09-10-2017, 10:02 AM
I do not really like to use the built in command FACTORS when I would like to know the factors of a integer number in real format. FACTORS would require some flags to be set plus real to integer conversion.
Sure when I have massive needs, then FACTORS is better, but otherwise I'd like to have a more handy routine.
A quick idea is the one below, but do you know any one else that coded something more robust and fast? Or maybe a MathExt library containing a substitution of FACTORS?
Requirements:
input: an integer or an integer in real form (so with the dot at the end), flag -3 and -105 set or unset, does not matter.
output: the factors of the input number (integers in real or integer form)
Requirements:
factorsR
{} "resultList" DROP
2 "possibleDivisor" DROP
0 "divisorFound" DROP
@input
inputNumber
@local var
resultList
possibleDivisor
divisorFound
WHILE
inputNumber ISPRIME? NOT
inputNumber 1 >
AND
REPEAT
2 'possibleDivisor' STO
0 'divisorFound' STO
WHILE
divisorFound 0 ==
REPEAT
IF
inputNumber possibleDivisor MOD 0 ==
THEN
1 'divisorFound' STO
'resultList' possibleDivisor STO+
inputNumber possibleDivisor / 'inputNumber' STO
ELSE
possibleDivisor NEXTPRIME 'possibleDivisor' STO
END
END
END
'resultList' inputNumber STO+
resultList
