My goal with the program is to eventually have the user touch one of the "four corners", which each touch turning the a certain color on (from upper left hand: red, green, blue, yellow). I am not all the way there yet. I am having trouble getting input with the MOUSE command - keep getting "Invalid Input" error. And I am stuck to finding where my error is.
Program I have so far:
EXPORT FOURSQUARE()
LOCAL mx, my, L0;
mx=-1; my:=-1;
REPEAT
RECT();
RECT_P(0,0,318,200);
RECT_P(0,201,318,218,0);
TEXTOUT_P("EXIT",130,218,3,
RGB(255,255,255));
WAIT(-1);
L0:=MOUSE();
mx:=B→R(L0(1,1));
my:=B→R(L0(1,2));
// draw boxes here
UNTIL my≥201;
RETURN "DONE";
Map:
(0,0) to (158, 100): red box that lights up with a touch
(159, 0) to (318,100): blue box that lights up with a touch
(0, 101) to (158, 200): yellow box that lights up with a touch
(159, 101) to (318, 200): green box that lights up with a touch
(0, 200) to (218, 318): black exit box. Touch this region to terminate program.
Any help is appreciated.
Hi, I have just started playing with PPL myself and very much still learning the basics, however I think the alternative below should work for you?
EXPORT FOURSQUARE()
LOCAL mx, my, L0;
mx=-1; my:=-1;
REPEAT
RECT();
TEXTOUT_P("EXIT",130,218,3,RGB(255,255,255));
L0:=WAIT(-1);
IF SIZE(L0)>1 THEN
mx:=L0(2);
my:=L0(3);
// draw boxes here
UNTIL my≥201;
RETURN "DONE";
Jacob
Did you check to see if MOUSE() returned an empty list? The very first instance of MOUSE() may very well return an empty list, in which case L0(1,1) and L0(1,2) would cause errors.
L0:=MOUSE();
// check if we have valid mouse input
IF (SIZE(L0(1)) OR SIZE(L0(2))) THEN
// handles first mouse
IF SIZE(L0(1)) THEN
// code here for mouse 1
// handles second mouse
IF SIZE(L0(2)) THEN
// code here for mouse 2
(12-14-2013 08:51 PM)Eddie W. Shore Wrote: [ -> ]No such luck.
Maybe I'm misunderstanding what you're trying to do, I thought your goal was to do something similar to what the code below does:
EXPORT FOURSQUARE()
LOCAL mx, my, L0;
mx=-1; my:=-1;
RECT();
RECT_P(0,0,320,200);
RECT_P(0,201,320,240,0);
TEXTOUT_P("EXIT",147,214,3,RGB(255,255,255));
REPEAT
L0:=WAIT(-1);
IF SIZE(L0)>1 THEN
mx:=L0(2);
my:=L0(3);
CASE
IF mx<160 THEN
CASE
IF my<100 THEN RECT_P(0,0,320,200,RGB(255,0,0)); END;
IF my<201 THEN RECT_P(0,0,320,200,RGB(255,255,0)); END;
IF mx>159 THEN
CASE
IF my<100 THEN RECT_P(0,0,320,200,RGB(0,0,255)); END;
IF my<201 THEN RECT_P(0,0,320,200,RGB(0,255,0)); END;
UNTIL my>200;
RETURN "DONE";
Jacob
Hi, everyone,
maybe something like that should work...
// MOUSE() ...
EXPORT MOUZ()
LOCAL grey=#707070h;
LOCAL s,DEP=0;
LOCAL x1,y1,xo1,yo1;
RECT_P(G0,0,0,319,219,grey);
DRAWMENU("","","","","","QUIT");
WHILE GETKEY() ≠ 4 DO // Esc to QUIT
CASE
// :::::::::1 FINGER ::::::::::
IF (MOUSE(0)≠−1 AND MOUSE(1)≠−1) AND
(MOUSE(5)==−1 AND MOUSE(6)==−1)
THEN
xo1:=B→R(MOUSE(2));
yo1:=B→R(MOUSE(3));
y1:=B→R(MOUSE(1));
x1:=B→R(MOUSE(0));
CASE
IF 0<xo1<158 AND 0<yo1<100 THEN RECT_P(0,0,158,100,#FF0000h); END;
IF 159<xo1<318 AND 0<yo1<100 THEN RECT_P(159,0,318,100,#FFh); END;
IF 0<xo1<158 AND 101<yo1<200 THEN RECT_P(0,101,158,200,#FFFF00h); END;
IF 159<xo1<318 AND 101<yo1<200 THEN RECT_P(159,101,318,200,#00FF00h); END;
DEFAULT
// :::::::: MENU :::::::::
IF y1>219 THEN
CASE
IF 0<x1< 52 THEN END;
IF 52<x1<105 THEN END;
IF 105<x1<158 THEN END;
IF 158<x1<211 THEN END;
IF 211<x1<264 THEN END;
IF 264<x1<319 AND DEP≠ 0 THEN BREAK; END;
DEFAULT
// :::::::: 0 FINGER :::::::::
IF (MOUSE(0)==−1 AND MOUSE(1)==−1) AND
THEN
RECT_P(G0,0,0,319,210,grey);
DEP:=1;
END; //While
Damien.
Quote:have a look at this code
Some interesting techniques in that code, thanks for sharing!
Jacob
I echo Jacob's comment. Thank you for sharing.
