Version 1.1.3b3 has now been added to the
first post in this thread. Several updates have occurred, most notably a couple of new commands and an important bug fix that addresses a potentially nasty crash that will definitely cause loss of data if you run into it. More on that below. First, the new commands:
I→BL and
BL→I. Although the most obvious use of these is in doing base conversions, they are also quite useful in other contexts. Especially when combined with some of the other ListExt commands:
______________________________________________________________________________
I→BL (Integer to Base List)
Input
2: number
1: base (number)
Output
1: { sequence of remainders }
Converts the number given in stack level 2 into a reverse-order sequence of remainders after division by the base given in stack level 1). The base will be rounded to an integer before evaluation, and the result after rounding must be greater than 1. The source argument in stack level 2 must be greater than or equal to 0.
Examples:
15 2 I→BL => { 1 1 1 1 }
1234. 16. I→BL => { 4. 13. 2. }
12345678901234567890 64. I→BL => { 10 45 20 42 24 51 43 7 48 43 18 }
342391 8 I→BL NL→I => 1234567
11806310474565 16 I→BL NL→S { 0 9 48 } CHR+ { 10 15 55 } CHR+ => "ABCDEF12345"
12345678901234567890 92 I→BL NL→S 35 CHR+ => "=0TW&V[UFA"
BL→I (Base List to Integer)
Input
2: { sequence of remainders }
1: base (number)
Output
1: integer
Performs repeated multiplication by the base in stack level 1 and addition of remainders in the argument given as a list in stack level 2. This is the reverse of the operation performed by I→BL. All numbers in the remainder list are rounded to the nearest integer before evaluation, and the result of that rounding must be in the range 0..<base-1>. The final result is always an exact integer, regardless of the type of the remainder values. The rounded base number must be greater than 1. An empty list as the source argument in stack level 2 will generate a value of 0 for the result.
Examples:
{ 1 1 1 1 } 2 BL→I => 15
{ 4. 13. 2. } 16. BL→I => 1234
{ 10 45 20 42 24 51 43 7 48 43 18 } 64. BL→I => 12345678901234567890
{ } 16 BL→I => 0
1234567 I→NL 8 BL→I=> 342391
"ABCDEF12345" { 48 57 -48 } CHR+ { 65 70 -55 } CHR+ S→NL 16 BL→I => 11806310474565
"=0TW&V[UFA" -35 CHR+ S→NL 92 BL→I => 12345678901234567890
Overflow bug in sequence creation commands
Versions 1.1.2 through 1.1.3b2 of the library all have a cringe-worthy bug that can wipe out the contents of your calculator. I'm not aware of anyone having run into it yet (besides me in testing
), but it can come up when passing arguments to the commands that would attempt to create much larger lists than would normally fit in the available memory of your calculator. Element counts greater than approximately 45589 (varies slightly by command) will trigger an undetected overflow which will cause the commands to blithely wipe out memory addresses well beyond their limits. Please just take my word for it and don't try this on your own unless you simply want to reset your calculator for some reason. It
will crash, and data loss will occur on those versions. The 1.1.3b3 release no longer has this issue.
Other changes
A couple other minor changes were put in place, including the ListExt menu now being available from the APPS list. See the release notes for more details on those changes.
