markup & margin => 12
The last case can be neglected since no unique solution for cost and price exists if only markup and margin are given.
Now the program can simply jump to the label with that number to start the calculation. Actually it jumps to a label with that number minus 3 because this way all results are between 0 and 9 and the labels above (LBL A = #10) can be used without interfering with the calculation routines.
Pressing [E] initializes the program. After two values have been entered (counted by a DSZ command) the calculation routine at LBL e starts. LBL a and b hold some calculations that appear several times. Afterwards pressing one of the keys [A]...[D] shows the respective result.
Here is the listing:
001 LBL E
002 FIX
003 DSP 2
004 2
005 STO I
006 CLX
007 STO 0
008 STO 1
009 STO 2
010 STO 3
011 STO 4
012 CF 3
013 RTN
014 LBL A
015 F3?
016 F3?
017 GTO c
018 1
019 STO+0
020 R↓
021 STO 1
022 DSZ
023 RTN
024 GSB e
025 LBL c
026 RCL 1
027 RTN
028 LBL B
029 F3?
030 F3?
031 GTO c
032 2
033 STO+0
034 R↓
035 STO 2
036 DSZ
037 RTN
038 GSB e
039 LBL c
040 RCL 2
041 RTN
042 LBL C
043 F3?
044 F3?
045 GTO c
046 4
047 STO+0
048 R↓
049 STO 3
050 DSZ
051 RTN
052 GSB e
053 LBL c
054 RCL 3
055 RTN
056 LBL D
057 F3?
058 F3?
059 GTO c
060 8
061 STO+0
062 R↓
063 STO 4
064 DSZ
065 RTN
066 GSB e
067 LBL c
068 RCL 4
069 RTN
070 LBL e
071 RCL 0
072 3
073 -
074 STO I
075 GTO(i)
076 LBL 0
077 GSB a
078 GTO b
079 LBL 2
080 RCL 1
081 RCL 3
082 %
083 +
084 STO 2
085 GTO b
086 LBL 3
087 RCL 2
088 1
089 RCL 3
090 %
091 +
092 /
093 STO 1
094 GTO b
095 LBL 6
096 RCL 1
097 1
098 RCL 4
099 %
100 -
101 /
102 STO 2
103 GTO a
104 LBL 7
105 RCL 2
106 RCL 4
107 %
108 -
109 STO 1
110 LBL a
111 RCL 1
112 RCL 2
113 %CH
114 STO 3
115 RTN
116 LBL b
117 RCL 2
118 RCL 1
119 %CH
120 CHS
121 STO 4
122 RTN
Here is an example:
Initialize [E] 0,00
Enter cost 110 [A] 110,00
Enter price 165 [B] 165,00
Get markup [C] 50,00
Get margin [D] 33,33
All data can now be recalled by pressing the [A] to [D] keys.
Be sure to press none of the number entry keys because else this will be considered a new data input.
Get cost [A] 110,00
Get price [B] 165,00
Another example:
Initialize [E] 0,00
Enter markup 50 [C] 50,00
You can also try any other combination. Including markup & margin. Try it: it will result in an "Error" message.
Note: data entry is detected by flag 3 which, on the '67 and '97, is set if you enter data with the number entry keys. It is not set if you recall a value from a register. So if you want to do so press any number key before. If you want you can change this to another method, e.g. consider only non-zero values as data entry. In this case simply replace the double F3? tests (which behaves like a FC?C 03) by an "X=0?" test.
Dieter
