06-21-2017, 01:26 PM
hi,
i am trying to build calc.bin for wp34s from source.
i installed minGW, yagarto, perl and svn.
i have also read the following pages:
http://www.wiki4hp.com/doku.php?id=34s:h...d_emulator
http://www.wiki4hp.com/doku.php?id=34s:windows_7_64bit
when i type mingw32-make in cmd it gives the following error.
tools/wp34s_asm.pl -pp -op tools/wp34s.op -c -o xrom.c xrom_pre.wp34s
// WP 34S assembly preprocessor enabled: '-pp'
// Opcode map source: tools/wp34s.op (specified)
// Opcode SVN version: -- unknown --
// Running WP 34S preprocessor from: C:/wp34s/wp34s-code/tools/wp34s_pp.pl
ERROR: wp34s_pp.pl::get_options: Must enter at least one file to process.
Enter 'wp34s_pp.pl -h' for help.
WARNING: wp34s_asm.pl::run_pp: WP 34S preprocessor failed. Temp file: '.__0.9441
26414907263.tmp'
ERROR: wp34s_asm.pl::run_pp: Perhaps you can try running it in isolation using:
$ "C:/wp34s/wp34s-code/tools/wp34s_pp.pl" -m 235 -cat .__0.944126414907263.tmp
-v3 -xrom -e2so -sd 4 -colour_mode 0
Makefile:429: recipe for target 'xrom_labels.h' failed
mingw32-make: *** [xrom_labels.h] Error 255
any help would be much appreciated.
i am using win7 64bit.
26414907263.tmp'
