Full Version: Existing CAS commands --> Prime discussion
Pages: 1 2 3 4
(11-29-2018 05:18 PM)ijabbott Wrote: [ -> ]Looking at the Giac/Xcas source code for exact and float2rational, they follow different code paths, but do similar things. The main functional difference seems to be that exact imposes a minimum epsilon value of 1e-14, whereas float2rational imposes a minimum epsilon value of 1e-11.
Prime's exact() function can be controlled by setting epsilon to any value between 1e-6 and 1e-15. Since the output of float2rational() can therefore be obtained by exact(), there is no need to add float2rational to the Prime's vocabulary... especially now that QPI is also available:
qpi(.324532453245) --> 295/909
The problem with QPI is that I can not control the output, so it does not always throw the output in rational format.
I propose to add to QPIRLNE
QPIRLNE( EXPR, FORMAT) where FORMAT = 0/1/.../6
case 0: (Default):
qpirlne( expr, 0) -> Expression as pi or root or ln or e
case 1: output only as a expression of QUOTIENT 1:
qpirlne( expr, 1) if it does not find the equivalent to quotient (1), but without
pi, root, ln, e, it returns the same value
case 2: output only as a expression of QUOTIENT 2:
qpirlne( expr, 2) if it does not find the equivalent to quotient (2), but without
case 3: output only as a expression of PI:
qpirlne( expr, 3) if it does not find the equivalent to PI, it returns the same value
case 4: output only as a expression of ROOT
qpirlne( expr, 4) if it does not find the equivalent to ROOT, it returns the same value
case 5: output only as a expression of LN
qpirlne( expr, 5) if it does not find the equivalent to LN, it returns the same value
case 6: output only as a expression of EXPR
qpirlne( expr, 6) if it does not find the equivalent to EXP, it returns the same value
PHP Code:
ex#0:
qpirlne( (2*π/3)+(3*π/4) , 0)  -> 17/12*π
 qpirlne
( (2*π/3)+(3*π/4) , 1)  -> 1137949/255685 // Q1
qpirlne( (2*π/3)+(3*π/4) , 2)  -> 4+(115209/255685// Q2
qpirlne( (2*π/3)+(3*π/4) , 3)  ->  17/12*π // PI
qpirlne( (2*π/3)+(3*π/4) , 4)  ->  (2*π/3)+(3*π/4// ROOT
qpirlne( (2*π/3)+(3*π/4) , 5)  ->  (2*π/3)+(3*π/4// LN
qpirlne( (2*π/3)+(3*π/4) , 6)  ->  (2*π/3)+(3*π/4// e
ex#1:
qpirlneLN(3*π)-LN((5)), 0)  -> LN( (3*π*(5)/5) )
qpirlneLN(3*π)-LN((5)), 1)  -> 55715/38728 // Q1
qpirlneLN(3*π)-LN((5)), 2)  -> 1+(16987/38728// Q2
qpirlneLN(3*π)-LN((5)), 3)  -> LN( (3*π*(5)/5) )  // PI
qpirlneLN(3*π)-LN((5)), 4)  -> LN( (3*π*(5)/5) )  // ROOT
qpirlneLN(3*π)-LN((5)), 5)  -> LN( (3*π*(5)/5) ) // LN
qpirlneLN(3*π)-LN((5)), 6)  -> LN(3*π)-LN((5)) // e
ex#2:
qpirlneLN((2/5))-LN((2)), 0)  -> -LN((25/2))/2
 qpirlne
LN((2/5))-LN((2)), 1)  -> -116599/92329 // Q1
qpirlneLN((2/5))-LN((2)), 2)  -> -1+(-24270/92329// Q2
qpirlneLN((2/5))-LN((2)), 3)  -> LN((2/5))-LN((2)) // PI
qpirlneLN((2/5))-LN((2)), 4)  -> LN((2/5))-LN((2)) // ROOT
qpirlneLN((2/5))-LN((2)), 5) -> -LN((25/2))/// LN
qpirlneLN((2/5))-LN((2)), 6)  -> LN((2/5))-LN((2)) // e
ex#3:
qpirlnee^(2*π/(3*(7))), 0)  -> e^((2*π*(7)/21))
qpirlnee^(2*π/(3*(7))), 1)  -> 224192/101585 // Q1
qpirlnee^(2*π/(3*(7))), 2)  -> 1+(21022/101585// Q2
qpirlnee^(2*π/(3*(7))), 3)  -> e^(2*π/(3*(7))) // PI
qpirlnee^(2*π/(3*(7))), 4)  -> e^(2*π/(3*(7))) // ROOT
qpirlnee^(2*π/(3*(7))), 5)  -> e^(2*π/(3*(7))) // LN
qpirlnee^(2*π/(3*(7))), 6)  -> e^(2*π/(3*(7))) // e
ex#4:
qpirlne7*π/(90), 0)  -> 7*π*(10)/30
 qpirlne
7*π/(90), 1)  -> 171470/73971
 qpirlne
7*π/(90), 2)  -> 260521/112387
 qpirlne
7*π/(90), 3)  -> 7*π/(90)
ex#5:
qpirlne1/(3+i*(3)), 0)  -> (1/4)-i*(((3)/12))
qpirlne1/(3+i*(3)), 1)  -> (1/4)-(1/4)*i*(1/3// Q1
qpirlne1/(3+i*(3)), 2)  -> (1/4)-(i*37829/262087// Q1
qpirlne1/(3+i*(3)), 3)  -> 1/(3+i*(3)) // PI
qpirlne1/(3+i*(3)), 4)  -> (1/4)-i*(((3)/12)) // ROOT
qpirlne1/(3+i*(3)), 5)  -> 1/(3+i*(3)) // LN
qpirlne1/(3+i*(3)), 6)  -> 1/(3+i*(3)) // e
ex#6:
qpirlneACOS((-1/2)), 0)  -> 2/3*PI
 qpirlne
ACOS((-1/2)), 1)  -> 138894/66317 // Q1
qpirlneACOS((-1/2)), 2)  -> 2*(6260/66317// Q2
qpirlneACOS((-1/2)), 3)  -> 2/3*PI // PI
qpirlneACOS((-1/2)), 4)  -> ACOS((-1/2// ROOT
qpirlneACOS((-1/2)), 5)  -> ACOS((-1/2// LN
qpirlneACOS((-1/2)), 6)  -> ACOS((-1/2// e
ex#7:
qpirlneCOS((3*π/4)), 0)  -> -(-2)/2
 qpirlne
COS((3*π/4)), 1)  -> -195025/275807 // Q1
qpirlneCOS((3*π/4)), 2)  -> -195025/275807  // Q2
qpirlneCOS((3*π/4)), 3)  -> COS((3*π/4)) // PI
qpirlneCOS((3*π/4)), 4)  -> -(1/2// ROOT
qpirlneCOS((3*π/4)), 5)  -> COS((3*π/4)) // LN
qpirlneCOS((3*π/4)), 6)  -> COS((3*π/4)) // e
ex#8:
qpirlneCOS(π/12), 0)  -> ((3)+1)*((2)/4)
qpirlneCOS(π/12), 1)  -> 129209/133767 // Q1
qpirlneCOS(π/12), 2)  -> 272847/282472  // Q2
qpirlneCOS(π/12), 3)  -> COS((3*π/4)) // PI
qpirlneCOS(π/12), 4)  -> ((3)+1)*((2)/4// ROOT
qpirlneCOS(π/12), 5)  -> COS(π/12// LN
qpirlneCOS(π/12), 6)  -> COS(π/12// e
ex#9:
qpirlneSIN(π/10), 0)  -> (-1+((5)))/4
 qpirlne
SIN(π/10), 1)  -> 98209/317811 // Q1
qpirlneSIN(π/10), 2)  -> 98209/317811  // Q2
qpirlneSIN(π/10), 3)  -> SIN(π/10// PI
qpirlneSIN(π/10), 4)  -> (-1+((5)))/// ROOT
qpirlneSIN(π/10), 5)  -> SIN(π/10// LN
qpirlneSIN(π/10), 6)  -> SIN(π/10// e
ex#10:
qpirlneSIN(π/8), 0)  -> (2-(2))/2
 qpirlne
SIN(π/8), 1)  -> 69237/180925 // Q1
qpirlneSIN(π/8), 2)  -> 69237/180925  // Q2
qpirlneSIN(π/8), 3)  -> SIN(π/8// PI
qpirlneSIN(π/8), 4)  -> (2-(2))/// ROOT
qpirlneSIN(π/8), 5)  -> SIN(π/8// LN
qpirlneSIN(π/8), 6)  -> SIN(π/8// e
ex#11:
qpirlneCOS(π/5), 0)  -> (1+((5)))/4
 qpirlne
COS(π/5), 1)  -> 98209/121393 // Q1
qpirlneCOS(π/5), 2)  -> 317811/392836  // Q2
qpirlneCOS(π/5), 3)  -> COS(π/5// PI
qpirlneCOS(π/5), 4)  ->  (1+((5)))/// ROOT
qpirlneCOS(π/5), 5)  -> COS(π/5// LN
qpirlneCOS(π/5),, 6)  -> COS(π/5// e
http://www.hpmuseum.org/forum/thread-18-post-83655.html
(11-29-2018 07:25 PM)compsystems Wrote: [ -> ]The problem with QPI is that I can not control the output, so it does not always throw the output in rational format.
case 0: (Default):
PHP Code:
ex#0:
 qpirlne
ex#1:
ex#2:
 qpirlne
ex#3:
ex#4:
 qpirlne
 qpirlne
 qpirlne
ex#5:
ex#6:
 qpirlne
ex#7:
 qpirlne
ex#8:
ex#9:
 qpirlne
ex#10:
 qpirlne
ex#11:
 qpirlne
I suggest a modification: pi, root, e, ln
should each have a value of 1,2,4,8 or zero
and the combination includes the selected separatable operations or values accordingly .
Testing binaries in a progran is easy.
It's also an easy syntax for humans to learn and memorize.
What do you say?
(11-29-2018 05:51 PM)Joe Horn Wrote: [ -> ]
I don't know if the minimum values of epsilon for exact() and float2rational() are different on the Prime, but the values I gave are accurate for the upstream Xcas source. I.e. for float2rational(), setting epsilon to anything less than 1e-11 behaves the same as setting it to 1e-11. Similarly for exact() with an epsilon less than 1e-14.
The float2rational() function sometimes "gives up" and gives you the float back, which is another reason for not implementing it!
Other function type commands to incorporate: equal2diff, list2exp
Sample
c:=circle(0,2); a:=equation(c); b:=4x^2+3x*y+y^2-8;
a:=equal2diff(equation(c));
r:=resultant(a,b,x);
sy:=solve(r=0,y,'='); sx:=sy:;
list2exp(sy,y);
y=(-(sqrt((sqrt(17)+7)/3) or y=(-(sqrt((-(sqrt(17))+7)/3) or y=(sqrt((-(sqrt(17))+7)/3) or (y=(sqrt((sqrt(17)+7)/3)
Test on-line
https://xcas.univ-grenoble-alpes.fr/foru...28&p=10708
On GIAC kernel
(function operator)
not(0) [↵] true
not(1) [↵] false
NOT(false) [↵] true
NOT(true) [↵] false
(prefix operator)
not false [↵] // It does not interpret.
NOT false [↵] true
NOT true [↵] false
not(0), not(1), NOT(false), NOT(true), NOT false, NOT true [↵] true,false,true,false,true,false
test on-line then press [ok], then [exec] button
https://www-fourier.ujf-grenoble.fr/~par...20true&;
HP Prime CAS
1,0,1,0,1,0 // numerical output in a symbolic environment =(
the subtype() command is required to identify the following types of objects
Xcas/HPprime
type(set[a,a,b]),type(poly1[0,0,3,-1]),type(a,a,b) [↵] returns
DOM_LIST,DOM_LIST,DOM_LIST
Xcas
subtype(set[a,a,b]),subtype(poly1[0,0,3,-1]),subtype(a,a,b) [↵] returns
2,10,1
according to XCAS help
subtype() cmd
Returns 1 for a sequence: for example (a,a,b),
2 for a set: set[a,a,b],
10 for a polynomial: poly1[0,0,3,-1]
and 0 otherwise.
PHP Code:
purge(a,b
// +0 to obtain the numeric value of the reserved word or constant
DOM_FLOAT+0,DOM_INT+0,DOM_COMPLEX+0,DOM_IDENT+0,DOM_LIST+0,DOM_SYMBOLIC+0,DOM_RAT+0,DOM_STRING+0,DOM_FUNC+0 ↵
1
,2,4,6,7,8,10,12,13
type
(3.0↵ DOM_FLOAT
type
(3.0)+0 ↵ 1
type
(3↵ DOM_INT
type
(3)+0 ↵ 2
type
(3+4*i↵ DOM_COMPLEX
type
(3+4*i)+0 ↵ 4
type
(abc↵ DOM_IDENT
type
(abc)+0  ↵ 6
type
({a,a,b}) ↵ DOM_LIST
type
({a,a,b})+0 ↵ 7
type
(a+b)↵ DOM_SYMBOLIC
type
(a+b)+0 ↵ 8
type
(3/4)↵ DOM_RAT
type
(3/4)+0 ↵ 10
type
("3/4")↵ DOM_STRING
type
("3/4")+0↵ 12
type
(f(x):=x+1)↵ DOM_FUNC
type
(f(x):=x+1)+0 ↵ 13
set1
:= set[a,a,b]; type(set1↵ DOM_LIST
type
(set[a,a,b]);↵ DOM_LIST
type
(poly1[0,0,3,-1]); ↵ DOM_LIST
type
(a,a,b); ↵ DOM_LIST
type
subtype
(set[a,a,b]),subtype(poly1[0,0,3,-1]),subtype(a,a,b),subtype(a+b*i)
2,10,1,
op() function command: Transform a list into a object type sequence (undocumented command) . Please, make it visible in the catalog menu.
Source:
https://www-fourier.ujf-grenoble.fr/~par...akesuiteop
Sample: (Disable Textbook display for better understanding)
Input: (0,1,2)
Output : 0,1,2
Input: seq1:=0,1,2
Output : 0,1,2
Input : op([0,1,2])
Output: 0,1,2
the inverse command to op() is required
makevector() function command: Transform a sequence object into a list object
Source: https://www-fourier.ujf-grenoble.fr/~par...de367.html
Input: makevector(0,1,2)
Output: [0,1,2]
Input: seq1:=0,1,2
Output : 0,1,2
Input: makevector(seq1)
Output: [0,1,2]
(12-09-2018 05:19 PM)compsystems Wrote: [ -> ]op() function command: Transform a list into a object type sequence (undocumented command)
Source:
Input: (0,1,2)
Output : 0,1,2
Input: seq1:=0,1,2
Output : 0,1,2
Input : op([0,1,2])
Output: 0,1,2
Output: [0,1,2]
Input: seq1:=0,1,2
Output : 0,1,2
Output: [0,1,2]
There is no makevector command on HP Prime as described in the cascmd_en. I think I used it a while ago but, somehow it misteriously disappeared from HP Prime.
(12-09-2018 11:47 PM)John P Wrote: [ -> ]There is no makevector command on HP Prime as described in the cascmd_en. I think I used it a while ago but, somehow it misteriously disappeared from HP Prime.
It was never included in Prime's vocabulary.
(12-10-2018 01:43 AM)Joe Horn Wrote: [ -> ]
Probably not, but I think I used it after reading, a while ago, the cascmd_en. Now when I type makevector(1,2,3) nothing happens on my HP Prime with the latest firmware. Maybe you have different one.
(12-10-2018 05:45 AM)John P Wrote: [ -> ]
(12-10-2018 01:43 AM)Joe Horn Wrote: [ -> ]It was never included in Prime's vocabulary.
It seems that we always have to state the hardware platform as well as the firmware version.
Although I meant that no version of the HP Prime firmware, ever, has had a 'makevector' command (I checked a bunch of versions, from beta versions before Prime was even announced, through the most recent version, including my 8 Primes which have different official firmware versions installed in each), it is possible that 'makevector' was introduced at some point and then removed again in a subsequent firmware version. Although I wouldn't bet on that, I'd be happy to be proven wrong.
(12-11-2018 03:49 AM)Joe Horn Wrote: [ -> ]
(12-10-2018 05:45 AM)John P Wrote: [ -> ]Probably not, but I think I used it after reading, a while ago, the cascmd_en. Now when I type makevector(1,2,3) nothing happens on my HP Prime with the latest firmware. Maybe you have different one.
You could be right. I remember when reading 'cascmd_en' about that command. I was probably trying to see how it worked on HP Prime. Did I used the command? Not sure. Maybe I did not find it and this is probably how I remember it. It is OK. I will not start some big commotion because of the 'makevector' and if I really, really needed it I would probably already write some little prgm. to substitute for it.
Cheers, John.
(12-11-2018 04:56 AM)John P Wrote: [ -> ]I will not start some big commotion because of the 'makevector' and if I really, really needed it I would probably already write some little prgm. to substitute for it.
Unless I am mistaken, its functionality can be achieved simply by using square brackets. Example (with Textbook Display turned off):
a:=3,4,5
a --> 3,4,5
[a] --> [3,4,5] which is the same output as makevector(a).
or:
mat2list(a) --> {3,4,5} if you prefer a list instead of a vector.
Another alternative way is: eval(seq(a,1))
but the important thing is to have a functional command, makevector(), dedicated for that purpose.
For example QR() returns a sequence Q,R, with makevector() returns a vector
makevector(QR([[1,2],[3,4]]))
There is also a need to document the lowercase qr() function command
makevector(qr([[1,2],[3,4]]))
The index functional command is not documented but it works. Please, make it visible in the catalog menu.
Help text.
Index acts as a system variable and as a functional command,
For functional command:
Index() returns the first position of an object in a list, a string or a set, if it does not find the object returns an error message.
index( List/String/Set, Object )
Examples:
LIST:
index:=0:; index([9,8,-1,8,9,8,7],8) [↵] returns 1
index:=1:; index([9,8,-1,8,9,8,7],8) [↵] returns 2
SET:
index:=0:; F_ := set[ H_,E_,L_,L_,O_];
F_ => set[ H_,E_,L_,O_]; the multiplicity of L_ is eliminated
index(F_,O_) [↵] returns 3
index(F_,L_) [↵] returns 2
The find functional command, is not documented but it works. Please, make it visible in the catalog menu.
Help text:
List of positions of an object in a list, a string or a set.
find(Object/List/String/Set)
index:=1:; F_:=[H_,E_,L_,L_,O_]; find(L_,F_) [↵] returns [ 3, 4 ]
The minus functional command, is not documented but it works. Please, make it visible in the catalog menu.
set[ "H", "E", "L", "L", "O"] minus set[ "H", "E" ]; [↵]
set["L", "O" ]
is_included() function synonym of ⊂ is not yet visible in the hp-prime catalog.
is_included(set[ "a", "d" ], set[ "b", "a", "c", "a" ]) [↵] 0
For a more intuitive output the numeric value [>0]/0 should be symbolix true/false, in this way the use of the EVALB() command is avoided.
evalb(is_included(set[ "a", "d" ], set[ "b", "a", "c", "a" ])) [↵] false
test online
session Xcas
more on sets
http://www.hpmuseum.org/forum/thread-11968.html
Pages: 1 2 3 4
