03-15-2014, 08:49 PM
Hi all,
I am getting an error message every time I use the AMORT command on the spreadsheet App. This is curious because by typing the exact same command on the Emulator, the command works just fine. Could a change in my settings be causing the issue? If so, are there any troubleshooting steps that you could recommend?
Works on the emulator, does not work on the actual calculator.
Thanks
Thanks
