Full Version: define a formula
I have hp prime and I would like to define a formula to make my calculus easy and faster,the formula is annexed here,anybody can help me please?
Thanks
Unless you absolutely want to write a function for that (for learning purposes maybe) you don't have to:
1. You could use the mean(L,p) function where L is the list of values and p the list of probabilities.
2. Or if you write L and p as vectors you could just calculate the dot product of the vectors L and p: [L1, L2, L3,...]*[p1, p2, p3...]
If p1, p2, etc are not probabilities in range 0 to 1, but frequencies instead (e.g. 3 times, 7 times etc) for method 2 you should also divide by sum(p): E(X)=L*p/sum(p)
(03-09-2014 11:40 PM)Stefan Wrote: [ -> ]Unless you absolutely want to write a function for that (for learning purposes maybe) you don't have to:
Thank you,that really help a little,but I have many formulas similar to this one,like this formula annexed below and I would like to know how to make this one to ...
lol, expectancy, entropy... looks like your studying for the same exam than I do :-D
Here you can again use the dotproduct and make use of the fact that you can apply most of the functions to lists and vectors.
log_2(p) applies log_2 to the vector p (the log_n(x) template is in the math templates).
And then just multiply p and log_2(p), just as before: H(x)=p*log_2(p)
P.S: You can type equations in this forum in Latex syntax if you surround them with two $ in the front and back:
$$\frac{1}{x}$$
(03-10-2014 12:10 AM)Stefan Wrote: [ -> ]lol, expectancy, entropy... looks like your studying for the same exam than I do :-D
$$\frac{1}{x}$$
I'm learning in a subject that is called principle of communication II (Hehehe).The dot tip is a good idea,I didn't understood the H(x),you have to make a sum and the PS too,can you try to explain in another way?
Thanks
(03-10-2014 01:05 AM)fefer92 Wrote: [ -> ]I didn't understood the H(x)
I just wrote the H(x) to indicate that this is the complete formula for the entropy. There is no need to enter the H(x) into the calc.
The P.S: instead of including an image for the equations you can write them right away in the text in LaTeX and make two $ around the equation. So e.g. writing
$$\frac{1}{x}$$
leads to $$\frac{1}{x}$$
