For integer input N the programme returns the Nth element of the series
https://oeis.org/A046034
NB The description below uses the expression
eg Z3_
for ZINT 3.
The two are however NOT the same, Z3_ at PTR 273CE having 2.5 Bytes & ZINT 3 having 6 Bytes.
The size & check sum below are for the version as printed.
CK1&Dispatch
# FF
Z3_
FPTR2 ^RMULText
Z1_
FPTR2 ^RADDext
DUP
FPTR2 ^Z>R
%LN
%4
%LN
%FLOOR
COERCESWAP
Z4_
3PICK
FPTR2 ^RP#
FPTR2 ^RSUBext
NULL$
ROT
ZERO_DO
OVER
Z3_
Z4_
INDEX@
FPTR2 ^RP#
FPTR2 ^RMULText
FPTR2 ^ZQUOText
DUPDUP
FPTR2 ^RADDext
Z1_
FPTR2 ^RADDext
Z8_
FPTR2 ^ZMod
OVER
Z4_
FPTR2 ^ZQUOText
FPTR2 ^RADDext
SWAP
Z1_
FPTR2 ^RSUBext
Z4_
FPTR2 ^IDIV2
DROP
FPTR2 ^RSUBext
FPTR2 ^Z>S
SWAP&$
LOOP
SWAPDROP
FPTR2 ^S>Z
SIZE 200.5
CKSUM # 118Bh
A faster version of the programme:
CK1&Dispatch
# FF
Z1_
SWAP
Z3_
FPTR2 ^RMULText
Z1_
FPTR2 ^RADDext
DUP
FPTR2 ^Z>R
%LN
%4
%LN
%FLOOR
COERCESWAP
Z4_
3PICK
FPTR2 ^RP#
FPTR2 ^RSUBext
NULL$
ROT
ZERO_DO
OVER
4ROLL
DUP
Z4_
FPTR2 ^RMULText
5UNROLL
Z3_
FPTR2 ^RMULText
FPTR2 ^ZQUOText
DUPDUP
FPTR2 ^RADDext
Z1_
FPTR2 ^RADDext
Z8_
FPTR2 ^ZMod
OVER
Z4_
FPTR2 ^ZQUOText
FPTR2 ^RADDext
SWAP
Z1_
FPTR2 ^RSUBext
Z4_
FPTR2 ^IDIV2
DROP
FPTR2 ^RSUBext
FPTR2 ^Z>S
SWAP&$
LOOP
ROTROT2DROP
FPTR2 ^S>Z
If you use the standard HP extable library and 50g's built-in assembler, you can use Gerald's source code if you add the following lines to the very beginning:
EQU Z1_ 273B6
EQU Z3_ 273CE
EQU Z4_ 273DA
EQU Z8_ 2740A
But this programme is much faster & shorter:
CkSum: # 71CDh
CK1&Dispatch
# FF
DUP
ZINT 1
Z<
caseSIZEERR
NULL$SWAP
ZINT 4
FPTR2 ^ZDIVext
ZINT 1
EQUALcasedrop
"2"
ZINT 2
EQUALcasedrop
"3"
ZINT 3
EQUALcase
"5"
"7"
SWAP
ZINT 1
FPTR2 ^RSUBext
SWAP
ROT
&$SWAP
DUP
ZINT 0
EQUAL
UNTIL
DROP
FPTR2 ^S>Z
With that last version, I get 146.5 bytes and #FA74h, and it just hangs when I run it.
I just copied the published source code & compiled on my 50g.
Result is that programme works correctly,
size 146
Cksum 71CD.
Has anyone besides Eric had problems?
A slightly shorter version:
CkSum: # 7092h
CK1&Dispatch
# FF
DUP
ZINT 1
Z<
caseSIZEERR
NULL$SWAP
ZINT 4
FPTR2 ^ZDIVext
ZINT 1
EQUALcasedrop
CHR_2
ZINT 2
EQUALcasedrop
CHR_3
ZINT 3
EQUALcase
CHR_5
CHR_7
SWAP
ZINT 1
FPTR2 ^RSUBext
SWAP
ROTSWAP
>H$
SWAPDUP
ZINT 0
EQUAL
UNTIL
DROP
FPTR2 ^S>Z
(09-04-2017 08:02 PM)Gerald H Wrote: [ -> ]Has anyone besides Eric had problems?
Both of the versions above this reply run fine on my 50g, and have the sizes and checksums that you cited above.
Hmmm...interesting. I am thinking this is a bug in Jazz.
Using the same extable library, Jazz (which I have been using for all of Gerald's posts because I'm too lazy to add the !RPL !NO_CODE to the beginning and @ to the end) compiles it incorrectly, giving the incorrect bytes/checksum that I listed. The built in assembler (ASM) works fine.
What makes it even more interesting is when I do a ->S2 on it, both the Jazz compiled code and the ASM compiled code decompile to the same source.
Inspecting the hexadecimal representations of both shows the difference. They are almost identical. The only difference is that Jazz compiles the ZINT 0 to the following, which is a positive signed zero:
41620 (DOINT)
7000000
And ASM compiles ZINT 0 to the following, which is an unsigned zero (which is correct -- zero should not be signed):
41620 (DOINT)
600000
The former does not work; the latter works fine. But calling ->S2 on either yields the same thing:
!NO CODE
!RPL
ZINT 0
Sorry for the false alarm, Gerald. Looks like Jazz is incorrectly putting a sign on zero!
Pleased to hear it works OK, Eric.
It is pleasant to know that someone goes to the trouble of compiling & using my programmes.
Indeed, some positive feedback would be nice as informing that there is some degree of interest in such programmes.
I guess comments like "Best programme I've ever seen" or "This programme has changed my life" or "Before I used this programme I was a bum, now I'm a multi-millionaire" would be appropriate.
However, most members of the forum don't always write what they believe but moderate their expressions to something like "Well done".
Suggestions for improvements most welcome.
Having once again carried out my weekly review checking for improvements & none having been published I guess the programme above is perfectly perfect.
Accordingly it may now be considered the final form.
The programme below carries out the inverse transformation.
I have attempted some error checking to ensure only compatible input is processed but it's better only to input correctly conformed integers.
Not yet a multi-millionaire & time's running out.
CkSum: # 1016d
CK1&Dispatch
# FF
FPTR2 ^Z>S
DUP
BINT2
BINT3
BINT5
BINT7
5ROLL
BINT4
ZERO_DO
SWAP
NULL$
FPTR F 1A
DROPLOOP
LEN$
#0<>
case
FPTR2 ^DROPZ0
ZINT 0
SWAPDUP
LEN$
ZERO_DO
DUP
CDR$
SWAP
CAR$
CHR>#
BINT49
#-DUP
BINT2
IT
#1-DUP
#5=
NOT?SEMI
#1-
FPTR2 ^#>Z
ROT
ZINT 4
FPTR2 ^RMULText
FPTR2 ^RADDext
SWAPLOOP
DROP
