07-28-2017, 10:00 PM
The Interchangable Solutions Module (INTSOLN.MOD) when combined with the SIROM Module is a nice way to solve equations, and quite a few examples are given. I have rewritten a couple sections of the SLV+ routine to allow it to use the SV$ program in the Formula EVAL Module (currently EVAL_1E.MOD).
Here is the new LIBSV$ routine (Solve equation from library) and an example using Ohm's Law for the equation to solve:
Notice that the variable to solve must be replaced with X, and that the variables (max of 5 allowed) are automatically put into a thru e (buffer 7). It is a little more complicated to enter the user equation, but much clearer on how it is being solved.
RAW files for the above program are attached.
Greg
Quote:01 LBL "LIBSV$"
02 SF 27 ' SET USER MODE
03 CLX ' CLEAR KEY ASSIGNMENTS FOR A-E
04 LKAX
05 LBL F ' NEW EQUATION RESTART
06 "EQ NAME: " ' GET EQUATION (6 CHARS OR LESS)
07 PMTA
08 ASTO 06 ' STORE IN 6
09 LBL 01
10 CF 04
11 CF 05
12 SF 06
13 XEQ IND 06 ' GET EQUATION PARAMS PROMPT
14 ALENG ' DETERMINE NUMBER OF PARAMS
15 E1
16 X<Y?
17 SF 05
18 CLX
19 9
20 X<=Y?
21 SF 04
22 CF 22
23 PROMPT
24 GTO 01 ' NOTHING ENTERED, ASK FOR PARAMS AGAIN
25 LBL A ' 1ST PARAM ENTERED / TO BE SOLVED
26 E
27 GTO 02
28 LBL B ' 2ND PARAM ENTERED / TO BE SOLVED
29 2
30 GTO 02
31 LBL C ' 3RD PARAM ENTERED / TO BE SOLVED
32 3
33 GTO 02
34 LBL D ' 4TH PARAM ENTERED / TO BE SOLVED IF VALID
35 FS? 05
36 SF 04
37 FC? 04
38 GTO 01
39 4
40 GTO 02
41 LBL E ' 5TH PARAM ENTERED / TO BE SOLVED IF VALID
42 FC? 05
43 GTO 01
44 5
45 LBL 02 ' COMMON PARAM HANDLING
46 FC? 22 ' WAS IT ENTERED?
47 GTO 00 ' NO MUST NEED TO BE SOLVED
48 X<>Y
49 STO IND Y ' SAVE IN REG 01 THRU REG 05
50 GTO 01
51 LBL 00
52 STO 00 ' SAVE LOCATION TO SOLVE
53 RCL 01 ' SAVE PARAMS TO a THRU e
54 STO L
55 RCL 02
56 RCL 03
57 RCL 04
58 RCL 05
59 SF# 4 (ST>B7) ' ENTER AS SF$ ST>B7
61 E-99 ' ASSUME VIRTUAL 0 AND 1 FOR GUESSES
62 E
63 "a^b=?"
64 PROMPT ' GET BETTER GUESSES IF SUPPLIED
65 CF 06
66 XEQ IND 06 ' GET SV$ COMPATIBLE EQUATION TO SOLVE
67 XROM "SV$" ' SOLVE IT!
68 STOP
69 GTO 01 ' GET NEXT PARAMS
70 LBL J ' EXIT ROUTINE, RESTORE USER PARAMS
71 E
72 LKAX
73 END
01 LBL "OHMS" ' EXAMPLE, OHM'S LAW, V=I*R
02 FS? 06 ' GOTO LBL 6 TO DISPLAY ENTRY PROMPT
03 GTO 06
04 RCL 00 ' STORE VARIABLE TO SOLVE
05 GTO IND 00 ' PICK EQUATION BASED ON THAT VARIABLE
06 LBL 01 ' SOLVING FOR V
07 "b*c-X"
08 RTN
09 LBL 02 ' SOLVING FOR I
10 "X*c-a"
11 RTN
12 LBL 03 ' SOLVING FOR R
13 "b*X-a"
14 RTN
15 LBL 06 ' DISPLAY
16 "V I R"
17 END
Greg
