03-12-2014, 07:06 PM
I bought a new 2GB card today and I wanted to format it on the HP 50g.
It starts formating but after few seconds there comes a popup window saying there is a format error.
I tried on the PC and everything works fine.
Also checked for errors and everything is fine.
Did someone got this error before? Is that a known error?
Or do I do something wrong?
Or do I need to learn RPL for that?
EDIT:
I just have read in the quick start guide that comes with the HP 50g (German) and it says:
- Only SD cards are accepted with max. capacity 2GB
- SDHC cards are NOT supported.
- FAT32 is supported but there will be a 2 Sec. lag at Boot Time.
- The HP 50g, in the case of a SD card greater than 1GB, it will display a free capacity lower than 1GB but you have full access to the 2GB.
EDIT:
