#cas
simpsonint(g,a,b,n):=
local l,l1;
IF even(n) THEN
IF (type(g)==DOM_SYMBOLIC OR type(g)== DOM_FUNC)
THEN
l:=MAKELIST(X,X,a,b,(b-a)/n);
IF type(g)==DOM_SYMBOLIC THEN
g:=unapply(g,x);
l:=apply(g,l);
l1:=MAKELIST(even(X)+1,X,1,n+1);
return (2*DOT(l,l1)-g(a)-g(b))*(b-a)/(3*n);
ELSE return ("f must be symbolic or function!");
// return 0;
ELSE return "n must be even!";
#end
#cas
trapezregel(g,a,b,n):=
local l;
THEN
g:=unapply(g,x);
l:=apply(g,l);
return (2*ΣLIST(l)-g(a)-g(b))*(b-a)/(2*n);
#end
#cas
rightsum(g,a,b,n):=
local l;
THEN
g:=unapply(g,x);
l:=apply(g,l);
return (ΣLIST(l)-g(a))*(b-a)/n;
#end
#cas
leftsum(g,a,b,n):=
local l;
THEN
g:=unapply(g,x);
l:=apply(g,l);
return (ΣLIST(l)-g(b))*(b-a)/n;
#end
EXPORT NumericIntegr()
local a,N,f,b;
N:=12; a:=1;b:=3;
f:='X^2';
if input(
{{f,[8],{20,70,0}},
{a,[0],{20,30,1}},
{b,[0],{20,30,2}},
{N,[0],{20,30,3}}},
"Enter Data",
{"f(X)=", "a= ", "b= ","N= "
"Enter the function, upper case X!",
"Enter the starting point",
"Enter the endpoint",
"Enter the amount of intervals"
{f,a,b,N}
then
f:=lower(string(f));
PRINT();
PRINT("Simpsonsumme: "+simpsonint(f,a,b,N));
PRINT("Trapezsumme: "+trapezregel(f,a,b,N));
PRINT("Rechtecklinks: "+leftsum(f,a,b,N));
PRINT("Rechteckrechts: "+rightsum(f,a,b,N));
return
end;
after you run it once the cas-functions are shown in memory manager whilst the main program can be seen in toolbox user menu (concerning your other thread)
