I have a 28S and the 2nd bottom row on both sides of the calculator are not working.
How would I go about opening the calculator? I can not find it on youtube either.
Thanks
(07-25-2017 02:31 AM)Jlouis Wrote: [ -> ] (07-24-2017 10:20 AM)beerlim Wrote: [ -> ]I have a 28S and the 2nd bottom row on both sides of the calculator are not working.
Thanks
Try this here
Good luck
Well I went ahead and started to document it.
http://www.teawea.com/how-to-open-a-hp-28s-calculator/
You should be able to see the images
here.
I finished documenting the opening of the HP28S. Same URL as before
Then I cleaned the contacts and put it back together just to see if it worked.
I could not believe it, it really worked.
So my next step will be to create a new case to transfer everything from the old "destroyed" one to the new. Will see how that goes.
(11-28-2017 11:11 AM)beerlim Wrote: [ -> ]… the next step is planed by creating a new case for the HP-28…
Just a suggestion, but wouldn't the
Door-in-Back version of the battery compartment {
as deployed on the final HP-19BII model} have enhanced longevity/utility over the
Door-on-Side version?
BEST!
SlideRule
