Hi Friends,
I am working with diff command BUT using variable name that stores a function F(X) some results include diff command again
Using diff in HOME direct goes fine:
diff(SEC(X)-1,X)
returns
SIN(X)/COS(X)^2
The problem is if the function is stored in a variable in this case fx
fx:='SEC(X)-1'
diff(fx,X)
returns
diff(SEC(X),X)
returns diff as part of result.... then HOW TO GET the final derivative using variable ?
Pd. I use diff in a program to calculate derivative then show it to user and evaluate in some X points.
Thanks for your answer. Best regards!!
joseph
Have you tried:
EVAL(diff(fx,X))
-road
(06-10-2017 02:43 PM)roadrunner Wrote: [ -> ]Have you tried:
EVAL(diff(fx,X))
-road
Thanks roadrunner,
I alredy tried EVAL(diff(fx,X))
The problem is if fx has funtion like 'SEC(X)+X^2'
diff returns diff(SEC(X),X)+2*X and EVAL will solve the diff issue but also will replace the X with its value.
I appreciate this and future suggestions.
Best regards!!
jose
The only way I can think of at the moment is to do it in CAS with small x's and then substitute in the big X's, try this from the home screen:
CAS("fx:=SEC(x)+x^2")
CAS("subst(eval(diff(fx,x)),x='X')")
You should get:
(SIN(X)/COS(X)^2)+2*X
-road
(06-10-2017 04:46 PM)josephec Wrote: [ -> ] (06-10-2017 02:43 PM)roadrunner Wrote: [ -> ]Have you tried:
EVAL(diff(fx,X))
-road
Thanks roadrunner,
Best regards!!
jose
I get the correct answer with eval and X keeps its old value. I set X:=2 then did EVAL(diff(fx,X)). That worked then when I typed in X and Enter
I got 2 back.
Tom L
(06-11-2017 12:29 AM)roadrunner Wrote: [ -> ]The only way I can think of at the moment is to do it in CAS with small x's and then substitute in the big X's, try this from the home screen:
You should get:
-road
Hi Roadrunner,
Thank You so much, WORKS GREAT...
as user enter X and no x, I used:
dfx:=CAS("subst(eval(diff(subst(fx,'X'=x),x)),x='X')");
then dfx will hold the final derivative with X variable to show to user and continue using it in my program
Thanks and have an excellent weekend!
joseph
(06-11-2017 01:54 AM)toml_12953 Wrote: [ -> ] (06-10-2017 04:46 PM)josephec Wrote: [ -> ]Thanks roadrunner,
Best regards!!
jose
I got 2 back.
Tom L
Hi Tom
Thanks for trying and suggesting...
Quote:diff returns diff(SEC(X),X)+2*X and EVAL will solve the diff issue but also will replace the X with its value.
I mean that X´s value is replaced in the +2*X part ... but the solucion offered by Roadrunner works great using
I appreciate Your time and suggestion.
Have an excellent week.
joseph
Here is a function that will differentiate equations written with HOME variables WITHOUT substituting in the value contained in the variable:
PHP Code:
EXPORT HOMEDIFF(z,n)
LOCAL a;
a:=CAS("subst(z,n=t25369a)");
RETURN CAS(EVAL("subst("+simplify(CAS(EVAL("diff("+a+",QUOTE(t25369a))")))+",t25369a=n)"));
example 1:
fx:='SEC(X)+X^2'
HOMEDIFF(fx,'X')
returns:
(2*X*SIN(X)^2-2*X-SIN(X))/(SIN(X)^2-1)
example 2:
HOMEDIFF('X^2+LN(SIN(X))','X')
returns:
(2*X*SIN(X)+COS(X))/SIN(X)
There are a few caveats:
1. It doesn't always work on the handheld calculator. It only works on the emulator and apps. Presumably, if the handheld is ever updated, it should start working there;
2. It doesn't work if you have either a CAS or user variable named t25369a;
3. Simplification isn't very good;
4. You have to use a valid CAS equation: X^3.2 won't work, X^(32/10) will work.
-road
edited to add caveat #4 and to correct a grammatical error
Hi Roadrunner,
Thanks for the detailed solution, simplification is not necesary for now... we hope more development in HP Prime CAS,
Best regards!!
joseph
(06-15-2017 07:00 PM)roadrunner Wrote: [ -> ]Here is a function that will differentiate equations written with HOME variables WITHOUT substituting in the value contained in the variable:
PHP Code:
LOCAL a;
example 1:
fx:='SEC(X)+X^2'
HOMEDIFF(fx,'X')
returns:
example 2:
returns:
-road
Well, this is what I have that works here for me:
The program is:
EXPORT fx,fxPrime;
EXPORT diffTest()
INPUT({{fx,[8]}},"Enter Expression");
fxPrime:=diff(fx,X);
Not sure if Bernard added something to the CAS, but I'm guessing a slight tweak somewhere may be responsible. Everything seems to be working as expected?
