09-05-2017, 03:24 AM
The game assumes you are playing a 10-point match of cyber tennis. You play as many rounds until either you or the calculator wins 10 rounds. See instructions to play the game and to view the special new features (see steps 6, 7, and 8).
Memory Map
HP-71B Listing
Instructions
1) Press the [RUN] key.
2) The calculator prompts you to enter a new seed for the random number.
3) Optionally enter a new seed and press [ENTER]. You can simply do the latter to use the current random number.
4) If you win the current round, the program displays "YOU=" followed by you current total winnings. If you lose the current round, program displays "CALC=" followed by the calculator's current total winnings. If neither wins the current round, the program displays "TIE".
5) If you reached the maximum number of points to win, the program displays "YOU WIN". If the calculator has reached the maximum number of points to win, the program displays "YOU LOSE". The program stops if there is a winner.
6) If the random number is equal to or greater than 0.99, the game goes into sudden death mode. In these mode, both you and the calculator have each a score of 9. The next win of a round determines the winning party. The program displays the message "SUDDEN DEATH" to announce this special game mode.
7) If the random number used to calculate your score in a round, is less than 0.01, your current winnings score is reset to 0. The program displays the message "YOU RESET".
8) If the random number used to calculate the calculator's score in a round, is less than 0.01, the calculator's current winnings score is reset to 0. The program displays the message "CALC RESET".
9) Resume at step 4.
Memory Map
M9 = max range
C9 = number of points to win
C1 = wining counter for player
C2 = wining counter for calculator
V1 = round value for player
V2 = round value for calculator
R = random number
V = round value
HP-71B Listing
10 REM CYBER TENNIS - 10-POINJT GAME
11 REM VERSION 2
20 M9= 100 @ C9=10 @C1 = 0 @ C2 = 0
30 R = PI
40 INPUT "ENTER NEW SEED? ", "";A$
50 IF A$<>"" THEN R=VAL(A$)
60 GOSUB 1000 @ V1=V @ IF R<0.01 THEN DISP "YOU RESET" @ WAIT 2 @ C1=0
70 GOSUB 1000 @ V2=V @ IF R<0.01 THEN DISP "CALC RESET" @ WAIT 2 @ C2=0
80 IF V1>V2 THEN C1=C1+1 @ DISP "YOU=";C1 @ WAIT 2
90 IF V2>V1 THEN C2=C2+1 @ DISP "CALC=";C2 @ WAIT 2
100 IF V1=V2 THEN DISP "TIE" @ WAIT 2
110 IF C1>=C9 THEN DISP "YOU WIN" @ GOTO 200
120 IF C2>=C9 THEN DISP "YOU LOSE" @ GOTO 200
130 IF R >= 0.99 THEN DISP "SUDDEN DEATH ON!" @ WAIT 2 @ C1=C9-1 C2=C1
140 GOTO 40
200 END
1000 R = (PI+R)^5
1010 R = R - INT(R)
1020 V = INT(M9*R)
1030 RETURN
Instructions
