In CAS mode if I type
(1-e^(-1/2))/(1-e^-2)
the result is
(e^(1/2))^3/((e^(1/2))^3+(e^(1/2))^2+(e^(1/2))+1)
wich is 0.174326466693
In home mode if I type the same
the result is
0.455054233923 that is the result I was looking for.
How can this be possible?
(07-09-2017 10:12 AM)COB160 Wrote: [ -> ]In CAS mode if I type
the result is
the result is
I get 0.455... in both modes.
(07-09-2017 10:39 AM)toml_12953 Wrote: [ -> ] (07-09-2017 10:12 AM)COB160 Wrote: [ -> ]In CAS mode if I type
the result is
the result is
Type (1-e^(-1/2))/(1-e^-2) in CAS mode click enter and u will get (e^(1/2))^3/((e^(1/2))^3+(e^(1/2))^2+(e^(1/2))+1), then go to home-menu-get from CAS-enter to obtain the numerical value of the result
If the expression is entered in CAS , then use [Shift][Enter], the approximate value returned shows up with the same value as returned when entered in HOME, (on my emulator).
(07-09-2017 12:41 PM)DrD Wrote: [ -> ]If the expression is entered in CAS , then use [Shift][Enter], the approximate value returned shows up with the same value as returned when entered in HOME, (on my emulator).
It is correct, but why when I import the same formula in home mode, it changes the result?
I was not able to reproduce the error either. All I get is 0.455054233923 every way I try.
(07-10-2017 07:00 AM)Freire Wrote: [ -> ]I was not able to reproduce the error either. All I get is 0.455054233923 every way I try.
Could my calculator be damaged?
COB160: What firmware version are you using?
(07-10-2017 06:10 PM)Joe Horn Wrote: [ -> ]COB160: What firmware version are you using?
I don know, I never update the calculator since i bought it! Another strange things I noticed is that there are lines that seem interferences when I tap th screen with the finger
(07-10-2017 09:51 PM)webmasterpdx Wrote: [ -> ]update your firmware
I am Mac OS user, is it possible to do it anyway?
(07-10-2017 08:05 PM)COB160 Wrote: [ -> ] (07-10-2017 06:10 PM)Joe Horn Wrote: [ -> ]COB160: What firmware version are you using?
I don know
Press Home, Help, Tree (soft key), up-cursor, Enter. What "Software Version" is shown?
(07-10-2017 11:52 PM)Joe Horn Wrote: [ -> ] (07-10-2017 08:05 PM)COB160 Wrote: [ -> ]I don know
It is written:
Software version: 2015 6 17 (8151)
Hardware version: C
CAS Version:1.1.2-11
Serial Number...
Operating System: V0.041.558
(07-11-2017 07:13 AM)COB160 Wrote: [ -> ] (07-10-2017 11:52 PM)Joe Horn Wrote: [ -> ]Press Home, Help, Tree (soft key), up-cursor, Enter. What "Software Version" is shown?
It is written:
Hardware version: C
Serial Number...
I downloaded HP Connectivity Kit for Mac OS, but I cannot upgrade the calculator... I have read that if the version firmware I have is too old, I had to upgrade the calculator from windows.
If I have lines on the screen when i scroll history data, could the upgrade fix it?
