09-11-2017, 05:14 PM
(09-11-2017 01:53 PM)David Hayden Wrote: [ -> ](09-05-2017 09:33 PM)Joe Horn Wrote: [ -> ]The problem of long garbage collections when there are a lot of exploded list items on the stack can be avoided by first storing the list into a global variable.Brilliant!
This is indeed a great option for avoiding the list/GC issues. Now that I've had a chance to run some tests with it, I've realized that there's still a potential "gotcha", though. In particular, it's not necessarily as memory-friendly as I was originally thinking.
The reason is that you will end up with (at least) two copies of the original list in memory for almost all scenarios while you are processing the list contents (assuming the list wasn't already saved to HOME). The first copy is the one saved in TEMP by the CKx... step of each command. Then the second is in HOME (by definition). Any altered elements will also be allocated in TEMP. So memory constraints can still play into this for large lists.
Avoiding that first copy in TEMP is possible, but it gets messy. Keeping it out of TEMP means it can't already be there when the CKx&Dispatch step is performed. Saving it to HOME prior to CK&Dispatch requires validating argument types before the "official" argument checking occurs, and has to be done carefully to avoid any errors being raised.
The payoff is great in the situation where lots of exploded list items exist on the stack and a GC occurs. Deciding (programmatically) how and where to apply that technique is not always straightforward, though. I'm still trying to figure out the best approach.
Thoughts are appreciated!
