A programme to enter symbolics in the Sequence App to reproduce the sequence
https://oeis.org/A002516
A002516
RECURSE(U,IFTE(N MOD 2==0,2*U1(N/2),IFTE(N MOD 4==1,N+2,2*(N-2))),3,6)►U1(N):
CHECK 1:
Could someone please put the symbolics in a Prime to see if it works?
Thank you, Didier. I have given up on the Prime & no longer have access to one.
Does this mean that previously noted defects in the Sequence App have been attended to?
The Prime is regularly updated and IMHO it is now one of the best if not the best calculator available. You can use the virtual calculator available
here if you want to try it again.
I don't know exactly which Sequence issues you're referring to, but there has been several updates and fixes for this App.
Thank you, Didier, & I'm very glad the fault has been corrected.
