09-17-2017, 04:09 PM
here is a library about list processing,
it add the Associative list concept.
What is "Associative list" ?
It's powerfull list that you can reach item by a key instead of an index.
You can store value based on name, for example list of GDP per country name...
This feature is well known in php, here is an example of php associated list :
With LibAssoc, it gives :
mylist:=AL_NEW(); //create the AList object
AL_SET(mylist,"key1",value1); //insert first value, for "key1" name
AL_SET(mylist,"key2",value2);
AL_GET(mylist,"key1"); // returns value1
Please note as Associative List is not a buildin object, most of API functions require the AList object to be passed as first parameter.
Note that 3 first lines can be shortened by this :
Please note this lib has one dependency : LibList, please first download it.
Download LibAssoc v0.801 - sept 2017:
[attachment=5194]
API list : AL_NEW, AL_SET, AL_GET, AL_FKEY, AL_SIZE, AL_DEL, AL_VMATCH, AL_VMAP, AL_FOREACH, AL_SPLIT
AL_NEW()
Create a new Associative List
ex :
AL_SET(AList,Key,Val)
set/insert key+value in AList
AList is an associtive list,
Key is a string,
Val any type you want.
ex :
AL_GET(AList,Key)
Return value from a given Key
if not found, return an empty string.
ex :
AL_FKEY(AList,Key)
is Key exist on AList ?
return non null if exist, 0 if not
ex :
AL_SIZE(AList)
Returns the number of item
ex :
AL_DEL(AList,Key)
Remove an item from a Associative List
ex :
AL_VMATCH(AList,FCT)
Value Matching
Run a user function Fct on each items, based upon function return, build a subset Assciative List and return it.
user function receive item value, and must return >0 to match.
ex :
AL_VMAP(AList,Fct)
Run user fuction on each Value
AL_FOREACH(AList,Fct)
Run user fuction on each (Key,Value)
ex :
AL_SPLIT(Str,Sep1,Sep2)
Build a AList from a string
Sep1 is object separator
Sep2 is the key/value separator.
ex :
PHP Code:
$mylist= ['key1'=>value1, 'otherkey'=>value2];
$mylist['key1'] // returns values1
mylist:=AL_SPLIT("key1=value1;key2=value2",";","=");
[attachment=5194]
AL_NEW()
ex :
L:=AL_NEW();
Key is a string,
ex :
L:=AL_NEW();
AL_SET(L,"key1","value1");
AL_SET(L,"key2",123); // key2 value is 123.
AL_GET(AList,Key)
ex :
V:=AL_GET(L,"key1");
AL_FKEY(AList,Key)
ex :
if AL_FKEY(L,"key1") then ...
AL_SIZE(AList)
ex :
PRINT("there are "+AL_SIZE(L)+" item(s) ");
AL_DEL(AList,Key)
ex :
AL_DEL(L,"key1");
Value Matching
ex :
L:=AL_NEW();
AL_SET(L,"key1",10);
AL_SET(L,"key2",20);
EXPORT myFct(val)
IF val>15 return 1; END;
return 0;
L2:=AL_VMATCH(L,"myFct"); // L2 have only the key2 item. (value>15)
AL_VMAP(AList,Fct)
ex :
EXPORT display(k,v)
PRINT(k+" -> "+v);
AL_FOREACH(L,"display");
ex :
L:=AL_SPLIT("key1=123|key2=456|key3=789","|","=");
