06-11-2017, 02:30 PM
Hello, the output "window" or view of the hp-prime (terminal) was designed only for the numeric environment or plain text HOME, so it does not print in pretty-print 2D, symbolic expressions (CAS)
The challenge is to create a viewer of equations, in first step can only be simulated a pretty print witn ascii chars as the following image
![[Image: mathomatic_windows.png]](http://qpdownload.com/data/mathomatic/screenshot/mathomatic_windows.png)
Someone knows some source code that can be ported to hp-prime?
