I had originally planned to have a 1.0 release of the library as the next official update, but several very good requests for commands prompted me to add those and a couple other simple ones to the set. There's been enough change in this one to warrant a ".1" version change as well. I'll add the usual notes at the bottom of this post, but here's some more specific comments about the newer commands:
MENU1423
There's now a custom menu that activates when you select the ListExt library from the LIB command (right-shift 2). The quantity of commands virtually makes this type of presentation a necessity, as searching for commands in the ever-growing menu was becoming a chore. The organization of commands into categories will hopefully make it easier to locate the ones you need faster, though it does take some getting used to. See below for the full breakdown of categories and the commands they contain. One of the nice things about this approach is that the menu can be altered/reordered without regard to the internal structure of the library, so (hopefully) the library's command numbers will no longer be subject to change after this release. Newer commands can be added to the "end" of the library and placed wherever it makes the most sense in the menu. "MENU1423" is actually a user command that can be used to activate the menu via an assigned key (or program) if desired. I'm planning to assign mine to "left-shift-hold +", which conveniently already has a { } label.
LPUSH
LHDTL was a simple (but very convenient) function that Pier had suggested some time back. In my mind, I came to think of it as a "POP" command, as it pops the first element of a list and leaves the rest behind. After becoming aware of the ability to have command aliases, I thought this would be a good time to rename LHDTL to LPOP and keep an alias of LHDTL active for the same function. LPOP would be lonely without LPUSH, so I went ahead and added that command to balance it out.
LRSPL
aka LSPLITR. Like its counterpart LSPLT, this simply splits a list into two parts based on the argument you supply. Instead of counting from the left, though, LRSPL counts from the right. This command was actually the inspiration for LLAST, which in turn needed LFRST to balance it out...
LFRST,
LLAST
Returns a list containing the first/last <n> elements of the original list provided as an argument.
LPICK
BruceH suggested this one, and I knew as soon as I saw it that it was a great idea. I think this is actually a very powerful addition, as it nicely combines both a "selection" and an "ordering" function into one command.
LRMOV
"List Remove". This one was actually a little trickier to implement than I thought it would be. There's several possible approaches, but the hard part was getting it to perform reasonably well with large lists. This version features a couple of custom Saturn routines to minimize the iteration of list contents as the target indicies are being validated.
KSORT
"Key Sort". I decided to implement this "sort helper" as follows: given a list and its corresponding list of keys, the two are combined and passed to either the internal SORT command, or a user program if provided (eg. « LSORT »). Allowing the optional user program also provides flexibility; the user program could further manipulate the interim list, save it for later use, or simply do nothing at all if it's determined that sorting isn't needed. If you don't supply a user program, the two lists are simply bundled/sorted/unbundled.
As always, see the command description document for full details. Thanks to everyone for your combined efforts at making this a useful collection of commands! Please give these newer ones a try. Those last three (LPICK, LRMOV, KSORT) probably need the most testing -- the others are just simple shortcuts.
Edit: The attachment has been deleted; see the first post in this thread for the latest version.
______________________________________________________________________________
ListExt Release Notes
Version 1.1.0d
2017-08-30
- Argument order for RPTCHR swapped (now: CHAR, COUNT).
- Updated the library description text to "ListExt Commands".
- Created a menu for the library commands that is activated either by the user function "MENU1423" or by selecting the "ListExt Commands" library directory from the LIB (RS-2) menu.
- Renamed commands: LHDTL to LPOP (kept LHDTL as alias), LDST to LDIST, LRLL to LROLL, LSHF to LSHUF, LSWP to LSWAP, LPOS to MPOS, LPOSL to MPOSL
- Command aliases added: LROLLD → LRLLD, LSPLIT → LSPLT, LOCASE → LCASE, UPCASE → UCASE
- MPOS now accepts two strings as arguments
- Added commands: MENU1423, LPUSH, LRSPL, LPICK, LFRST, LLAST, LRMOV, KSORT
- Bumped version to 1.1.0 and changed status to "d" (development) due to the nature of the updates in this release.
COMMAND SUMMARY
List Creation (CREAT menu)
LSEQ - creates a list of <count> integers as a sequence from 1..<count>
LSEQR - creates a list of integers for the range specified
LMRPT - repeats list contents as indicated by count
LNDUP - creates a list by repeating an object as indicated by count
List Editing (EDIT menu)
LDDUP - removes duplicates from a list
LPOP - retrieves the first element in a list while leaving the rest on the stack
LPUSH - adds object to front of list
LPICK - returns a list containing identified elements in specified order
LREPL - replaces list elements with a substitute object as indicated
LRMOV - removes 1 or more elements from a list as indicated
LFRST - returns the first <n> elements of a list
LLAST - returns the last <n> elements of a list
LRCL - recalls objects identified by variables in a list
Element Arrangement (ARRNG menu)
LROLL - rolls the list (equivalent to 1 LROT)
LRLLD - "roll down" the list (equivalent to -1 LROT)
LROT - rotates list elements left or right as indicated by count
LSWAP - swaps the positions of two list elements
KSORT - Sorts a list based on keys from a separate list
LSHUF - shuffles the contents of a list
Element Grouping (GROUP menu)
LCLLT - collates a list of sublists
LDIST - distributes list items into sublists (reciprocal of LCLLT)
LGRP - replaces repeated elements with a single instance
LRPCT - list with LGRP elements and another list of the count of each element
LSPLT - splits a list as indicated into two sublists
LRSPL - splits a list as indicated from the right into two sublists
LSDIV - subdivides a list into <count> sublists
LXIL - explodes inner sublists into individual elements (non-recursive)
LXILR - recursive version of LXIL
List Testing (TEST menu)
LCNT - counts objects in a list
LEQ - checks list items to see if any do not match
MPOS - returns a list of all positions of an object in a list, or a substring in a string
MPOSL - returns a list of all positions of an object in a list or its sublists
Combinatorics (COMB menu)
DOCOMB - feeds indicated combinations of a list to a user-supplied program
DOPERM - feeds indicated permutations of a list to a user-supplied program
List Math (LMATH menu)
LSUM - ΣLIST that also accepts lists with 0 or 1 element
LPROD - ΠLIST that also accepts lists with 0 or 1 element
String/Number Conversion (STRNG menu)
CHR+ - adds an offset to the CHR value of each character of a string
LCASE - converts upper case characters in a string to lower case
UCASE - converts lower case characters in a string to upper case
RPTCHR - creates a string of repeated characters
I→NL - converts an integer to a list of numbers
NL→I - converts a list of numbers to an integer
S→NL - converts a string to a list of numbers
NL→S - converts a list of numbers to a string
S→SL - converts a string to a list of characters
SL→S - converts a list of characters to a string
Other Commands
About - Library short description and version information
Unins - Detaches and deletes the library
Not included in the menu:
MENU1423 - activates the ListExt menu
