09-08-2017, 06:39 AM
I discovered a useful video describing how to use the input command to create a form in the prime. However, it doesn't cover a few things.
First, the video i'm referring to is here:
https://www.youtube.com/watch?v=4rObQpO5DTY
The checkbox option, if you put in a value other than zero, the checkboxes would be a single selection where only one box could be selected, so you'd give each one a value of 1, 2 or 3, for example.
e.g. Where any can be selected, the code is:
{tm,0,{90,10,4}},
{wm,0,{90,10,5}},
{sb,0,{90,10,6}},
....and when only one can be selected, it becomes...
{tm,1,{90,10,4}},
{wm,2,{90,10,5}},
{sb,3,{90,10,6}},
This shows how to make all your checkboxes have a selection...but what if you have more than one group of checkboxes on the same form?
So, my first question is...is it possible to have more than one group of checkboxes where only one is selectable? ....on the same form I mean? If so, how is that done?
My second question is a bit bigger....there are many other widgets I've seen, such as a slider in the geometry app. If I want to add a slider to one of my forms, how do I do it?
Also, I've seen a progress slider when loading something, e.g. the codeviewer app, has a progress slider displayed when loading the code to view....how do I do that?
i.e. Is there any link where all the possible widgets are described? Also, is there any decent place where the input command is described in detail, with examples if possible?
I'm trying to figure out how to use all possible widgets as I'm giving serious consideration to developing an SDK app where these widgets can be defined in a visual way and then the app will generate the code to create them.....first step is figuring out how they are displayed and used.
Thanks in advance...
-Donald
{tm,0,{90,10,4}},
{wm,0,{90,10,5}},
{sb,0,{90,10,6}},
{tm,1,{90,10,4}},
{wm,2,{90,10,5}},
{sb,3,{90,10,6}},
-Donald
